Please help me narrow down what kind of bike I want
Hello, I'm new(ish) here, and I'm looking to buy a decent bike.
I'm 6'3" and nearly 290lbs. I need to start getting some exercise, and I can't seem to get back into jogging like I used to. I don't look to put 500 miles a year on it or anything, just some joy riding and for my hobbies and to get a little more active. I also don't know how to size a bike for myself.
I'm an amateur radio operator and I also like to fish, so I'd like to have something that does moderately well off-road to explore for my hobbies, as well as on the road.
I currently have a Walmart Hybrid bike, had a road bike like 3 decades ago, and as a kid had a small mountain bike. I can't stand having 21 gears like my current bike has. I know that's pretty much standard, but no matter how hard I work at it, I can't smoothly transition gears. I would love to have like a 3 speed or something, but I know that's not likely to happen.
My price range is around $450, so I guess I'm looking for a low end bike, and I don't mind working on things or slowly upgrading things on it over time. I would also prefer new, but not completely opposed to used.
My time frame I'm looking at is most likely after all this virus stuff blows over.
I think that's about it. I know that's a lot of constraints, but maybe you all can help me or talk me into some other options.
Thanks
Thanks
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
Why not this?
https://www.bikesdirect.com/products/...brake-mtb.html
There are videos on the partial assembly you'll have to do. Delivered to your home. 21" size for you.
The remaining $50 can be spent on accessories. First a rear rack to help you transport your fishing gear. After that, a frame mounted pump, tire levers, a spare tube, and sunscreen.
Quoted: 1572 Post(s)
Liked 643 Times
There are a plethora of bike styles that are all variations on a theme. Picking the one that suites you. best is a decision you will have to make for yourself.
The first task is to find a bike shop guy who really wants to talk with you. Look for the old guy or even better, his wife. Most times I think you'll find they're more willing to take the time to discuss the various styles of bikes and how they might best fit where and how you picture yourself using your new bike.
Once you do that, Choose the style bike you think will suit you best find a price point you can live with and you'll never go wrong. The biggest trick is finding the right sales person.
Thanks for the quick response. I'll add that to the list and compare with any other suggestions. I like the looks of that one so far.
Liked 643 Times
How old are they? In the interest of full disclosure, I may be showing a little bit of age bias.
If I had to guess, they are in their late 30's or 40s. I know one is the son of an avid bicyclist(when his hip and knee will allow) that is in his 60's I think and helps promote the shop as well. They do screen printing in the basement of the shop as well. I believe they've been in business for a long time.
WALSTIB
Save up to 60% off new Hybrid Bicycles | Adventure Hybrid 29er Bikes Shimano Nexus 8 Speed Bikes Elite Adventure Sport Trail
Like our bike guru Mr gretz says bikes direct. $50 over budject this sweet 8 speed. May even haul alligator gars
Quoted: 7653 Post(s)
Liked 3,479 Times
2020 Motobecane 529HT 29er Mountain Bikes (https://www.bikesdirect.com/products/...ntainbikes.htm)
Looks a like a solid low-budget MTB for someone who wants fat tires, wants to be able to haul a load off-road, and who isn’t too worried about competition riding.
This is a 24-speed, but that doesn’t matter. Likely you could leave it in the small or middle ring and just shift the rear—just ease up on your pedaling pressure for a stroke and the chain will move well enough.
22 chain ring and 32-tooth cog---you won’t have much trouble on hills (says the man who can barely climb his driveway. )
100 mm fork would be overkill, but given your heft (pretty near my own) you will be able to set it up sort of soft and cushiony and still have enough spring to keep from bottoming out.
Since it is a hard-tail, you can get a rear rack and some cheap panniers and a trunk bag (or a big duffel bag, bungeed across the top of the panniers) and carry more gear than you would ever need for fishing unless you were also camping---and you could still make that work.
Not saying this bike is your best bet---but it should do what you need it to.
I might go with a rigid frame myself—but I don’t know.
You will need to forge a good relationship with a local shop anyway, unless you like doing mechanical work …. And maybe they will turn out to be really good people and worth knowing in their own right.
Well let me run this by you all as well. Seeing as I have the Walmart bike and it's still in decent shape, would it be in my better intrest to put some time and a little money into that bike to try make it better for a while? It's a Schwinn Avenue Hybrid that I got about 10-11 years ago. It has some shimano parts and is in mostly decent shape, though I'm sure it needs some grease and a little wrenching.
Quoted: 590 Post(s)
Liked 445 Times
500 miles per year is ~10 miles per week, or ~5 minutes per day. Shoot for 5,000 miles per year.
Bikes: 2012 Salsa Casseroll, 2009 Kona Blast
Quoted: 1031 Post(s)
Liked 208 Times
Likes For MRT2:
Liked 3,479 Times
if the Schwinn runs and has no major flaws, get it tuned up and ride it. For as little as you plan to ride, it should be fine.
If you are planning to ride ten miles per week out to the fishing hole at a lazy pace, the Schwinn should meet your needs. even if you went three times as often, if you weren't going over drops and slamming into obstacles, the Schwinn should be fine. You will have to keep an eye on the wheels because of your mass---speaking from knowledge, if you let a couple spokes get loose, the rest will start popping and snapping and all sorts of ugly things, but if you check them every few rides, you can probably keep the wheels round and straight for quite a while.
Yo have to decide how much you really want to ride, and what kind of riding you want to do. Maybe you will find riding more fun than jogging (your knees and feet sure will) and you will decide you deserve a new bike more suited to your needs ... or maybe the Schwinn will last for several more years. Maybe you will save the Schwinn for fishing and get a more road-oriented bike for general riding .... or maybe you will take up jogging again, I don't know.
Bottom line, if the Schwinn isn't broke, you don't need a new bike right away.
Thank you everyone for the help. I'll get the old Schwinn tuned up a little, Check out the bikes you all showed me on bikesdirect, and give a call to the LBS here. You've all given me some stuff to think about and it's looking like Hybrid or Mountain bike is the direction I need to steer.
As you are 6'3", I'm guessing the Walmart Schwinn is too small for you as Walmart typically sells one size fits all. Read about measuring a bicycle's frame size and let us know it's size. Wrong size bike = replace.
You'll likely looking for a 22-23" (58-60cm) size bike.
