XTR hub?
aka Timi
XTR hub?
Any downside to an XTR hub compared to XT for a touring rear wheel?
I'll be needing a new rear wheel soon and am considering an XTR hub. I met a guy with them on his mountain bike, and was impressed that it was totally silent when coasting.
I realise it probably isn't "worth it", but as long as there is no disadvantage, so...
cheers!
cheers!
imi, I've actually found XTR and D-A hubs to be more noisy when coasting than Shimano's other groups. I don't know if there is any disadvantage to the XTR hub when used for touring, but there was some concern when the XT line began using aluminum axles.
Brad
Brad
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,220 Times
They are a good lightweight tough as nails hub that you can pound off-road. They aren't particularly delicate considering that they are made for demanding conditions. There are some of problems with them, however. First, finding a 36 hole XTR hub isn't impossible but it's not as common as a 32 hole hub. Second, if you buy new ones, you'll only find them in disc versions. If you need a disc hub that's good news but if you don't need discs, why pay for the privilege of using them?
Third, they aren't cheap. You could buy a good set of White Industry hubs that aren't disc compatible and run very, very, very smooth on seal cassette bearings for about the same price or you could buy a set of Phil Wood hubs that also run very smooth and can be taken apart with a 5 mm allen wrench for a bit more money. My rear Phil's cassette mechanism comes completely out of the body making spoke replacement on the drive side much easier and simpler.
Stuart Black
Stuart Black
aka Timi
Thanks guys. Yeah i saw there are only disc XTR hubs now. Wasn't that many months ago I found the non-disc model...
I'm not sure if White or Woods hubs are easy to get in Europe? i buy most of my stuff online from England.
Ordering stuff, especially from the USA, from an LBS is usually extremely expensive here in Sweden.
One of my reasons for wanting to stick with Shimano was that in case of hub problems 'anywhere in the world', it would be easier to get a replacement hub and the old spokes would fit.
I'll probably go for XT again, but it is interesting to explore new possibilities
I've seen that some people have issues with XT's having aluminium axles, though I suspect this is more relevant if one is heavy, loaded very heavily... or jumping off things! n'est-ce pas?
I have XTR 950 (older) hubs on my 26" touring bike and have been pretty happy with them. If you don't need disc capability, I'd try to find an older set in good (or NOS) condition and build them up.
Quoted: 12194 Post(s)
Liked 1,497 Times
Me and the wife both have bikes with XTR hubs.
I got NOS from ebay, and bike shops. It didn't cost a lot.
https://www.ebay.com/sch/i.html?_nkw=....c0.m270.l1313
As far as appearance goes, I like the looks of the 950 best.
Liked 4,220 Times
White Industries lists a dealer in Sweden including this website.
Stuart Black
Stuart Black
Rhythm is rhythm
It seems like it would be durable enough because it's a mtn bike hub and is meant to take a ton of abuse. And it goes without saying that shimano makes good quality stuff, so if you're into disc brakes I'd say go for it.
aka Timi
Cheers Cyccommute! I could have done a bit more homework myself there!
Older years they were steel axles, newer , to cut grams, the axle is Aluminum alloy..
No personal Experience,
though, there are simple designs including my Old bullseye Hubs
of making a really thick large diameter axle of aluminum, plenty strong.
Quoted: 19 Post(s)
Liked 7 Times
The issue with aluminium axles is not strength but the reduced space for bearings. The ball bearings are smaller than used on steel-axle hubs. There seem to be more freewheel failures, eg cracked shells. Have they reduced the shell thickness?
If you are looking for a premium touring hub and you have the money, then Phil Woods is the obvious choice. The spares support is a lot better than for Shimano in the long run.
Liked 4,220 Times
Just trying to do something about my nation's trade imbalance
Stuart Black
Stuart Black
Phil Wood list several dealers in Sweden and many more in Europe. Might be worth looking into.
Liked 4,220 Times
can i ask what model of phil wood 9 speed hud would you recommend. i would like a good strong but light rear wheel so hub spokes and rim in 559 (600) i see sjs cycles in the uk sell phil wood hubs so i would like to get a price off them if i new what to ask for thanks.
Stuart Black
Stuart Black
Dropping the need for a 9 speed cassette, I found Phil's freewheel Hubs great.
(I had a 48 hole so a broken spoke never stopped me,
in spite of not being able to replace it on the spot...
a bit of truing and I was good to go, on 47 remaining.)
7 speeds , but in a wide ratio spread, [+ triple crank]
have worked well for my long distance travels ..
Phil's freehubs , as I have read, Occasionally need a cleaning and re oiling,
when the function falters, but are made to be field stripped to do so..
just don't lose any small parts way out in the outback..
sorry imi dont mean to hijack your thread honest .
Liked 4,220 Times
I'd go with something that is off center drilled for the rear like a Velocity Synergy O/C (or even an Aerohead O/C) and the matching rim in the front. I'd build the wheel with DT Swiss Alpine III or Wheelsmith DH13. Both have a stronger head which makes for a stronger wheel.
Stuart Black
Stuart Black
aka Timi
Them Phil Wood hubs sure look nice They come in lots of pretty colours as well!
Good to know sjs have them, thanks for the tip, anto
aka Timi
re axle and spacers to suit, theres 10+mm of extra length on the left..
145, down to 135 ..
and Shimano's tandem hubs offer 40 spoke holes & 48.
my loaded touring bike, got a bit overbuilt for reliability and it worked.
145, down to 135 ..
will do imi,
fietsbob my wheels are sun rhyno on xt hubs sapin stainless spokes, great wheels sjs built them for me but to be honest i want a much lighter wheel i just think there overkill for the touring i do .
less spokes , just bring spares.. the cassettes come off, easier than freewheels,
with tools brought along.
freewheel , 6 speed , I could ride for a week on the 37 spokes Till I borrowed the big spanner.
DIY wheels, might be different at 1.50 per spoke, DB DT, and such,
than it was back when I got them at .35 each.
then a common 36 or 32 would be fine.. , screw up the wheel ,
you just buy a replacement.
no attachment to fancy stuff , works too..
just a different shopping philosophy.
If imi feels a desire to top shelf the parts , go for it.
20+mph Commuter
Bikes: Surly LHT, Surly Lowside, a folding bike, and a beater.
Quoted: 1434 Post(s)
Liked 331 Times
I have XT hubs that have worn out two touring bikes. After five years I decided to clean and re-grease the hubs. When I looked inside, everything, including the factory grease looked so new I just put the hub back together and rode another five years, rain or shine. I am still riding on those wheels but the rims braking surfaces are well canoed and will certainly fail soon. I already have a new set of wheels with new XT hubs ready to go.
So I guess if you can get XTR cheap somewhere, why not. But XT hubs will serve you well. If I had to spend a ton extra for XTR I might take a pass. It is my understanding that the "R" in XTR stands for "R&D". XT is top of the line, XTR is the next generation "beta" version of the component. I ride an XTR long cage rear derailleur. It looks really cool, and I picked it up cheap. I would have been just as happy with an XT no doubt.
