Alfine 11 SG-700 Best practises?
Quoted: 8 Post(s)
I have an NOS alfine 11 SG-700 i.e. the older version. Looking for recommendations from those who have successfully managed to use it trouble-free for many years
what should i keep a check for to avoid troubles?
How often should i change the oil?
Is there any other oil that you have tried which works?
Does everyone get an oil leak? How to keep it in check?
Anything else?
Thank you for your help.
(I understand there is loooong thread elsewhere but i am looking for more updated responses)
Anything else?
Senior member
Quoted: 943 Post(s)
Liked 658 Times
Anything else?
Anything else?
I serviced one recently that the owner had used ATF instead of the Shimano oil. I don’t believe that the ATF did any damage to the hub, but it was obviously incompatible with the drive side cap as it had swollen to the point that the threads no longer engaged the hub and all the oil had leaked out.
I have tested ATF in Alfine 8 speed hubs but the bearings in those hubs are greased which forms a partial barrier to oil webpage.
The 11 speed bearings are oil bath so the cap is fully exposed.
I have observed swelling of the cap on the 8 speed hubs as well but to a lesser degree.
My observations and tests have led me to conclude that there are good reasons to stick with the OEM oil.
Others have used gear lube and their results may differ.
Likes For Dan Burkhart:
Quoted: 5793 Post(s)
Liked 2,585 Times
Consider Dan an expert on these and take his advice to heart.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Bikes: '09 Felt F55, '84 Masi Cran Criterium, (2)'86 Schwinn Pelotons, '86 Look Equippe Hinault, '09 Globe Live 3 (dogtaxi), '94 Greg Lemond, '99 GT Pulse Kinesis
Quoted: 389 Post(s)
Liked 270 Times
Maybe I'm a wuss, but I believe in sticking with the manufacturer's recommendations and products. The Shimano oil change kit and a can of oil (which will last you forever-ever-ever) are cheap enough. Never had any leaks, never had any problems, though I don't ride off-road or in rainy conditions much. Two of these hubs on two bikes, probably ten thousand miles between the two of them. Try to change the oil every two years, but I've been late a few times with no problems. I also take them for a ten-mile+ rode to "heat up the oil" which has been my motorcycle tradition for decades, to good effect. The used oil still drains clear out of the hub and I've never seen any shavings or grit.
I have a Jtek bar-end shifter on one of them, which is AWESOME, but the shifts are lightly indexed, so it's possible to do a "half-shift" when you're in a hurry, which could possibly damage the gear teeth.
I love riding this bike, and once you've adjusted to ensuring you're not between gears, it's so sweet.
Senior member
Quoted: 943 Post(s)
Liked 658 Times
Maybe I'm a wuss, but I believe in sticking with the manufacturer's recommendations and products. The Shimano oil change kit and a can of oil (which will last you forever-ever-ever) are cheap enough. Never had any leaks, never had any problems, though I don't ride off-road or in rainy conditions much. Two of these hubs on two bikes, probably ten thousand miles between the two of them. Try to change the oil every two years, but I've been late a few times with no problems. The used oil still drains clear out of the hub and I've never seen any shavings or grit.
Quoted: 389 Post(s)
Liked 270 Times
I say this with absolutely no sarcasm, but I marvel at minds like yours. I've watched at least a half-dozen Youtube videos (some of them twice) very closely,. I've also opened cleaned, and re-oiled my Alfine-8 hubs a few times. I've torn-down and rebuilt entire motorcycles. Yet these hubs are still black-magic to my puny non-engineering brain. I also never passed calculus. Is calculus required? Because I'm thinking calculus might be involved with the planetary gears and such in there.
The planetary gears are not complex themselves on a 3-speed, but when you get to hubs like a Rohloff 14, the drive-paths can be very complex and difficult to keep straight for even us engineers with extraordinary 3D spatial-relations skills. But those specializing in such things, get better at it with time. Modern Computer Aided Design (CAD) with solid modeling, including the ability to different color parts, instantly add or remove parts from an assembly, and actually produce an animation of all the parts in motion, helps a lot (and produces great youtube videos!).
Likes For Duragrouch:
Senior member
Quoted: 943 Post(s)
Liked 658 Times
Palmer
Quoted: 1671 Post(s)
Liked 1,826 Times
And to think, all William Reilly had back in 1901 was a piece of paper and a pencil.
Likes For tcs:
Palmer
Liked 1,826 Times
Bikes: Litespeed Firenze, Spot Acme, Specialzed S Works Pro Race, Davidson Stiletto, Colnago Superissimo
Quoted: 133 Post(s)
Liked 302 Times
The most important oil change is the first one and should definitely be done on schedule.
IDK about ATM, but synth gear oil is a popular substitute for the Shimano stuff--Royal Purple and Red Line are popular.
My issues have been leaking seals, some of which are replaceable and others, not. My one bike with the 11-sp hub has perhaps 20k mi and I've gone through three, due to seal leaks. Shop serviced, not DIY.
Quoted: 980 Post(s)
Liked 582 Times
I've used Royal Purple 75w-140 in my Alfine 11 for around 10,000 miles with no problems. I used the Shimano oil for the first change; a kit with the necessary syringe and tube came with enough for the flush and fill. As far as I could tell, the only real differences were color and price. I also use this oil for dipping my Nexus gears once a year.
Likes For sweeks:
https://forum.cyclinguk.org/viewtopic.php?t=64432
60 pages there, many older posts so relevant to your older hub.
I'm running valvoline 75w-90 gl5 full synthetic in a newer hub, about 1 year old with 2 k miles.
I've drilled and tapped the hub for a second hole about 90° away from the original to allow for easier drainage.
I used a brass bolt for one of the plugs and drilled it with a 3mm bit, then epoxied 3mm round magnets into the hole to catch any ferrous debris, so far it has only accumulated very tiny filings that almost feel like fuzz.
So far leakage hasn't been terrible, but I think I'm going to replace the right hand dust cap next time I change the oil.
Quoted: 8 Post(s)
Thank you all for your guidance
Unfortunately, after posting in this forum, I tried several retailers where I live and none have the OEM oil and importing it would be quite expensive. I think I'll sell this hub and move back to a derailleur drivetrain or something simpler to maintain like the Nexus8.
Just another thing to reinforce my view that IGHs are more expensive to maintain. Don't need maintenance as often, but critical to do, and lube needs to be correct (I had thought not previously, but this thread and others have convinced me, better stay with recommended lube).
Palmer
Liked 1,826 Times
*And Sturmey even defines readily available commercial equivalents!
Palmer
Liked 1,826 Times
Quoted: 8 Post(s)
Yeah, I would suspect that (what I've heard) Alfine 11 has roller clutches and not pawls, the lube would be special. Not something you would find at typical retailers, but one would think that a bike repair shop that does IGHs would sell some, but perhaps not, they might only buy in bulk for their own use.
Quoted: 8 Post(s)
There's one BF user who has also used royal purple exclusively on his Alfine 11 and had no problems. But there aren't many other voices..
In the pictures on our various IGH pages you can see how we lubricate hubs. The gear teeth and ball bearings get a load of CRC Sta-Lube Blue Boat Trailer Wheel Bearing Grease (product code SL3125). The roller bearings, pawls and the rest of the parts get coated in Phil Wood Tenacious Oil. The grease on the bearings helps keep the oil inside. It also acts as a barrier to water intrusion by filling all the spaces. Do not use heavy grease on the rollers or the hub may slip. Cold climate users may want to use only oil or a lighter grease with a low operating temperature such as Buzzy's Slick Honey or Dumonde Tech Freehub Grease. We have had reports of success using Lucas Heavy Duty 80W-90 Gear Oil (It is good down to -36 degrees C). You may also use Rohloff Speedhub Oil or Shimano SG-700 Oil. Note that all 3 oils are for sealed hubs like the Alfine 11 and will leak faster out of lesser sealed hubs. Dumonde Tech also makes a suitable sealed hub oil.
Quoted: 8 Post(s)
Thanks for sharing! I have been to Aaron's informative site - however I don't live in the US so can't avail of his services.
He mentions Lucas Heavy Duty 80W-90 Gear Oil in the same line as the Shimano and Rohloff oil, so perhaps there is an alternative. However, on his shimano IGH specific page, he writes "Use only Shimano SG-S700 Oil in the Alfine 11 hubs. Other lubes may cause seal swelling or deterioration." and "The main seal should be replaced every oil change to prevent leaks." Perhaps too conservative but still can be a best practise. Anyway, too much work for me as compared to a derailleur-drivetrain
Don't live in the US? Well that's not what it says on your profile, dangit! But I assumed you don't live local to Seattle, even if in the US, it can cost a lot to ship wheels these days. But I figured the website may have good info you can just apply locally yourself.
