tires for trek 7200
tires for trek 7200
Old 04-18-10, 05:59 PM
mcleodja
tires for trek 7200
currently have specialized crossroads 700x38 on my trek 7200 but thinking about 700x32. Does this sound like too much of a change or would this work or does any one know what would be the best fit for this bike?
mcleodja is offline
Old 04-18-10, 08:02 PM
RonH
Life is good
RonH's Avatar
Bikes: 2018 Lynskey Helix Pro
Quoted: 522 Post(s)
Liked 10 Times in 10 Posts
It shouldn't be a problem unless the rims you have are very wide.
See this --> https://www.sheldonbrown.com/rim-sizing.html
and this (scroll down to width consideration) --> https://www.sheldonbrown.com/tire_sizing.html
RonH is offline
Old 04-18-10, 09:48 PM
dynodonn
dynodonn's Avatar
Quoted: 1268 Post(s)
Liked 78 Times in 67 Posts
If you are using the stock rims, 32s should be just fine. If you are using a kick stand, you may have to shorten it a little to keep the bike from standing too upright with the smaller tires.
dynodonn is offline
Old 04-18-10, 10:10 PM
Velo Dog
FWIW, I've found that the recommended size range for most rims is VERY conservative. Depending on what I plan to do, I've used tires from 23mm to 41mm on several sets of wheels with no problems ever. Only issue has been whether the tires will fit the frame and fork.
Velo Dog is offline
Old 04-19-10, 07:38 AM
Wanderer
aka Phil Jungels
Wanderer's Avatar
Bikes: 08 Specialized Crosstrail Sport, 05 Sirrus Comp
Quoted: 202 Post(s)
Liked 86 Times in 60 Posts
I'm running a 35 on the front of my Crosstrail, with a 40 on the rear. OEM was 45.
If you still have one good tire, try swapping to a 32 on the front to see how you like it.
You will get better, and quicker, handling - and still retain the nice ride with the fatter one on the back.
I like the mix real well, and am running Schwalbe Marathon Supremes.
I just might try a 32-35 mix, when I run out of these sizes.
With either of those sizes, the Planet Bike Hardcore Hybrid Fenders, will fit perfectly.
Wanderer is offline
Old 04-19-10, 09:37 AM
mcleodja
thanks guys
mcleodja is offline
Old 04-19-10, 01:10 PM
bkaapcke
Quoted: 118 Post(s)
Liked 50 Times in 25 Posts
One of my ride buddies has a 7200 and ran 32's for a season. No problem except he found the ride to be too harsh. This year he went back to the stock 35's. bk
bkaapcke is offline
SidewalkTerror
Singlespeed & Fixed Gear
7
11-30-17 10:36 PM
GoodRoadRunner
Road Cycling
10
09-21-17 08:33 PM
Lrdchaos
Road Cycling
3
04-29-17 08:28 PM
Axiom
2
03-12-12 06:19 PM
max power
Road Cycling
6
01-24-11 10:19 PM
