DIY bag making
#76
Freewheel Medic
Quoted: 1453 Post(s)
Liked 2,196 Times
@rootboy, thanks! I do like the way this one turned out. I realize this "home brew" is not for everyone. But what else can be done with old tubular tires?
I'm tinkering in my head and will attempt to make a handle bar model using the support arms from a vintage Cannondale bag (single piece of round steel that loops over the stem and bars). The one downside is that even after the tire is taken apart, it still wants to curl inwards to form the "tube." I bought a yard of "Duck Cloth" that I can make into a liner and the bottom. I'll make the sides from the old tubular tires. Not certain about the top just yet.
My wife says I need to sketch this all out on graph paper first. I find it kind of fun to just eyeball it and move ahead. The only piece I needed to re-due on the small bag was the strap for the seat post. It was not at the correct position so I took it off and found the "sweet spot" for a good fit.
Bob
Bob
#77
Pedal to the medal
Some good looking ideas in here, that's for sure.
#78
Quoted: 1608 Post(s)
Liked 2,216 Times
@pastorbobnlnh - your tubular bags are fun! I applaud your development cycle and results! You are right, what do you do with spent tubulars? They use to be called sew-ups and you have redefined the term!
#79
Living the Dream
Bikes: 2015 AWOL Frameset with custom drivetrain, 20?? Windsor Tourist, 2010 Specialized Secteur
Quoted: 9 Post(s)
My wife has helped me make a few bags. Most turned out pretty handy.
The black bag was made specifically for the small rack. We bought the material from JoAnns.
The red bag was a cheap waterproof bag modded to fit under the saddle.
#81
Quoted: 472 Post(s)
Liked 1,028 Times
"some times the simplest solutions are the best'. I've made several of those and they are just right. I especially like the roll top feature.
#82
Freewheel Medic
Liked 2,196 Times
@stdlrf11 nice work by you and your wife! Well done.
Bob
Bob
#83
Quoted: 1951 Post(s)
Liked 2,013 Times
Bob,
do you have pictures of your tubbies bags open? I can't quite figure out the lid closure system. Very nice btw.
Jeff
Jeff
#84
Bikes: CAAD10 5, Trek 1000 Alpha Series
first attempt at a front pannier. i'm very happy with the results. a little testing and then i'll make another to go along with it. it's very satisfying to see my improvement from when i first started.
[img]https://scontent-iad3-1.xx.fbcdn.net/v/t1.0-9/13087577_10104544919846048_1166440960482729239_n.jpg?oh=639d8f89a7752f60e12bfbd6741d70f0&oe=57B54EDF[/img
#85
Unimatrix Zero
Quoted: 7 Post(s)
Cool to see the bags people have been working on. I've been making myself some bags - a QR handlebar bag and a set of panniers - out of x-pac. To cover costs I've also been making small tool rolls and selling them. Works out nicely and I can buy lots of fabric
#86
post pics when you're done! your other stuff was great. how are you selling your bags, online?
#87
Freewheel Medic
Liked 2,196 Times
Jeff, I'll try to post more pictures ASAP. Basically I'm using Velcro. I was not all that happy with the results of the "lids/doors" on bags #1 and #2 , so I tried something different on #3 , and liked the result much better.
Bag #1 uses a back flap stitched on at the top and secured with Velcro to the inside of the bag. This one was tough because the Continental Gatorskin tubular is very stiff. You can see how it wants to keep its shape in the bottom picture.
Bag #2 uses two flaps which are hinged with pieces of leather at the top and bottom. The then have Velcro attached so that they stay together when closed.
Bag #3 uses a door sort of like a shoe box lid that is stitched at the bottom of the rear of the bag. It has a strap attached to the top which Velcros to the back.
Bob
Bob
#88
What material do you use to hold your rolls together? I used nylon webbing but I think it would be better with something with some stretch
#90
Freewheel Medic
Liked 2,196 Times
@aquateen ^ well executed!
Bob
Bob
#92
Quoted: 472 Post(s)
Liked 1,028 Times
Well done. You're getting 'the wrinkles ironed out" nicely. Good choice using the roll top on the panniers. The simplest designs are the best.
#93
Could someone tell me what type of sewing machine you're using? Just a good quality traditional machine or something specifically for heavy duty sewing?
#94
Quoted: 556 Post(s)
Liked 132 Times
Nice work, Whatwolf!
That's an interesting question, Velocivixen. I can't really answer it as I don't use mine for making these kinds of things, yet. But I could.
But if you're looking to acquire something that will handle these heavy nylons and multiple layers, etc., I'd keep an eye out for an old Singer 201. A strong old workhorse machine with a "potted" (direct drive, not belt) motor.
And, furthermore, ignore nearly every ebay listing that says "heavy duty", or "leather" in it, to get ideas or research. ...as it is mostly all lies. Sellers on ebay know lots of people are looking for heavy duty, leather-capable machines. So, they talk them up as being heavy enough to sew leather. Some can. Light leathers. But they're not true heavy duty machines. Almost all of them are just "regular" sewing machines.
Rant over. I'd be curious to know what Whatwolf is using.
#95
Unimatrix Zero
Quoted: 7 Post(s)
#96
Quoted: 109 Post(s)
Note that the 600 series Singer and newer (from the mid 60's on) uses some plastic components in the drive train, not as good for heavy materials as the old Model 66 or 15's or the 300/400/500 series. I've made several amplifier covers with medium weight vinyl on my Model 66 and 503a machines.
One key is to use the proper needle for your material--leather needles and vinyl needles have different tips than general-purpose needles. Also set your thread tension properly for the thicker seams. I've found the old machines often have their thread tension mechanisms gummed up from old solidified lubricants, so they won't work properly until that little mechanism is properly (thoroughly) cleaned and oiled.
#97
As always, I love all your stuff Whatwolf. Any advice working with Xpac? Should I try not using pins with the fabric? I'm planning a few projects for later this summer.
For a sewing machine, I use an old Singer 201
#98
is just a real cool dude
Quoted: 32 Post(s)
Liked 34 Times
This is what I use. Super smooth and my wife has Bernina 240 that's a few years older. The swiss watch of sewing machines. I originally bought one of those dark grey Singer Heavy Duty machines off of Amazon but it was so bad I boxed it back up the same night and sent it back the next morning. Really erratic with it's stitching and sounded like a jackhammer. Just felt really cheap overall.
#100
Unimatrix Zero
Quoted: 7 Post(s)
Good. Yes, that's Helix. It was very foggy that day so you can't see Mt. Miguel in the background.
