dual use pedals. SPD and Look
I have a road bike and have been using the look style pedals that have the three whole attachment. I will be riding across Iowa this summer and bought Keen spd biking sandals for that ride. The SPD sandals will be better for walking my bike through the busy towns.
Is there a pedal that has SPD on one side and look on the other side? I would like to have the option to wear either shoes without having to switch out the pedals.
Quoted: 3242 Post(s)
Liked 2,091 Times
Why not just do the ride in the Keen's ?, or if not stiff enough (that can be an issue), just buy a pair of good SPD mt. shoes with a stiff sole and make that your single shoe for all condition ?, SPD works well for this.
Bikes: Bianchi San Mateo and a few others
Quoted: 634 Post(s)
Liked 13 Times
I really doubt you'll find a pedal with a Shimano attachment on one side and Look on the other. Two different companies on one pedal? Probably not gonna happen.
But you may be able to find an adapter similar to this one that'll let you put two-bolt SPD cleats on your three-bolt shoe. That way, you could use either pair of shoes with SPD pedals.
Bikes: 2011 Lynskey Sportive, 1988 Cannondale SM400
Quoted: 20 Post(s)
Schwinn used to make something called a Triple Link pedal for their Spinning bikes. It had SPD on one side and LOOK on the other, with an insert for the LOOK side that had a cage and strap for those who don't wear cycling shoes. They are really heavy though, since weight isn't a concern on a bike that goes nowhere.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Only the road shoes have made accommodations, to install both types of cleats... Need 2 pair of shoes..
SPD sl has pontoons along side the cleat.. 2 bolts,
Look/Time 3, surrounding the other,
so 5 places to screw on the different cleats..
then, .... a pedal wrench, to change the pedals, is not that big a deal.. between the 2 different pedals..
Quoted: 1110 Post(s)
Liked 1,204 Times
I have a set - they're a good idea but too thick if not used with the sole intended.
I agree with those who recomend getting a good quality pair of MTB shoes and just use SPD pedals. Bring the sandals too.
Quoted: 1188 Post(s)
Liked 1,154 Times
Pair of flip flops and a pair of Shimano MTB boots with SPDs and you've covered pretty well all the bases. Some thick socks and thin socks. Thick socks when it's cold and really hot to insulate your feet from extremes, thin ones for in between. Take off the cleats and put the base plates on and you can climb mountains.
