Go Back  Bike Forums > Bike Forums > Fitting Your Bike
Help with numb hands
Fitting Your Bike Are you confused about how you should fit a bike to your particular body dimensions? Have you been reading, found the terms Merxx or French Fit, and don’t know what you need? Every style of riding is different- in how you fit the bike to you, and the sizing of the bike itself. It’s more than just measuring your height, reach and inseam. With the help of Bike Fitting, you’ll be able to find the right fit for your frame size, style of riding, and your particular dimensions. Here ya’ go…..the location for everything fit related.
Old 09-11-19, 01:31 PM
hefeweizen
Quoted: 43 Post(s)
Liked 20 Times in 13 Posts
Long time ago I had a wrist injury. Just trying to find something that will help a little.
Bike is a Giant TCR. Fit is really good. I played with tire pressure, bar angle and have
the stem up. Numbness starts around 35 mile mark. Would like to get another 10-15
miles before this happens.
Would changing the stem length help?
How does going 10mm longer or shorter change things?
Thanks
hefeweizen is offline
Old 09-11-19, 01:43 PM
Clem von Jones
Quoted: 151 Post(s)
Liked 23 Times in 16 Posts
1. Shorter stem and corresponding increase of saddle setback to reduce weight on your hands.
2. Increase bar drop. Consider drastically lowering the bars. The lower you go the shorter the stem has to be to maintain the same reach. Use an online reach calculator. It's counter-intuitive but increasing bar drop can reduce weight on your hands by shifting more weight into your body core, spine, and legs.
3. Consider the possibility you're developing peripheral neuropathy as a pre-diabetic condition. Half the population is prediabetic, but fortunately it's easily reversible by changing to a low-carb diet. Symptoms of prediabetes and "metabolic syndrome" include hindered circulation in your legs and hands, feelings of coldness, numbness, feeling exhausted after eating meals especially a mid-afternoon crash, frequent urination, and weight gain. If these symptoms apply google metabolic syndrome and low-carb diet. Nip diabetes in the bud before it destroys you. It's easy to reverse.
4. It's also possible your stem is too short and inadequate reach causes back-pressure against your hands cutting off circulation, but that's a fairly obvious situation.
Clem von Jones is offline
Old 09-11-19, 02:09 PM
hefeweizen
Quoted: 43 Post(s)
Thanks.
I found a thread with the info I was looking for.
Old 09-11-19, 03:20 PM
philbob57
Quoted: 715 Post(s)
Liked 611 Times in 376 Posts
What thread was that (a link might help people who come after you, since this comes up every so often)?
Also, mild carpal tunnel syndrome is a possibility. That's based on my being diagnosed with moderate CTS with numbness after 10-15 miles.
philbob57 is offline
Old 09-11-19, 03:41 PM
hefeweizen
Quoted: 43 Post(s)
https://www.bikeforums.net/road-cycl...umb-hands.html
Old 09-11-19, 04:55 PM
oldtrekguy
Bikes: 1989 Trek 400 2009 Kona Jake the Snake 1993 Bianchi Forza
Quoted: 13 Post(s)
Liked 7 Times in 5 Posts
You might also check the positioning of your brifters, yo see if you are "breaking" your wrists. Do you arms flow naturally from your shoulders to the bars?
Padded gloves and/or padding under your bar tape can help.
Carbon handlebars can reduce harshness if your roads are not the best.
Practice frequently moving your hands to different positions. Top of bars to brifters to drops.
Try flexing your hands frequently.
Do you unconsciously have a tight "death grip" on the bars?
I went into my LBS this year and finally had them do a basic fit for me. The resulting fit is much better, and numbness is much less. It was a very worthwhile $40 exense.
oldtrekguy is offline
Old 09-18-19, 09:29 PM
Brian25
Bikes: Road, mountain and track bikes and tandems.
Quoted: 282 Post(s)
Liked 18 Times in 15 Posts
I have no idea if this helps: A downward tilted seat of 6mm/ 1/4", or more is a real hand killer.
Brian25 is offline
johngwheeler
Road Cycling
66
04-27-20 05:58 AM
Mithrandir
16
02-05-15 10:49 AM
F15Todd
9
02-14-11 06:57 PM
jcinnb
Bicycle Mechanics
21
09-08-10 11:28 PM
spwelton
General Cycling Discussion
10
07-13-10 05:42 PM
