Am I missing something? Help with correct stem diameter.
Quoted: 74 Post(s)
Liked 72 Times
Hey everyone,
I have an older fillet brazed Jamis Diablo (1988) that I'd like to rebuild from a rigid mountain bike into a dirt drop/commuter setup. It has a threaded, rigid fork, and Tioga headset.
I assumed that the quill stem post (where it inserts into the steerer tube) diameter should be 22.2mm. When I got out the dial caliper and measured at multiple points, I am getting exactly 22mm - if I open my caliper to 22.2mm I definitely have a minute amount of play between the caliper arms and the stem.
Is this typical? I know some older French bikes like my Motobecane take a 22mm stem, but was suprised to get a 22mm reading on a late 80s mountain bike. Do stems vary by a couple tenths of a mm typically?
I am getting measurements of 22.0mm stem diameter and 25.4mm clamp diameter for the stem (which makes sense).
I'd prefer to get a nice 22.2mm Nitto dirt drop stem with a 26mm clamp size to fit the Nitto Dirt Drop bars, but if I really have to go with 22mm options I'll be stuck with a threadless adapter.
Thanks for any insight!
Quoted: 74 Post(s)
Liked 72 Times
Unfortunately I don't have another 22.2 quill stem lying around I could try. The stem has no markings other than "Jamis" on the neck and the marks for the minimum insertion depth.
Quoted: 74 Post(s)
Liked 72 Times
^I hope this is the case - I had just repacked the bearings and correctly tensioned the headset and locknut when I decided to actually measure it before ordering parts last night. I couldn't get a good measurement of the ID of the fork steerer with the locknut installed as there is a rubber washer in there to prevent grime from getting in. I am unsure if the ID of the locknut is the exactly the same as the ID of the fork as well. I guess I'll have to pull it apart and check that next. I was wondering if maybe it was common for 22.2 quills to measure closer to 22.
Quoted: 4201 Post(s)
Liked 3,857 Times
Another possibility is that some early MtB bikes used the "American" (these days I should really say "USA") 21.15mm stem diameters, a left over from decades of US bikes and Wald/Schwinn like products. (Ross was another who used this spec). With a simple caliper the measuring is easily drifted a bit from the actual. This is why afterr the thousand of assumptions and the one measurement, a trial fit tells all. Andy
AndrewRStewart
AndrewRStewart
Liked 3,857 Times
Agreed. The cheap calipers tend to have a bunch of slop in their movement. Additionally don't forget that if you ask 10 people to measure something with the same device it's often that you end up with 11 different claims Andy
AndrewRStewart
AndrewRStewart
Quoted: 1324 Post(s)
Liked 927 Times
Cheers
Liked 3,857 Times
Yes so have I. But when one says they measured a steerer ID you have to hope that they know the difference between the steerer and the top nut Andy
AndrewRStewart
AndrewRStewart
Liked 927 Times
Cheers
Liked 3,857 Times
Yes, My reply was a tad tongue in cheek. I should have added more then a smile to indicate that. Andy
AndrewRStewart
AndrewRStewart
