In Need of Practical On-Bike Hydration Advice
Suburban Dad
Bikes: 2019 Trek Domane SL5 Disc, 2021 Giant Talon 2, 2012 Trek 7.1 FX, 2005 Trek Fuel 70, 2003 Trek 4500
Quoted: 17 Post(s)
Liked 33 Times
So... I found myself on the floor writhing and shouting in sheer agony Saturday morning as my legs continually cramped beyond any charley horse I have ever experienced before in my entire life. It went away after my son-in-law mixed up several glasses of his post-workout drink mix for me. It was so bad that my leg muscles are still sore today (Monday) from the cramping on Saturday. This occurred after a 52 mile ride in the hot, humid, Houston, TX sun (my single longest ride ever).
I obviously let my hydration and electrolytes get too low even though I drank over 70 oz. of regular water from my Camelback during the ride supplemented by some Propel drink mix in my water bottle.
I have always been a heavy perspirer all my life and being a large guy now only exacerbates the issue. I would welcome any recommendations regarding a high quality drink mix and/or practical strategies for hydration and electrolyte replenishment during my rides.
Likes For boozergut:
Bikes: Kona Dew, Gary Fisher Paragon, Salsa Campeon
Quoted: 120 Post(s)
Liked 128 Times
As far as strategies, I use the larger 20 ounce insulated bottles combined with a camelbak if its hot enough. I dont add hydration products to the camelbak as that quickly ends up in feeding the funk. I dose the waterbottles and then keep a few extra packets or tubes of the powder in a small bag to add at refill stops. Dont mess around with dehydration as a fellow big man.
don't try this at home.
Quoted: 974 Post(s)
Liked 512 Times
I sometimes get strong leg cramps later in the day after a big ride. It's overworking the muscles, not electrolytes. Occasionally, the cramp is strong enough to be sore for a couple of days. But it stops by itself after a few minutes of agony, no drink mix to cure it.
Electrolytes seem to work for some cyclists, not for others. Cramps must have more than one cause.
It's easy to get behind hydration. I've seen comments that if you are thirsty, you waited too long!
Likes For rm -rf:
Quoted: 2604 Post(s)
Liked 1,933 Times
You're going to have to keep riding and trying different things to find out what works for you.
True, overexertion beyond what you've trained for can cause cramps. But I suspect the fact your cramps went away after drinking (presumably) electrolyte mix is an indication you were low on salt, water, or both.
Some concrete suggestions:
1. Drink a big glass of water before you start. Make sure you're drinking every 15 minutes or so on the road.
2. Find electrolytes that work for you. Concur with the suggestion to put them in a water bottle. FWIW, Heed works OK for me, Nuun used to but upsets my stomach now. Somewhat concentrated lemonade with a hefty pinch of salt in a bottle, drinking 3-4 swallows of that along with 3-4 swallows of water at every drink, usually does the trick for me.
3. If you run low on the road, see if a gas station or convenience store has V-8. It may taste like something your dad or grandmother would drink, but it's one of the best ways to get a concentrated dose of salt in you. Wash it down with plain water.
Likes For pdlamb:
Bikes: 1996 Trek 970 ZX Single Track 2x11
Quoted: 614 Post(s)
Liked 565 Times
70-90oz across ~3+ hours of riding in hot conditions, particularly if known to be a heavy sweater -- sounds like it wouldn't be sufficient fluids, to me.
Back in the day, I used to run distances quite hard, often in hot trail conditions, often for several hours. Proper hydration was critical, as with any other hard activity. Almost never did supplement (with electrolytes) on average hard runs, back then, even if a ~2hr route. But fluid intake was something else.
I used to do about 16oz every 15-20mins. Of course, if running, water weight gets tough to carry much (in packs/bottles), so stopping every once in awhile is vital. Assuming well-hydrated prior to a hard distance run, at 16oz every 15mins that'd be a half gallon (64oz) every hour. If a 2hr intense run, that could easily require 1gal of water for the 2hr stint. On a bike, I'd generally not push nearly as hard, but still.
My suggestion based on what you've described would be: either carry another 50% water with you on the bike (a larger Camelbak plus another 1-2 big bottles), else stop halfway in order to recharge your water stores; and add a suitable electrolytes mixture to your water. It's still a guess as to whether the cramps were due to fluids and/or electrolytes, but it sounds like it, given how it rapidly cleared up with the post-workout fluids.
I suspect that's likely to eliminate the cramping.
Likes For Clyde1820:
Quoted: 3241 Post(s)
Liked 2,512 Times
Carry a cable lock on your rides. That makes every place with a bathroom/fluids on your routes a SAG.
However, as some have said, cramps are as much about muscle overexertion as about electrolytes/hydration. Been doing endurance sports for around 15 years now. There is no magic process that will eliminate cramps. You just learn to cope better. Wait till you do multisport if that's on your future horizon. Some muscles will cramp in the water, some more on the bike and continue on the run. You learn to live with it. At the end of a marathon, I basically have to lie still on the ground or sit in a chair for around an hour with no movement. Movement will cause severe/painful spasms in places below the waist.
Likes For seypat:
Lance Legweak
Gatorade, or similar, mixed with water, 50/50. Get the largest insulated bottles you can find. I fill mine up with ice cubes then Gatorade and top off with water. If it’s a really warm day I get a small plastic bottle, fill with Gatorade and freeze. Carry that in my back pocket. When the two water bottles are empty I put in Gatorade from the small bottle and fill up. That gives me three whole bottles of water/Gatorade. Just know where you can get water on your ride so you can fill up.
Also, check out a product called Sport Legs. One of the few ergogenic aids I found that actually works. Helps reduce leg cramps from lactic acid buildup.
Bikes: Trek Domane
Liked 5 Times
More water!
2 things ... I usually drink about 40 oz of water an hour when it's that hot. For your ride i would have drank about 120 oz. Also, the day before the ride, prehydrate. So when you start your ride, your body is already fully hydrated.
Usually when i plan longer rides i make sure there are places to refill my water bottles along the way. Parks, bathrooms, convenience stores. If those aren't options you can load up and bring a ton of water, or stash some along the ride. Finally, carry some dry Gatorade mixes. You can add that to a water bottle or two, to increase your electrolytes.
I find I really drink a lot on rides, if going by what I read others do. That said, I use camelbak packs, and if it's going to be long, I freeze a bottle or two depending on bike capacity to refill the pack. I'm short, and have always hated reaching to grab and replace bottles on the move. As far as what I fill with, I don't like all the sugary sports drinks, and found that LMNT works for me, with one flavor I've come to like. I mix up at home, and usually throw a couple of packets in a pocket for more if needed.
Likes For exercion:
I used to get the same issues. I switched to drinking HEED several years ago and have not had any issues since then. I carry small ziploc bags of mix on longer rides so that when I stop to refill my bottles I can mix up more drink.
Likes For chadtrent:
Liked 5 Times
Thought I'd chime in! I typically only drink carb mix like Skratch/Infinit, I hate eating while riding throw in about 70g/carb in each of my bottles... If I'm worried about electrolytes, I throw in F2C electrolytes which are a lot cheaper than nuun and are flavourless.
Likes For bjamat:
Liked 5 Times
Oh i also carry 2 bottles on the bike and one in the jersey... I try to go through just over 1 bottle per hour because I'm a sweater..... I also try to plan a gas station or cafe stop in the ride for anything over 3 hours so I can get more water.
Likes For bjamat:
I ride with a hydrapak. Being older fishing for a frame mounted bottle is getting iffy. I don't use additives. You may need them. I don't.
Likes For igorgroks:
Quoted: 1074 Post(s)
Liked 295 Times
I use a Camelbak-style bladder in a frame bag. Then I use one of those self-retracting yo-yo things as for key cards and similar to hold the nozzle end of the tube to the bar. Makes drinking on the go as easy as grab, bite, slurp, spit. Ease-of-use has considerably improved my hydration.
I’ve tried using two bladders, one water and one concentrated sports drink heavy on the electrolytes, but it would require a redesign of the frame bag.
I also dose up on magnesium supplements the day before long rides.
Likes For dabac:
Cafe Racer
Too much OR not enough potassium can cause painful cramping. Eat a banana or drink a cup of black coffee.
Likes For CyFan:
Quoted: 3242 Post(s)
Liked 2,089 Times
Thought;
- Dial back the distance on hot humid days. Maybe do 30 not 50
- Stop more often at 7-11's and such and re-hydrate
- For me, 50 miles would be about 4 + hrs., I would want 128+ ounces of fluids for that. I cannot carry that even with a Camelback so would need to replenish at stores.
- Drink tomato juice after the ride and eat bananas. I recently read this here, the potassium really helped me eliminate cramping.
Likes For Steve B.:
Liked 2,089 Times
I understand. 2 tricks is to locate the bike in the window so you can keep an eye on it, also loop your helmet thru the spokes on the front wheel and thru the downtube, this prevents somebody from rolling away with your bike unless they dis-attach the helmet, which takes time.
Bikes: Too many to list
Quoted: 1765 Post(s)
Liked 1,124 Times
ive been using a lot of pickle juice lately. In theory just concentrated salt water, but i like the taste better
Ive purchased a few of the small vials at the bike shops and refill them with my own when used up -- i just keep a couple of those in my camelbak pockets
Likes For DMC707:
Bikes: Masi, Giant TCR, Eisentraut (retired), Jamis Aurora Elite, Zullo, Cannondale, 84 & 93 Stumpjumpers, Waterford, Tern D8, Bianchi, Gunner Roadie, Serotta, Serotta Duette, was gifted a Diamond Back
Quoted: 305 Post(s)
Liked 2,038 Times
I have cramps when sleeping or waking up in the morning. I seems to be caused by the exertion than the loss of electrolytes. But it helps for me to drink a Powerade before bed, it adds potassium and helps with the cramps. When I ride outside I tend to drink two bottles of water or sports drink for a 2 hour ride. I have tried the pickle juice too, I get a large jar of whole pickles and eat a couple of pickles each day and when I am done I use the pickle juice.
Likes For cyclist2000:
Not lost wanderer.
Quoted: 886 Post(s)
Liked 1,000 Times
Bananas, grapes, and or oranges.
Peanut butter crackers, or cheese.cheese.
Cashews, almonds, pecans, and walnuts.
Hard boiled eggs or small boiled potatoes with butter and salt.
Eat more, drink enough.
Drinking too much can make you internally drowned.
Eating both salty and sugar gives your digestive system something to use with the water.
Cambodia bikes, Bridgestone SRAM 2 speed, 2012 Fuji Stratos...
Cramps, been getting them all my life in my feet, especially at night. My uncle also and what helped him is mustard and IB PROFAIN. 1 in the morning and at night (though not good for recovery after rides) and that has helped a lot. Mustard, I eat whole grain and not the bright yellow stuff. Pickle juice some love, not for me.
Stop drinking plain water, do not buy Gatorade or other sugar waters. Tablets aren't a bad option. Apple cider vinegar or Himalayan Sea salt your water. change the PH level will hydrate you better than just plain water (Dr. Tommy John.) Camps are most likely a salt issue, could be potassium but without salt the body won't processes the potassium efficiently. Eat fruits high in water as well, apple, watermelon, etc...
I still haven't found a cure for cramps while swimming distance. For biking, hiking and running, salted water, and eating mustard has done wonders.
Likes For GMoser85:
Quoted: 18424 Post(s)
Liked 15,580 Times
Likes For indyfabz:
