How important is frame size?
We went down to the LBS for a new MTB and brought a bike I know I like the feel of, my Trek Roscoe 6. Tried a few bikes Scott acent, Canondale trail SE and GT Avalanche Expert. Went with the expert. Didn't have a dropper post, but had the 1x12 I wanted a better fork (Rockshox Recon vs Suntours on the Canondale and the Rockshox Reba on the Scott) I figured for less money, the nicer fork was a plus, I think the other two had smaller cassettes too. But that may be level dependent and not a huge issue. Either way, they all seemed comparable and nothing night and day different. I was sent away with a med frame on the GT and I ride a Med on the Trek too. But on the GT webpage they say the Med is for a 5'8 to 5'11 person. I am not experienced enough to know what a "perfect" fit feels like. I can stand over the bike in flat shoes and just clear the top bar. They said they could try the small if I really felt it was too large but that it looked good. Riding it, it's so much better than my last 400 dollar bike that it's night and day. Huge step up. Should I really even think about Sm vs Med frame size and is this something that will matter more as I get more experience doing this? Thanks for the replies, over all, it's nice that both of us have upgraded!
You didn't mention how tall you are. Manufactures have different measurements with their frames. For example, I am a L or XL depending how the manufacture designs the frame.
To answer the question in the title, a frame being the correct size is the most important thing when selecting a bike. If you are between sizes, finding the correct size is something you need to figure out. Take both bikes on a 20-30 minute test ride (longer if possible) and pick which feels best.
Quoted: 3242 Post(s)
Liked 2,086 Times
If you are happy with the fit on your Trek, why not just measure reach of saddle to mid stem on the GT and match it or get really close ?
Quoted: 1400 Post(s)
Liked 1,883 Times
for off road riding - especially tight technical off road riding - the amount of standover clearance does not appear to be ideal
but I don't know your primary type of riding - and obviously have not seen you on the bike
how is the length ... top tube length ?
what is your height ?
Quoted: 967 Post(s)
Liked 1,631 Times
When I was at 300 pounds plus I rode a big heavy duty ChroMo 80's FUJI till I got my weight down. Called it my horse cause I had to jump on and off of it. The only reason I was able to do it was because of my years of experience ridding 70's road bikes.
My suggestion to you is not to get a bike that is too big for you. Especially if you don't have allot of experience ridding...
Likes For zandoval:
I picked up the same bike this spring. I’m 5’11” with a 31” inseam. Stand over height feels perfect but the reach feels a little cramped. Their sizing information is just a guide and not going to be perfect for everyone. Sounds like you got the right size.
And standing over the Trek Roscoe 6, the top tube comes up quicker and seems as close/closer. There's maybe a half inch difference if you sit them side by side, and the Trek is supposed to fit down to 5'4. I'm just not sure how to be sure since I'm an amateur. Trust the LBS who said I was good, or trust the "sizing guide" that says go for a small.
Quoted: 427 Post(s)
Liked 700 Times
Sizing "guides" are just that--a general guide, and are not correct for everyone. I had considered a hybrid once, and like the Trek FX line. Trek's sizing guide indicated a medium was the right size. Went to a dealer, medium was much too small, while a large was perfect. A guide might get you in the ballpark but it's no substitute for actually riding the bike. Didn't buy a hybrid-decided didn't really need one.
Likes For freeranger:
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
I suggest dropping the focus on standover. Sizing modern MTB bikes using standover is a bad idea, and nobody who understands modern MTB fit well would do so.
Go by the length of the reach and how it feels actually riding it.
Frame size for mtb IS very important, because getting the proper frame reach is very important. At least if you are going to be riding technical terrain. If the bike is for more casual riding or mostly paths and rail-trail stuff then you have more leeway to make adjustments with stems length and such.
At 5’6” you could be a med on some bikes and small on others.
If you do decide to make standover a deciding factor (which is a big mistake, IMO) then look for a model that has standover AND proper reach. Going down a size in a particular model just to get more standover can leave you with too small of a frame for the 99% of the time you are riding it rather than standing over it.
As far as whether to go with the shops rec or the manufacturer’s guide… depends on the shop. Did they have you ride the bike around the parking lot and see how you positioned yourself or did you just sit on it in the shop?
Try searching forums like MTBR (there is a Trek sub-forum there) to see how others sizes up on Roscoes.
Industry guy
There is no advantage to a bicycle to big for the rider, or one to much to small either.
A really long or really short stem affect steering and handling.
A super long seatpost or one jambed way is affect pedaling geometry.
A good fit is essential.
BTW, the top bar always wins!
rusty
rusty
Likes For 100bikes:
rusty
rusty
Bikes: Too many to list
Quoted: 1765 Post(s)
Liked 1,124 Times
I cant straddle the top tube on several dual suspension bikes i have had (and have )
Granted -- a dual suspension bike is a different animal, - but just throwing that out there for the folks that claim you need to have top tube clearance in all cases
Likes For DMC707:
Bikes: Soma Pescadero, Surly Pugsley, Salsa Fargo, Schwinn Klunker, Gravity SS 27.5, Monocog 29er
Quoted: 186 Post(s)
Liked 234 Times
Standover doesn't matter when riding. Proper sizing and fit is based on cockpit length.
Quoted: 883 Post(s)
Liked 823 Times
If you're comfortable, IMO it's settled. My wife, 5'5" but long legged for her height, rides a M Felt 29er better than any of her previous bikes. Standover may be over-valued since (normally) you don't put both feet on the ground simultaneously when stopping.
Likes For 2old:
Advanced Slacker
Liked 2,537 Times
To put standover into perspective for me:
I’ve been riding a new MTB since April. I have never checked the standover. And until I checked yesterday, I had no idea if I have any. Turns out i don’t.
I ride very technical terrain, and regularly need to bail or put a foot down. Never notice the standover.
Quoted: 186 Post(s)
Liked 234 Times
Advanced Slacker
Liked 2,537 Times
Whenever I dab a foot, I am also going to be leaning the bike in that direction, anyway. With the non-dabbing foot on the other pedal, you have a lot more clearance.
Also, in those times when I do go over due to not being able to plant a foot on the ground, it is the saddle - not the top tube - that is in my way.
Likes For Kapusta:
Steel is real
Bikes: 1992Giant Tourer,1992MeridaAlbon,1996Scapin,1998KonaKilaueua,1993Peugeot Prestige,1991RaleighTeamZ(to be upgraded),1998 Jamis Dragon,1992CTWallis(to be built),1998VettaTeam(to be built),1995Coppi(to be built),1993Grandis(to be built)
Quoted: 670 Post(s)
Liked 977 Times
A too tall or a too small frame can have bad consequences on your back or kness and on your position in the cockpit, also don't cut the steering pivot too much other wise it would impact your back badly. I always had 17.5 -18 inch sloping MTB frames. I always made sure before having my bikes assembled that the riding position would suit me.
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,995 Times
Fit is always important on any frame that you plan on riding. Standover not so much but actual fit on the bike is supremely important and really the most important because if they bike doesn't fit you and you aren't comfortable on it size wise you aren't going to ride it and enjoy it so why buy it.
Likes For n2t:
Quoted: 5224 Post(s)
Liked 3,584 Times
Liked 3,584 Times
Liked 3,584 Times
how do you bail
what is dabbing?
