Rear Derailleur Recommendations
Old 01-21-20, 12:03 PM
mjac
Quoted: 480 Post(s)
Liked 100 Times in 74 Posts
I cannot get my Rear Derailleur adjusted. I think it is just worn out. It has a lot of play at the swivel post and the cage doesn't look all that straight. I think I need a new Derailleur. What derailleurs do ya'll recommend that would be the best value for the money?...Thanks,mjac
mjac is offline
Old 01-21-20, 12:07 PM
jadocs
jadocs's Avatar
Quoted: 643 Post(s)
Liked 292 Times in 192 Posts
This begs for more information.
What do you mean by swivel post and rear derailleurs need to be compatible with the rest of your drivetrain.
jadocs is offline
Old 01-21-20, 12:19 PM
Mosyosalyangoz
Road Cyclist
Mosyosalyangoz's Avatar
Bikes: Corelli Kr 100
Quoted: 26 Post(s)
Liked 19 Times in 18 Posts
Road bike or mountain bike? If the road bike; shimano 105, if the mountain bike; Shimano XTR M9100.
Mosyosalyangoz is offline
Old 01-21-20, 12:21 PM
alcjphil
alcjphil's Avatar
Quoted: 843 Post(s)
Liked 214 Times in 143 Posts
Your rear derailleur has to be compatible with your shifter. Without knowing what shifter and rear derailleur you currently have it is impossible to recommend anything
alcjphil is offline
Old 01-21-20, 02:26 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds.
Quoted: 972 Post(s)
Liked 187 Times in 146 Posts
Anything you can steal.
Bill Kapaun is offline
Old 01-21-20, 06:54 PM
mjac
Quoted: 480 Post(s)
I was nowhere near descriptive enough. It is a 15 year old Schwinn Varsity Road Bike with the polished aluminum frame. It has a 14 - 28 Shimano Original Equipmet Replacement 7 speed free wheel, a 52T Shimano BioPace Chain Ring, a Shimano Acera Rapid Fire Shifter mounted horizontally on the aero bars and an old Shimano Journey Shifter that was bought used. By the swivel post I mean the axle that the derailleur swivels on forward and backward to take up the slack in the chain.
After I posted I looked on Amazon again and searched Acera since that is the type of shifter I have. I found an Acera Mountain Bike Derailleur RD-M360 that looked more rugged then the others Aceras. In the description it said it has quick,crisp shifts especially with the Acera Shifter. So I called up an Old School Bike Shop, since I talked to them about it earlier and had him order me one. It is supposed to be a step up from the Journey.
What are ya'lls thoughts...Thanks,mjac
mjac is offline
Old 01-21-20, 08:32 PM
Bill Kapaun
Quoted: 972 Post(s)
It's Tourney, which is totally suitable for 7 speed.
As you go up the food chain, DER's get narrower & more finicky as the number of cogs increase.
This can result in more chain rub etc. than the "cheaper" part.
The RD-M360 seems suitable though, since it appears to be listed as 7/8 speed.
Old 01-21-20, 08:36 PM
ramzilla
ramzilla's Avatar
Quoted: 549 Post(s)
Liked 137 Times in 115 Posts
I've been using Deore M591 RD's on all my old 7 speed bikes. It's listed for 9 speed drivetrains but, works fine as long as you're using a Shimano SIS or STI 7 speed shifter. And, you can usually find them for $25 to $30 on ebay.
ramzilla is offline
Old 01-21-20, 08:37 PM
Kapusta
Cyclochondriac
Quoted: 1306 Post(s)
Liked 457 Times in 283 Posts
Make sure your derailleur hangar is straight before you start buying new derailleurs.
Kapusta is offline
Old 01-21-20, 11:12 PM
mjac
Quoted: 480 Post(s)
The Tourney is suitable, I think it is just worn out. Too much play to precise. I picked the Acera because I have an Acera shifter and they say the Acera Derailleur works great with the Acera Shifter. It looks pretty ruggedly built. Don't know what the Bike Shop is going to charge me but Amazon has it for $25.
mjac is offline
Old 01-21-20, 11:16 PM
mjac
Quoted: 480 Post(s)
This Derailleur is listed for 7-8 so that should not be an issue.
mjac is offline
Bill Kapaun
Quoted: 972 Post(s)
I'm not sure who "they" are, but 9 speed & less mountain components all play pretty well together.
Old 01-21-20, 11:20 PM
mjac
Quoted: 480 Post(s)
I have been caught by that before. Nothing was working and the tab was bent over toward the freewheel. I have straightened that thing so many times I am amazed I didn't break it.
mjac is offline
Old 01-21-20, 11:48 PM
mjac
Quoted: 480 Post(s)
"They" is Shimano in their product description. They recommend using the Acera Derailleur with the Acera Shifter. That is why I got the Acera Derailleur because I have a Acera shifter. Looks like a pretty solid shifter.
mjac is offline
Old 01-22-20, 07:23 AM
Kapusta
Cyclochondriac
If your shifter is shimano 7 speed, any shimano 7, 8, or 9 speed MTB derailleur will work perfectly.
Kapusta is offline
Old 01-22-20, 08:09 PM
Retro Grouch
Retro Grouch's Avatar
Quoted: 1395 Post(s)
Liked 263 Times in 165 Posts
Need to know hanger or direct mount.
Retro Grouch is offline
Old 01-22-20, 08:26 PM
Kapusta
Cyclochondriac
His bike is 15 years old with a 7 speed Alivio RD. It has a hangar.
Any 9sp or lower Shadow RD will be backwards compatible with hangars.
Kapusta is offline
Old 01-23-20, 05:30 AM
mjac
Quoted: 480 Post(s)
Over the phone I told the Bike Shop I had a small aluminum tab coming down from the frame that the Derailleur mounted to. He called that a Direct Mount. He said the other is an Axle Mount where the Derailleur mounts directly to the axle. Is this correct. Ya'll keep talking about hanger and direct mount. I assume the hanger is the small aluminum tab and Direct Mount is to the axle. Seems different from what he said. He might have been just a clerk though not the mechanic. Which one is the correct terminology?
mjac is offline
Old 01-23-20, 09:49 AM
hokiefyd
hokiefyd's Avatar
Bikes: 2018 Giant Roam 2, 2018 Redline Zander, 1997 Trek 750, 1970 Peugeot UO-18
Quoted: 970 Post(s)
Liked 200 Times in 159 Posts
Direct mount is different from a derailleur hanger though your verbal description to your bike shop could apply to either one.
This website has a description of both.
It sounds like your bike shop is referring to your aluminum hanger as a "direct mount", and a direct mount to the axle as an "axle mount", which is not consistent with the rest of the bike industry.
hokiefyd is offline
Old 01-23-20, 11:37 AM
mjac
Quoted: 480 Post(s)
Exactly, the guy on the phone repeatedly referred to the derailleur mounted to the tab or hanger as Direct Mount and the derailleur mounted to the axle as axle mount. Even after I asked him because it did not make sense. The website also explained what backward mount is which I did not understand when it was mentioned in the forum.
mjac is offline
