Rear wheel wobble
RespectIsEverything
Rear wheel wobble
Wobble so hard that the disc brake crashes into the calliper and makes this terrible sound. I heard the screws on the drop out could be bad, but that's not it. Heard the rotor could be bent, hear the rim could be bent... Bike wheel isn't trued, ball bearings worn down due to wobble. Dunno
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
Too many variables, not enough info. Take it to a bike shop and have the hub, rim, rotor, and spokes looked at.
Likes For Rolla:
Quoted: 18424 Post(s)
Liked 15,580 Times
Sounds like negative rim stretch.
Quoted: 1074 Post(s)
Liked 295 Times
It kinda-sorta sounds like you’re talking about the screws found on some bikes with horizontal dropouts. But those just about never have disc brakes.
Sure, that can happen. Usually doesn’t take much. A bend bad enough to make a really bad sound should be readily visible.
that certainly can happen too. But there’s no realistic way for the condition of the rim to influence the condition of the brake rotor.
Worn bbs can certainly contribute to bearing play. But the usual culprit is water etc getting into the bearing and attacking the bbs. A ”wobble”causing noticeable bearing wear is hugely unlikely.
Likes For Bimmer69:
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Jesus, some of the posts on here...you have no idea what the OP is trying to do or find out. C'mon people, at least try to use 4th grade grammar and post something that makes sense. It's like a sizable percentage of the members here never made it to middle school.
And of course this should be in GD, but should have been posted in 'bicycle mechanics'.
Quoted: 523 Post(s)
Liked 230 Times
Broken axle?
Have you checked for a broken axle? It happens. It will introduce a really bad wobble. The only way to be sure is to remove the bolts that hold the wheel to the frame or open the quick release and remove the wheel. If the axle is broken it will fall out in two pieces. It could be that the only thing keeping the wheel on the bike is the quick release or axle nuts.
Quoted: 4227 Post(s)
Liked 2,488 Times
Why don't you do a little bit of investigating yourself and see if you can find the problem ??....If you don't have time or if you lack enthusiasm for tinkering with bikes, then take it to a bike shop..
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
Hub related. Not rim or spokes. But they might have their own problems.
Quoted: 6196 Post(s)
Liked 4,811 Times
There are all sorts of possibilities that might be happening. I wouldn't completely eliminate rim and spokes, but more than a few spokes would have to be too loose and others over tensioned or the rim actually bent for that to be an issue.
Broken axle, loose cones, improper installation of most any of the involved components and etc.
More info about what your bike is and maybe a pic or two would help.
Posting in the mechanics sub-forum might have kept this thread for going downhill so fast.
Do you live near a bike shop? Doesn't cost you anything at most to just take it in and get their opinion of what the issue is. Though some of the larger high falutin bike shops might not let you near a mechanic. Most of the smaller ones are owned and run by the mechanic.
And most probably won't charge an arm and a leg to fix it. Unless there is damage that requires replacement of expensive parts.
Quoted: 9656 Post(s)
Liked 6,366 Times
Liked 15,580 Times
Likes For indyfabz:
Quoted: 969 Post(s)
Liked 1,631 Times
Or take it to a bike shop and hope you can afford to pay them to do it and after you pay them that they do... Do It!
Note: I have great sympathy for those Bike Shops and employees that are trying to keep thier head above water in a drowning pool. I have no sympathy for Bike Dealerships more intrested in financing than service.
Quoted: 365 Post(s)
Liked 419 Times
If the rotor rubs, it's either the rotor itself or the hub. The hub could have loose bearings or a bent/broken axle. Most commonly, especially with low-end mechanical disc brakes, the rotor becomes out-of-true due to hard braking. It can be trued with your thumbs, but there is a tool that makes things easier.
Now if your RIM has a wobble, that is a separate issue and should also be dealt with.
Quoted: 506 Post(s)
Liked 639 Times
Homey
Quoted: 2427 Post(s)
Liked 1,407 Times
And if not, remember,not everyone is as perfect as you.
Expired Member
Quoted: 3674 Post(s)
Liked 5,441 Times
"Thanks for trying to make people feel crappy."
Well heck, just trying to add some humor, salvage an unimaginative troll thread. I'll delete.
