$1270 to save 1/2 lb at the rim?
#77
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 735 Times
I wouldn't spend that much on a whole wheelset, so I'm not an opinion to consider.
That being said,
Will you want to ride the bike more?
--Would you feel better when you do ride it?
Then perhaps it'll be worth it. Certainly would be purty, and sometimes that's worth the $.
That being said,
-Tim-
#78
Quoted: 4717 Post(s)
Liked 1,882 Times
I did a FG conversion with an old CF frameset, and the bike came in close to 14 pounds(and it was nearly all spare parts).
#79
I thought the whole 'rotational weight' thing was a myth and it's been busted years ago. I'm too lazy right now to dig up the information.
No I would not spend that much purely for weight reduction. At least I try not to.
#80
staring at the mountains
Bikes: Obed GVR, Fairdale Goodship, Salsa Timberjack 29
Quoted: 394 Post(s)
Liked 197 Times
so it's a (potentially) net $200 upgrade?
Why are you asking again?
#82
- Soli Deo Gloria -
Liked 735 Times
I'll bet that thing flies. It looks like so much fun.
No, a bit over $800 for the wheels with an expected $200 recoup from selling the old wheels so $600-ish net. Sorry if I was unclear.
The Euro is going up so I ordered the hubs today.
-Tim-
#84
1/2 as far in 2x the time
Bikes: Yes, Please.
Quoted: 499 Post(s)
Liked 285 Times
This is not so. 31 mph is a slightly downhill race or even TT pace... Aerodynamics being the limiting factor, 62 mph was a relatively rare accomplishment without drafting motorized vehicles, but "fine" is a fine word to describe the feeling of security, riding a good racing bike with trued wheels and well glued tires on good road. Perhaps carbon's reputation for instantaneous unexpected failure contributes to fear for some of high speeds on a bike. Tubular blow-outs were/are not remotely common events, and especially on well-known roads, going as fast as possible down hills was always part of the fun.
#85
Quoted: 18883 Post(s)
Liked 10,644 Times
I haven't done 61 mph. If Strava is to be believed I've hit about 55 mph coming down from Barlow Pass. Garmin says high 40s, Strava likes to reimagine your data. I passed a campground and two kids were looking at me like bikes don't normally go that fast. Felt fine. Great even.
#86
bike whisperer
Quoted: 1520 Post(s)
Liked 716 Times
But with CX-Rays, that same amount of metal is in a lovely little blade (they are just beautifully made) that not only shows any twist, but allows you to easily prevent it. And the forging process to create them makes them the strongest spoke on the market, even though they're almost floppy out of the box.
They are the bee's knees, and worth every cent.
Sheldon Brown's bike info ~~~ Park Tools repair help
Half-step triple, using double gear ~~~ 6400 STI rebuild walkthrough ~~~ Want 8/9/10s @126mm OLD? OCR. ~~~ Shimano cassette body overhaul ~~~ Ergopower Escape wear repair ~~~ PSA: drivetrain wear
List of US/Canada bike co-ops ~~~ Global list
#87
bike whisperer
Liked 716 Times
I used to hang onto trucks, without a (compulsory in my country) helmet. But now that I have a few grey hairs, once I get up to 60-70kmh, I can't help thinking how bad I'd get messed up if I was to come off for some reason. At 100, I reckon I'd be packing my dacks. And I'm not an anxious type; I see people cowering in unfounded fear everywhere.
#88
- Soli Deo Gloria -
Liked 735 Times
I haven't built any wheels with Lasers (I think the thinnest round spokes I've used were 1.6), and I'd be a bit nervous about trying to with low spoke counts and high tension... I'd want to do tape flags, and have the wheel securely fixed in a robust stand in order to push it side to side to detension spokes as they're adjusted. 1.5mm is stuff-all to resist twisting.
I appreciate your recommendation. "Worth every cent" is spiritual food for me.
Do CX-Rays require a different spoke hole at the hub or can they be fitted to the same holes that would accept Lasers?
-Tim-
#90
Liked 1,882 Times
I had to build the rear wheel with a White Industries ENO eccentric hub, but the rest of it was just spare parts.
Likes For TimothyH:
#92
Liked 1,882 Times
Keep in mind that this is a "fixed gear road bike." It has a fixed gear drivetrain but is ridden on the road like any road bike. The rear hub will not have a freewheel but even so, track hubs and track components in general are typically not light. Anyway, I'm going to save about 1/2 pound and cost will be a little over $800.
Light Bicycle 35 mm deep carbon rims have already been ordered.
Hubs will be Mack Superlight front and rear. The 8mm bolt-on is slick. They come with an aluminum track lockring but this will be replaced with Dura Ace steel for street use
-Tim-
FREEWHEELS ? White Industries
#93
- Soli Deo Gloria -
Liked 735 Times
BTW, there's no reason that you couldn't use a freewheel on those hubs if you wan't to. White Industries makes one that's top notch.
Thanks for that.
-Tim-
#96
Bikes: 1979 Raleigh Team 753
Quoted: 3374 Post(s)
Liked 371 Times
Would you spend $1270 for new wheels to save 223 grams (7.87 oz) if all the weight savings were at the rim?
The new wheels would be exactly the same as the existing wheels except for much lighter rims. Assume for now that the hubs, spokes, nipples, tires and tubes are already as light as they can go.
The bike flies and I've no need for new wheels. This would be a luxury purchase.
Wheels would be built by ProWheelBuilder and come with 2 year warranty and lifetime 25% off crash replacement. I could probably sell the existing wheels for a couple hundred.
This is on a sub 16 lb bike.
-Tim-
-Tim-
