The Masi's dropout hanger is askew
Old 09-19-19, 07:24 PM
Cyclist753
Quoted: 97 Post(s)
Liked 106 Times in 66 Posts
Cyclist753 is offline
Old 09-22-19, 09:45 AM
tiger1964
tiger1964's Avatar
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 971 Post(s)
Liked 624 Times in 399 Posts
Well, early Saturday I went on a group ride that started and ended at the LBS; left the RD on the 4th cog, chattering away back there, and did the whole ride in 4th/inner and 4th/outer, and kept up (I usually ride alone, so it felt a bit strange). After the ride, the LBS was open for business, and they adjusted the hanger but I have not tested the results yet but it looks right.
RJ the bike hack shows you how to make a homemade tool.
https://youtu.be/sWdO4dnu18g
I need to do this, one of my other bikes might need this adjustment some day. One more reason I must buy a drill press, even if it's a small one; this alone, plus I was following the topic on polishing hub cones, would justify the expense.
Originally Posted by Chuckk
But using the Allen wrench method is only easy after the hanger has been adjusted carefully with an appropriately sized Crescent wrench closed on the hanger. Then, the long handle of the Allen displays any additional adjustment needed in SIX directions! After all, this is rocket medicine. ;-]
This would have been tempting! Only, however, with a "sacrificial" derailleur; otherwise, with my luck, I'd bend the Nuovo Record, and that's unacceptable.
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
tiger1964 is offline
Old 09-22-19, 10:01 AM
masi61
masi61's Avatar
Quoted: 1163 Post(s)
Liked 441 Times in 314 Posts
Based on the photo in post #3 , you were way out of spec. The fact that you are using a Nuovo Record friction rear derailleur means that by having the bike shop use their “DAG” (derailleur alignment gauge) tool, the clattering should now be silenced.
Where you would really appreciate the proper alignment if you decided to run a 7 speed indexed rear freewheel or cassette.
It it was very satisfying to me when I got my old Saint Tropez (1980’s Japanese 126mm steel frameset, think Centurion Dave Scott Ironman) aligned. I was able to run my rear Dura Ace 7400 seven speed Uniglide cassette wheel in super reliable index mode in my 3x7 conguration.
masi61 is offline
Old 09-22-19, 10:03 AM
unterhausen
Randomhead
Liked 3,684 Times in 2,508 Posts
I hadn't ridden one of my bikes for quite a while and decided to ride it on Friday. It became obvious that the hanger needed to be adjusted, so yesterday I adjusted it. Wouldn't shift into the biggest cog. I came to the conclusion is that the hanger was out of alignment the last time I adjusted the derailleur. The other interesting thing was that by eye, it sure looked like the hanger was bent in at the bottom. But when I measured it, it was actually bent in at the front and it was okay top to bottom. So much for doing this by eye without a gauge.
unterhausen is offline
Old 09-22-19, 11:39 AM
Chombi1
Chombi1's Avatar
Quoted: 1635 Post(s)
Liked 823 Times in 532 Posts
Mehh.... Don't overthink this one. Just put in a wheel, clamp down the skewer nice and tight to keep the dropout faces aligned and bend out the hanger as needed with a well padded (with electrical tape on the jaw faces), big enough adjustable wrench......
The steel the dropouts are made from is ductile enough to take the very little bit bending it looks like you need to do without cracking/breaking.....
Chombi1 is offline
Old 09-22-19, 01:06 PM
mpetry912
aged to perfection
mpetry912's Avatar
Quoted: 828 Post(s)
Liked 1,238 Times in 654 Posts
Using a crescent wrench is probably OK for small adjustments and you can eyeball it, lay a straightedge across the derailleur mounting flat. Close enough is good enough in most cases. I recommend against using an allen wrench in the derailleur bolt, you might bend the bolt.
you are only looking for an adjustment of a couple degrees, so go easy and check frequently. remember you're looking for parallelism in both the vertical and horizontal plane.
Mark Petry
Bainbridge Island, WA USA
mpetry912 is offline
BigPoser
Road Cycling
1
09-25-16 07:44 PM
Deontologist
Bicycle Mechanics
2
06-27-15 02:38 AM
Barrettscv
Bicycle Mechanics
8
05-17-15 11:39 AM
davlac89
Bicycle Mechanics
15
05-15-14 03:22 PM
TromboneAl
Bicycle Mechanics
13
05-04-11 10:30 AM
