Front Derailleur Not Shifting Properly (Friction Shifters)
So, I have been building up this old 1977 Bridgestone Kabuki SSD, new tires and inner tubes, new cables and housings, new handlebar tape, brake pads, and chain. With all of this I am also trying to get the drivetrain shifting smoothly, the rear derailleur shifts great, but in the front, it shifts down onto the smaller chainring just fine, but when I try to shift onto the larger ring, it just keeps slipping off and never manages to shift onto it. I have tried moving the height of the derailleur, rotating it, adjusting the stops, but I can't get it to shift onto that larger ring.
Also let me know if you have any suggestions for what I can do with these bikes. I have two, one is the SSD which I am working on building up to be a general good 10 speed, and then a Kabuki Superlight which I do not have plans for yet. (It needs a new front derailleur, tires and tubes, cables, and brakes to be in good condition.)
Quoted: 4802 Post(s)
Liked 3,922 Times
If the Kabuki is going to get a new derailleur anyway, why not just wait until you have it? FDs always have to be fussed with; that's their nature.
Is the cable and housing in good condition? If it is original, I'd go new on both. Is the shifter slipping? You might need to tighten the screw or take it apart, clean and lube it. (Do one side at a time so you have a reference on the order of the small parts. It matters. Also there will be two "washers" that are not to be greased. These are your friction plates.)
Ben
Ben
Ben
Ben
Quoted: 18409 Post(s)
Liked 15,520 Times
Tighten the cable?
Quoted: 2281 Post(s)
Liked 1,710 Times
Really, it shouldn't be that much different than any other shifter. The only difference is that there's no click stop or set position where the shifter needs to be in order to shift into the next gear. As someone explained it once, trigger/brifter shifters are like digital, and friction shifters are like analog. The trigger shifters and brifters go directly into the next gear with a click, but the friction shifters have to be eased up into the right spot to shift into the next gear. Usually you just feel it as the derailleur shifts.
But for all the simplicity of a friction shifter compared to any other shifter, the friction shifter ought to be easier to figure out. The worst problem I've ever had with a friction shifter is one which loses friction and doesn't stay in gear.
Old fart
Quoted: 3587 Post(s)
Liked 3,398 Times
Start by setting the outer cage plate of the front derailleur parallel to the large ring, and only a couple millimeters clearance above the teeth when shifting from the small ring. Still have problems? Use an adjustable wrench to bend the forward 5mm or so of the inner cage plate slightly inward. Make sure the cable is taut, shift quickly and smoothly, with a slight overshift (inner cage plate contacting the chain on the large ring), then trim back to clear the chain.
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
Move to bike mechanics?
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
Helix Lamont
Bicycle Mechanics
6
08-13-17 08:53 PM
davidonabike
Bicycle Mechanics
17
04-13-16 01:19 PM
InfiniteMiles
Bicycle Mechanics
11
01-13-15 07:22 AM
