Another weight limit/road bike thread
Old and in the way.
So when I started dieting my goal was to get below 300 and then buy a road bike. I have been using a Surley Kona which is a good bike but about as much fun to ride fast as my Toyota Tacoma is to drive fast; which is to say not very. Well I was looking around the interwebs and found a Cannondale R1000 for sale near me cheap. I have agreed to buy it. It had 32 spoke wheels which is nice but I am concerned I will wreck it if I ride it at my current weight (330) Should I put it to the garage until I lose some weight or get on the pony and ride?
ride it, and ride it some more.
Heft On Wheels
Quoted: 887 Post(s)
Liked 560 Times
Ride it until you break a rear spoke. Front wheel will be just fine, rear will be depending on how well the build it. BUT I would suggest start saving for a new rear wheel. But yes, ride the think and have fun. I was riding road bikes at 336lbs when I started the diet. Had alum frame and some 36 spoke wheels made and never had an issue. Down under 300 now and rolling better yet.
Good luck, enjoy the ride!
Bikes: 2015 Ghost Panamao X3; 2015 Specialized Diverge Comp Carbon
Quoted: 63 Post(s)
Nice ride! I've been riding on 24 spoke wheels from about 300 lbs without any trouble. Bigger tires though (700 x 28).
Bikes: 2001 Waterford RST-22, 2002 Gunnar Sport, 1999 Trek 520 gravel grinder
Quoted: 35 Post(s)
Liked 5 Times
At my heaviest, I went about 295. I rode 36-spoke Mavic Open Pros with 28c tires and had no trouble at all -- no bent or broken spokes, and I ride on West Virginia's notoriously ill-maintained roads! I've never even had to re-true one of the Mavics. I'm now at 233 pounds and shooting for 215. I highly recommend Open Pros; they're as close to a bombproof rim as I've ever ridden. Good luck with your weight-loss regimen!
Bikes: '18 Giant Defy,'18 Trek FX3, Early '90s Giant Iguana
Quoted: 19 Post(s)
I'd probably just take it to a LBS and have them check tension and true. Then just ride it. I popped the reflector of the rear wheel of my le tour when I put a bit of torque to the wheel getting out my driveway with the spokes a little loose. I'm at 265 right now.
Getting older and slower!
That the wheel is true is as important that the number of spokes you have.
Old and in the way.
Just an update bought the bike. The guy had a tune up done before he gave it to me (for $450 no less) and its pristine, Have just over 100 miles on it no issues yet, although I am super careful not to hi potholes or curbs with it.
Old and in the way.
You mean they won't stay like that forever? You don't say! Gosh maybe someone could invent something to make sure they get attention before they break... we could call it "Preventative Maintenance" or "PM" for short.
Sorry I am an Engineering Tech. PMs are my job.
Mad bike riding scientist
Quoted: 6200 Post(s)
Liked 4,204 Times
Second, I think you mean a Kona Sutra. Kona and Surly are two different brands of bicycle. I suppose a Kona could become surly if it gets dunk and disorderly or that a Surly could go to Kona but, generally, they are two different brands.
Now to the meat. The number of spokes does matter but, far more importantly, the type of spoke matters much more. A stock wheel with 32 spokes is relatively weak because they use spokes that just aren't up to the load. For your weight, stock spokes and 36 spoke wheels would still be questionable. When the spokes on your wheel start to break...and they will...consider going to a stronger spoke. You can still use the 32 spokes...if you use stronger spokes. Take a look at this article and consider having the wheels rebuilt with a triple butted spoke when your spokes start to break. I build all my wheels with them and have for roughly 20 years. That's mountain bikes (which, like the Tacoma is lots of fun to ride fast if you ride it correctly), touring bikes, commuter bikes and go fast bikes. This bike, for example, uses 32 hole wheels that I wouldn't hesitate to put on a touring bike.
IMG_0736 by Stuart Black, on Flickr
In fact, the wheels it has replaced a set of low spoke count wheels that were supposed to be light but the bike lost 2 lbs with the new wheels and gained much stronger wheels in the process.
Bottom line: Triple butted spokes greatly increase the strength of the wheel...about a 50% increase...while not adding weight to the bike. They are slightly more expensive but less expensive then replacing wheels often.
Stuart Black
Stuart Black
Old and in the way.
IDK after you have ridden motorcycles for 30 years cars are like hammers... You can have a fast hammer, but its still a hammer. IMHO, YMMV and all relevant disclaimers.
As to the wheels. The bike came with wheels.. If they have issues I will do something, if they don't I will get them checked regularly or maybe learn how to true wheels myself. Until then Like I said I will just ride knowing that I am over the intended load limit and avowing curb hopping and potholes. I will keep you posted.
This is my other bike:
https://bikemagic.com/bikes/kona-2008-part-two.html
Kona Jake not Surly : I blame my advanced age and hardening mind for stuff like that.
TakingMyTime
Road Cycling
29
10-25-16 10:18 AM
vintagerando
99
10-01-15 12:30 PM
