Spokes stuck!
Spokes stuck!
I'm trying to re-dish a wheel from an old '88 Schwinn. A few of the spokes are stuck and will not loosen. Any tips for fixing this without stripping the end of the spoke?
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Lubricate them...what else can you do?
Really Old Senior Member
I keep hypodermic needles/syringes to apply a small drop of penetrating oil to old spoke nipples.
Do about 4-5 on the bottom (gravity is good), let it sit a minute, rotate 4-5 spokes & repeat.
If spokes are severely frozen, I just peel off the old nipple with a vise grip and install a new, lubed nipple.
Quoted: 1438 Post(s)
Liked 1,092 Times
Get one of the good (Park Tool is one) spoke wrenches which grips 4 corners/3 sides of the spoke and is the correct size; a good fit is critical to give you the best chance of breaking the spoke loose without rounding off the corners. AFTER a good soak in penetrating oil, Kano Kroil is the best PB Blaster second.
Likes For dsbrantjr:
Thanks all! Unfortunately in my haste, I already accidentally rounded (stripped) a few of the nipples. Fix for this? Do I need to remove the spoke entirely and install a new nipple?
Quoted: 5793 Post(s)
Liked 2,585 Times
NO,
Assuming you can loosen them, there's no need to remove spokes to replace nipples. Of course, if they're truly frozen and won't turn, cutting the spokes the only option.
Likes For FBinNY:
A vise grip pliers with "sharp" teeth will cut and "unwrap" a frozen nipple with ease.
Likes For Bill Kapaun:
Droid on a mission
Quoted: 317 Post(s)
Liked 280 Times
PB Blaster in a spray bottle is always handy to have around
The OP's not necessarily down to that last resort. If the OP can get some penetrating oil into the threaded joint to lubricate and loosen the seized threads, as Bill Kapaun noted previously he can still use a pair of locking pliers (e.g., Vice-Grips) to remove the stripped nipples. Doing that will be a bit of a pain, but it will preserve the spokes. (He'll of course have to replace the mangled nipples.)
That's what I'd try before cutting the spokes, anyway.
Likes For Hondo6:
Quoted: 1074 Post(s)
Liked 295 Times
Plenty of options.
penetrating lube from the hub side.
Penetrating lube from the tire side.
Heat. Soldering iron for the careful approach. Cigarette lighter - position wheel flat for this. MAPP torch if you want some danger.
Shock therapy, ie hit it. Rig something up to act as an anvil, then hammer away. If it doesn’t break free, odds are good it’ll simply break enough to be removeable from the tire side. File or grind one side out, add more lube, then turn from the tire side. Split it with some pliers. Brass is kind of brittle, so it’s entirely doable w/o damage to the spoke.
Likes For ign1te:
Bikes: lots
Liked 2,932 Times
Bikes: lots
Liked 2,932 Times
Ok 'pal', whatever you say. I should never have questioned someone with you obvious level of technical expertise. I'm concerned this doesn't sound snippy, that would be terrible.
Liked 2,585 Times
I've been away from here for 5 years or so. It's comforting to see that some things don't change.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3890 Post(s)
Liked 6,488 Times
Quoted: 1143 Post(s)
Liked 1,753 Times
Does a hairdryer even get warm enough to melt grease into treads?
Quoted: 15 Post(s)
Liked 10 Times
You know for a guy with the word wrench right in your username you were zero help with my brake problem, a tad condescending I may add.
