BR1050 toe in?
BR1050 toe in?
Is there a way to adjust toe in on Shimano 105 BR1050 brake pads? Maybe I should check mechanics forum?
Quoted: 1163 Post(s)
Liked 442 Times
You could possibly also spec some aftermarket brake pads that have nested spherical washers to permit more angle adjustment of the pad. This might not work depending on what size tire you are running due to tight tolerance of the caliper arms.
Likes For masi61:
You can do it the old way and take a little adjustable wrench on the caliper arm to bend the slight toe in that you need.
Quoted: 1949 Post(s)
Liked 2,010 Times
Just take a file to the pad.
Liked 2,010 Times
I broke one brake arm years ago. I will never brake another one. Big time Campy mechanic once told me, "If there was supposed to be toe in, Campagnolo would have designed the brake with toe in." Those two things guide my toe in practice.
Likes For Classtime:
SE Wis
Quoted: 2746 Post(s)
Liked 3,390 Times
Or an old Park BT-3
https://bikerumor.com/2017/07/07/ask...hing-part-two/
Liked 2,010 Times
Maybe Campy makes a toe in tool. Or perhaps Shimano? 🤔
Quoted: 5888 Post(s)
Liked 3,471 Times
How about doing nothing? I have a set of these brakes. I installed new brake pads and the brakes work fine without squealing and without toeing in.
Liked 3,471 Times
Have you tried new brake pads? https://www.amazon.com/Shimano-Bicyc...503233&sr=8-10
Quoted: 767 Post(s)
Liked 1,898 Times
You might try these: https://www.jensonusa.com/Shimano-Ul...Brake-Shoe-Set
Toe-in adjustable, replaceable pads, and work very well. I use these kinds of shoes on three bikes, dual pivots and single. Excellent braking.
Quoted: 34 Post(s)
Liked 22 Times
We have been bending Shimano brake calipers with an adjustable wrench to get tow in since the 80's and have yet to break anything. We just use some thin cardboard to protect the finish on the caliper and don't go crazy. Not all rear brake bridges were installed perfectly straight and this was the only way to correct the problem as adjustable pads were not invented yet.
