Will you ever go disc?
#51
Sad thing is, cheaper bikes that normally come equipped with Tektro or own brand crappy rim brakes brakes will be the last to see an upgrade to hydro disc, even if they are the ones to benefit the most. For now road hydro disc is still somewhat expensive, but when the price come down and and bikes in the Sora and Tiagra segment move from rim brake to hydro disc, it will be a massive upgrade.
#52
Quoted: 18883 Post(s)
Liked 10,646 Times
Likes For Seattle Forrest:
#53
Liked 10,646 Times
Point is rim brakes will never go away completely, nobody is being "forced" to ride a bike with discs, and nobody will be. It's not something to fret over. Rim braked bikes will be like record players and vinyl, they'll still be around and some people will keep riding them.
#54
When I bought a new bike last year I found discs to be predominant on most bikes I was considering. After 45 years on Campy sidepulls it was a leap, especially after some early squeaky disc hiccups. Since I bought the bike, the Mid Atlantic area has seen countless rainy weekends. Normally I would have been hesitant to ride on wet roads, but disc brakes are a game changer and allowed me to salvage many weekends. The braking experience is confidence inspiring. No regrets here.
#55
Advocatus Diaboli
Quoted: 4729 Post(s)
Liked 1,531 Times
The idea that everything moves forward solely as a result of necessity is an incorrect premise. In fact, many types of priorities instigate change and many having nothing to do with necessity or improved function.
That's particularly true when it comes to cycling where "style" alone is a high enough priority in the introduction and acceptance of new ideas and change.
#56
Sophomore Member
Quoted: 1628 Post(s)
Liked 1,057 Times
"You may find yourself aboard a 12 speed carbon fiber bike with electronic shifting and disc brakes
You may find yourself in a beautiful house with a beautiful wife
You may ask yourself, well, how did I get here?"
Likes For Lemond1985:
#57
Perfect! This is not my beautiful wife, this is not my Di2 disc equipped bike...
#58
Advocatus Diaboli
Liked 1,531 Times
Do not be deceived
You don't have to wait for more instructions
No one makes a monkey out of me
#59
Quoted: 18397 Post(s)
Liked 15,494 Times
"Arm me with harmony."
#60
Quoted: 1591 Post(s)
Liked 1,017 Times
I ride a vintage bike with downtube friction shifters. In all probability, I'll continue with that until I'm too old and feeble to continue riding. So I'm really not seeing disc brakes in my future.
#61
I'm currently building a new bike with hydro discs, I've never used them before but have lost confidence with my rim-brakes as they've melted for me before and they're awful in the rain.
#63
Bikes: 2023 Canyon Aeoroad CF SL, 2015 Trek Emonda SLR, 2002 Litespeed Classic, 2005 Bianchi Pista, Some BikesDirect MTB I never ride.
Quoted: 647 Post(s)
Liked 136 Times
#64
Quoted: 741 Post(s)
Liked 412 Times
According to the local Trek Store, gone. I have only seen one rim brake Madone which was from a guy who wanted to build the bike up with Campy. I bet it is not a big seller.
#65
Quoted: 2952 Post(s)
Liked 3,106 Times
Heavier, less aero, requires a heavier fork, more expensive, and uglier. But other than that, sure great.
Likes For caloso:
#66
I've had a Trek Domane SLDisc 5 for almost a year now. My wife has the next model up. Already I"ve have had to fiddle with brake adjustments more than I've had to do with any previous bikes with rim brakes. To be honest with myself, I simply do not notice superior braking power with discs. I've never had a problem with rim brakes, so the discs are overkill for me. The only advantage to me is that the discs allow for wider tires, and I definitely like that. My bike has 32s, which I much prefer to narrower tires, but as far as stopping is concerned, the differences are lost on me. I prefer simple over complicated, so in the long run I prefer rim brakes. Why couldn't manufacturers come up with a rim brake that allowed for wider tire? I'm sure such a thing is possible. I prefer minimum maintenance on my bikes, and hydraulic brakes are a move away from that.
#67
Liked 10,646 Times
#68
I am potato.
Quoted: 1783 Post(s)
Liked 1,622 Times
Will I ever go disc? Yes.
After a bout of super lame 160mm rotors & OEM garbage Tektro, I was ready to swear them off forever. But then I upgraded to 180mm rotors & I could see a glimpse of promise to the whole idea. So I then upgraded to Avid BB7's calipers. Then again to TRP Spyres calipers. Then finally to 180mm RT99 XTR Icetech rotors.
OMFG! That's what "stopping" is all about.
Currently, I'm getting a 26 inch wheel travel bike built with a 180mm Icetech rotor in front, 180mm Rohloff proprietary rotor in the rear & TRP Spyre calipers all the way around. Being S&S coupled sort of dictates cable operated, but at a nominal weight of 300 pounds of person, camping gear + bike, I see no problem going down 20% logging road grades or mountain passes indefinitely & keeping it all at a safe speed.
The second biggest benefit (for us all weather riders) is not needing to buy rims every 2 years. Dynamo's & Rohloffs get expensive being laced into new hoops when a disk swap is <$100
Likes For base2:
#69
Liked 10,646 Times
#70
I love new tech. Carbon is great. Clipless, electronic shifting and brifters too.
I absolutely will buy a road bike with discs when it meets the following criteria:
1. The disc setup, including the frame and fork is lighter than an equivalent level rim brake setup. I make it a point of buying new stuff only if it is lighter than my previous. Par is now 15.5 pounds; I love lightweight gear.
2. The rear stay spacing is no greater than 130mm. I don't want heel strikes or having to increase my crankset q-factor. Cranksets are too wide and biomechanically inefficient already.
3. No PITA thru-axles. First thing I do when I get a new fork is grind the #@^±»!! lawyer tabs off, so the quick release operates like it should. You flip the lever, and the wheel drops out.
Otherwise I wholeheartedly welcome disks.
#71
I've had shimanos and formulas. And they all developed some weird problem within a year. The formulas needed bleeding every year and the shimanos had multiple problems. I basically got tired of it and went cable instead. Its very easy to fix and troubleshoot cable discs. I run bb7 on all bikes.
#72
Will I go disc?
Yesterday. Picked up my SLR7 Disc. I have no opinion on them yet, but inasmuch as we live in an area with a ton of hills, I'll be interested in seeing if I notice the differences.
[insert clever quote here]
#73
Heft On Wheels
Quoted: 887 Post(s)
Liked 560 Times
I have disc on my mtb and I have them on the cross bike...that is as a much disc as I really want. Road bike has rim, I like rim on the road.
So no, not on a road bike!
Likes For sdmc530:
#74
Quoted: 4791 Post(s)
Liked 3,918 Times
Ben
#75
I am potato.
Liked 1,622 Times
I guess you may right; Losening a nut 2-3 full turns is just so much more troublesome than dental work.
Broken teeth are so under-rated. I recommend everyone get them. I have 2. They're wonderful.
(Serious. I do have broken teeth from a bike accident.)
