Mounting tires on older nonhooked alloy rims
Bikes: 1974 Falcon Olympic ,1982 Trek 710(both all Reynolds 531), 1974 Raleigh Sports, the'Keep Portland Weird'Montgomery Ward Open Road 10sp with basement sourced modern parts, 1989 TREK 400, 1980s Nishiki mixte, 1981 VINER Special Professional,Rockhopper
Quoted: 13 Post(s)
Liked 11 Times
I recently was gifted an early 1970s Gitane with Weinmann 27x1 1/4 straight wall (nonhooked) alloy rims. It was riding ok at my usual 100PSI until a much heavier friend took a ride... and of course the rear tire blew off the rim. I now know that these older nonhooked rims should not be inflated to modern PSIs. I remounted the like new Gatorskin it came with and only inflated it to the Forums advised under 70PSI. After I mounted the tire (wheel not yet back on the bike) and inflated to just 65PSI , I saw in faint letter lettering on the sidewall 'mount only on hooked rims'. My question: will the tire stay on at that lower PSI or do I need to buy compatible tires? If I need other tires, inexpensive ones which will seat on these rims recommendations?
Many thanks
Michael
Many thanks
Michael
Quoted: 1088 Post(s)
Liked 1,205 Times
Wire bead (they also come in folding, but I specifically recommend the wire bead) Panaracer Pasela tires come in 27" sizes, and they ride very well at 70-75psi. I used to have them on my daily rider with hookless Super Champion rims. They're usually pretty inexpensive.
Quoted: 4513 Post(s)
Liked 6,389 Times
I have Pasela's on my big Paramount with Weimann's, they only tolerate about 45psi before they want to squirm off.
Quoted: 1074 Post(s)
Liked 295 Times
A rarely used, but functional option is to fit 700C tubulars to 630mm ETRTO rims. Depending on rim trough profile, you may need to add double sided sticky tape to keep the tire from sliding.
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
Were the Gatorskin tires folding- or wire-beaded???
Some early 1970's Weinmann rims could barely handle 70-75psi reliably even using wire-bead tires, but this was more a problem of quality control of the rim's diameter as it was about it's basic hookless shape.
Many bikes with hookless 27" rims were reliable at 90+psi (with tires from the 1970's having a rated pressure that high).
I rode on about 90psi for years on my old bikes having hookless rims!
