Did I over buy with a Specialized Roubaix Sport?
Quoted: 8279 Post(s)
Liked 9,033 Times
Apparently so. I really am not sure I was guided in the right direction in the first place. Hence returning it and going a different direction. The more input I got, a lot of it from this forum, suggested maybe a different type of bike might be a better choice to get my feet wet in the cycling world. It seems enthusiasts LOVE the Roubaix however, and after a season or two maybe I will find then is a better time to revisit one.
Bikes: 2007 Bianchi Volpe
Quoted: 19 Post(s)
Walk away and sleep on it
Sorry but if you haven’t ridden in 10 years spending $2300 is too high a bike. In Power of Persuasion you learn the psychology of sales. So on a big purchase you should walk away and sleep on it. E.G. I called a bike shop for a test ride. The disc brakes weren’t set so when I test rode it no brakes. He told me ahead of time. Later I thought what the hell if the shop isn’t responsible enough to set the brakes for a test ride what else didn’t they do? I canceled the deal. In your case the next day if you still want the bike buy it. Take the impulse buy out of the equation.
Liked 9,033 Times
If having the nicer bike makes you happy, or makes you want to ride more, then why not?
Besides, have you seen bike prices lately?
Likes For big john:
Liked 9,033 Times
Quoted: 1581 Post(s)
Liked 1,189 Times
First: you absolutely did not 'overbuy' with the Roubaix you've returned, assuming always that the purchase would have been within your financial comfort zone. I'm with @big john, among others, on that point.
Second, and fwiw, the Cannondale Quick 1 is also a very nice bike, and not all that different: it is a flat-bar road bike, and has quite a bit in common with 'endurance' drop-bar road bikes like the Roubaix. Given your start-point, you'll be able to progress your cycling for quite a while on it, assuming it fits and is correctly fitted to you. At some point you might want a change; with experience, you'll know when.
Third, and most importantly, best of luck with the medical stuff. Ms. Badger has twice fought and beaten cancer (thyroid and later, breast). Her course of treatment for the latter sounds very much like the one you are facing: she's now six years clear.
Jedi Master
While I love the idea of riding a hybrid to stay in shape, the concept of a carbon hybrid makes no sense to me. What difference does a few pounds make on a bike that's designed to be ridden at a moderate pace? If I were buying a flat-bar road bike for personal fitness for myself or someone in my family, my budget would be $5-600.
Liked 1,189 Times
And btw, flat-bar road bikes are no more inherently "designed to be ridden at a moderate pace" than are their drop-bar cousins -- so-called 'endurance' or even 'gravel' bikes.
Jedi Master
Makes perfect sense to me, and to many, many cyclists who prefer flat to drop bars. I've just treated myself to one, to replace my aging carbon/aluminum one. If I could afford it, I wouldn't bat an eye at buying something like this (https://road.cc/content/review/21802...nowdon-paradox).
Liked 9,033 Times
Well I hope it works out for you, whatever bike you decide on. It's a great way to stay active. I've been riding as a recreational cyclist for more than 30 years and I still get excited about upcoming rides, still get the feeling of satisfaction even from solo rides around the neighborhood. And I have lots of friends made through cycling.
Likes For big john:
Liked 9,033 Times
The point of the carbon fiber frame is not to save "a few pounds" but to provide a smoother ride than aluminum. Carbon fiber frames can be manipulated to change the ride characteristics easier than aluminum. The weight difference would likely be less than 1 pound between a quality aluminum frame and a cf frame.
Likes For big john:
Bikes: 89 Paramount OS 84 Fuji Touring Series III New! 2013 Focus Izalco Ergoride
Quoted: 285 Post(s)
Liked 74 Times
My thought would be that a Roubaix Sport is not some exotic bike that only a select few can handle and appreciate. Could OP achieve stated goals on a cheaper bike? Sure. And if the bike is just going to sit in the garage then it's kind of expensive for that. But for a rider who spends most of the time on roads or MUPs with a little gravel that bike will work for them. As a sidewalk bike probably not worth the expense.
Of course if you are unsure what direction your cycling hobby will lead you, then it would make sense to me to limit the financial exposure until I figured that out.
I do agree that whatever direction OP heads, getting a bike that fits with saddle and pedals that you like is the first step to enjoyment.
scott s.
scott s.
Quoted: 590 Post(s)
Liked 445 Times
If you then add on top of that, the gas savings and "wear and tear" savings of not using your car if you also decide to bike-commute to work, this bike might actually start to make you some money. Ask you husband if he can say the same about his golf clubs, boat, tools, cameras, video games, musical instruments, etc...
Bikes: trek 720 multitrack hybred, 92 trek 2300, 2010 specialized roubaix, 2014 specialized roubaix
Quoted: 14 Post(s)
Liked 17 Times
in my opinion the 2019 roubaix will ride significantly smoother than any allow bike made.
the 2019 roubaix sport has a shock absorber built into the fork for 20MM of travel to absorb bumps without feeling them. the rear stays also flex over 10mm to absorb bumps. you can also upgrade it with a better seat post off the higher level bikes that also flexes so give additional cushion to smooth out the road. it is also designed to allow tires up to 32mm to smooth out the ride.
quote from a bike radar review. Overall, the Roubaix is one of the best ever endurance bikes, and though this Sport model is on the expensive side for the level of equipment, it does deliver the full-fat full-flavour Roubaix experience.
If comfort, closely followed by exciting handling, are at the top of your wishlist, then the Roubaix could be the bike for you.
full article ....https://www.bikeradar.com/reviews/bik...-sport-review/
Quoted: 822 Post(s)
Liked 1,960 Times
To the OP: Have you ever considered renting different types of bikes to narrow down what would best fit your needs?
A quick interweb search indicates you have several bike rental options in Portland.
Quoted: 19 Post(s)
Exactly
Liked 9,033 Times
Exactly. The user level and riding environments should dictate the purchase - not the salesman. In a perfect world know your gear inch range by looking at Sheldon Brown site. When in doubt start with a low model, get into your bike groove, learn, then buy a better bike. That way ya have a beater bike ya don’t have to worry about getting ripped off and a good bike ya have to watch. I did this with a GT mtn bike then a Bianchi Volpe 07 after reading Lords book on Adventure Cycle Touring. If I hadn’t read the book I wouldn’t have known about this model because most shops in SF Bay Area don’t have it on the floor.
Sometimes people buy "expensive" bikes and ride them and love them.
Likes For big john:
Quoted: 1020 Post(s)
Liked 463 Times
I don't see how you can make such a statement. Spend whatever you want, even if it's just for wall art. If you want a nice thing, (bike, watch, car, etc) and you can afford it, who cares how much it costs?
I own some very nice bikes. I ride them all. I am old, I am slow, I have diabetes and I have seven coronary stents (from previously not taking care of my health and my diabetes). But now every year I ride five to six thousand miles. On an average ride I ride 100km and put over 750 meters of climbing, sometimes more, and sometimes less.
I will not let my spouse, or anyone else, dictate to me what I should be doing to stay healthy. You shouldn’t either.
Even if I didn’t enjoy all the health benefits of riding, just the pleasure of riding my very nice bikes is enough benefit for me.
Could I get the same enjoyment and benefits out of riding other bikes? Probably. But riding my bikes puts me at a whole other level of joy.
To the OP, if you listen to the people who answered your post, the majority of us want you to be happy and healthy riding the bike that you want.
Have fun and please don’t let your spouse bring you down...your health, your happiness and your life are at stake.
Likes For eja_ bottecchia:
So I ordered the 2018 Cannondale Quick 1 Disc Womens in small. Brand new but an older model offered significant savings. The flat bars are supposed to be lower on the Quick 1 than the other Quick line up, but of course not to the level of drop bars. I’m wondering how many men here (and even women frankly) have ridden a drop bar bike while being fully weighted down by a G cup bra completely filled. I’m just guessing, but this possibly could have had something to do with how in the end I was more comfortable on a flat bar bike. But I really didn’t want to give up the 105 components, I enjoyed that on many of the bikes I test rode. After my breast cancer surgery I will lose a rather massive amount of breast size, and once I recover and get back to hitting the road every day again I might eventually consider a different type of bike, but I think this is a really good fit for where I am today.
I SO appreciate the wide variety of opinions offered here, thank you so much!
Best wishes on the cancer treatments. I have a couple of good friends and a mother in law who have all beat it and are healthy 5 and 15 years on. The improvements in diagnosis, treatment and outcomes from breast cancer have been amazing. Congratulations on trying out cycling as an exercise to combat the side effects of your treatment. Have fun with your riding, do some exploring, ride with friends (or make friends with people who ride, worked for me).
Quoted: 19 Post(s)
Jedi Master
I right now am looking for 30-60 minutes a night after work at a truly moderate pace. If I catch the bug and feel the need to hunker down and feel the wind in my face then I will revisit my original Roubaix purchase. I am going to go out on a limb here and guess that a lot of enthusiasts here aren’t still riding their first bike.
Liked 9,033 Times
Likes For big john:
