Garmin Speed sensor 2 - cumulative distance?
Bikes: Custom built LHT & Troll
Quoted: 832 Post(s)
Liked 141 Times
Is there an app, a data field or a clever hack that will compute a running total of distance, ideally a counter that can be reset manually. I'd like to use this sensor as an odometer, the idea being to schedule maintenance.
The sensor itself has no memory it just counts and regularly sends that count to the head unit. If you have a Garmin cycling computer it should have the total distance under History / Totals. On my Edge 800 there are per bike odometers under settings / bike profiles menu. I don't know if the newer units without bike profiles still provide a breakdown. Strava also shows total distance for each bike if you have multiple bikes set up and set the bike for each activity.
Quoted: 871 Post(s)
Liked 725 Times
In Garmin Connect you can specify max distance for each piece of gear you assign to your rides. I don't think it alerts you, but you can see when you've exceeded the max in the app and on the website. I use it to gauge when I should clean and relube my chains, then once I'm done, I update the max distance.
Likes For surak:
Bikes: Trek Domane 4.3
Quoted: 193 Post(s)
Liked 50 Times
Strava also can track this info in settings for each bike and the components. Obviously requires uploading rides to Strava.
Quoted: 832 Post(s)
Liked 141 Times
Quoted: 18883 Post(s)
Liked 10,645 Times
When you pull up a (any) ride in the mobile app, you get a bar chart for each piece of gear used on that ride, and how close it is to its end of life.
You can get creative. Some of my friends are gear in Connect, I know how many miles I've hiked or ridden with different people, and more importantly I can get a list of everything I've done with that person, which helps in planning new adventures.
Quoted: 4221 Post(s)
Liked 1,322 Times
https://www.dcrainmaker.com/2019/04/...th-review.html
Or the same thing with a Cannondale label.
https://www.cannondale.com/en/USA/Pr...B-A6437F664351
Quoted: 832 Post(s)
Liked 141 Times
WRT DCRainmaker -- I've read his review (even commented on it, asking about sensor's memory). IIRC he doesn't describe the "gear trick" but rather says that he has custom soft.
I would suppose that cumulative distances by activity will be (if not already) a feature of GC. Useful to keep track of wear and tear. Hadn't realized that the "gear" feature was a good way to get the data. I didn't see any interest in associating a run with a pair of shoes, or a ride with a specific bike. Makes sense to me now.
Quoted: 871 Post(s)
Liked 725 Times
BTW, I found that there is a Garmin Connect setting that will email you when you go over the max distance set for a piece of gear. On the website, it's under Account Settings->Messages->Receive Connect Emails (toggle)->Gear->Max Distance Alerts.
