Enve's new, less expensive road wheels
Quoted: 18883 Post(s)
Liked 10,646 Times
Cycling News, Enve.
Looks like 45 or 65 mm, disc only, for 25 to 28 mm tires, tubeless. Same size front and back. Just popped up on my feed.
Likes For Seattle Forrest:
Bikes: SuperSix Evo | Revolt
Quoted: 733 Post(s)
Liked 815 Times
Tubeless only, no thanks. Better price point than their usual offerings at least, guess they're finally realizing that most people don't want to spend $3k+ on a set of wheels.
Quoted: 3361 Post(s)
Liked 3,638 Times
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
Where does it say that. I read "tubeless compatible," and also
Foundation wheels feature ENVE’s patent pending Wide Hookless Bead which is a design element at the leading edge of the rim that dissipates impact energy and reduces the likelihood of pinch flatting your tubed or tubeless tire.
Likes For Cyclist0108:
Occam's Rotor
Liked 2,331 Times
I think they are sort of responding to the idea that hookless rims are tubeless-incompatible. (Some tires are reported to blow off hookless rims fairly easily.)
Liked 10,646 Times
I have similar wheels that need tubeless tires but can be used with tubes.
There aren't as many tubeless road tires available as tubed ones. There's excellent tubeless rubber available. You can generally get excellent tubed ones at a lower price.
Tubeless at 28 mm has been working well for me.
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
Over on ST, their bike tech's review makes it sound like a righteous pain to set them up, and he's a big fan of tubeless. Hard pass from me.
https://www.slowtwitch.com/Products/...ries_7633.html
serious cyclist
Bikes: S1, R2, P2
Liked 3,679 Times
https://www.enve.com/en/lp/tire-compatibility/
Likes For Bah Humbug:
You even need tubes to set them up. And there's a specific compatibility list for tires:
I very much doubt I'll be interested in these wheels, but for other reasons. Them requiring a tube for initial installation, or requiring tires known to be tight enough and strong enough not to blow off due to no bead hook aren't going to be the reasons.
Likes For SethAZ:
serious cyclist
Bikes: S1, R2, P2
Liked 3,679 Times
Putting a tube in for initial setup is to ensure that the rim tape is properly smashed down onto the rim and well sealed. I've tried tubeless a couple of different times on my bike, and I put a tube in after installing rim tape for the exact same reason. Just look at rim tape that's just been applied, and look at the same type of rim tape in a wheel that's been ridden with tubes for a while and it's easy to see why.
My problems with current road tubeless mainly revolve around the issue of constantly having to replenish sealant due to the fact I live in Arizona and it's hot as hell here, so the sealant evaporates quite quickly, then eventually having to deal with all this dried and semi-coagulated sealant when I have to take the tire off. That, and the difficulty of removing and reinstalling uber-tight tubeless tires on the side of the road if a puncture or slice or something happens that can't be sealed by the sealant. Thankfully MTB tubeless is pretty easy in comparison.
I'm also still coming to terms with the idea of hookless rims. The explanations make sense to me, but I need some more time to adapt to the idea before I'd try a hookless rim.
Occam's Rotor
Liked 2,331 Times
This is worth reading: https://www.renehersecycles.com/enve...e-herse-tires/
Quoted: 20810 Post(s)
Liked 9,456 Times
And that doesn't even include roadside flats. Oy.
Likes For WhyFi:
Quoted: 4717 Post(s)
Liked 1,882 Times
Yeah, for road tubeless it's still a hassle.
Likes For noodle soup:
I'm not averse to trying again, having already tried twice. My next set of tires will be tubeless ready, so I may well just try running them tubeless and see how the experience goes. Are you willing to reveal what specific tires and sealant you're using?
My bikes live in the garage when I'm not riding, and my garage (everyone's garage, I'd assume) gets insanely hot here during the summer. My experience of dealing with dried sealant is based on two or three experiences of sitting in my garage for like an hour or two picking, peeling, rolling, etc. dried sealant off the inside of tubeless tires. If you haven't had to do that before consider yourself fortunate. It's always possible that different rubber compounds or finishes from different manufacturers deal with adhesion of evaporated sealant differently. I'm willing to change my opinions based on new evidence. I did quite enjoy the feel of the tubeless tires when I've tried them.
Liked 1,882 Times
1 tire was cut beyond repair on it's second day, but in the last 14k miles, that was the only issue. I still limped home on that tire(@ about 25psi), but the tire was toasted.
Quoted: 850 Post(s)
Liked 344 Times
Some observations:
- The hubs uses NTN bearings. Nice to see high quality bearings getting used.
- The spokes are CX sprint, which are stiffer but cheaper than the rays used in higher end wheels
- the profile looks a lot like that of the Light Bicycle falcon rims
- For a hookless rim, there is quite a delta between the inner width and outer width, which is probably good for aero and durability but not weight (hence the average weight). This is one advantage (imo) over cadex
- nobody has mentioned the tires they’re showcasing on the DNA bikes. Some rumors of a tire optimized for wide hookless rims from ENVE have been swirling for a bit. Those might be it. Very exciting, and I hope they’re not ultra fragile.
Likes For smashndash:
serious cyclist
Bikes: S1, R2, P2
Liked 3,679 Times
There are few roadside flats I've gotten that wouldn't have also killed tubeless. And latex is resilient enough that it's saved me from a few itself. But we've been down this road before.
Liked 9,456 Times
Then there's the question of... why? Why even unmount, clean and remount? Leave the tire on, check fluid levels and viscosity through the valve stem, run 'em until they're threadbare and then toss 'em. I have cleaned 'em out before on my road bike, in fits of boredom and OCD, but then I realized that it wasn't necessary with proper maintenance - I'm really just looking at two or three level checks/top-offs per the life of a tire and you shouldn't get that much accumulation in that period of time.
(I've done it on my gravel bike, but more because it doesn't get too many miles put on it and it'll sit for a for weeks (sometimes months) at a time, cultivating some big snot puddles in the process.)
Likes For WhyFi:
Liked 9,456 Times
"Killed" as in totaled the tire? Yeah, those are neither here nor there. If you're talking "killed" as in the tire was still structurally sound but the sealant wouldn't have held, those are exceptionally rare for me - I've experienced that once.
serious cyclist
Bikes: S1, R2, P2
Liked 3,679 Times
The best was still the 3" nail that went straight through AG's tire and rim bed.
Liked 10,646 Times
I've been on hookless rims for most of 3 years. (Still not riding much lately though.) I've never had a problem with burping or the tire staying attached to the rim. The opposite problem, it's a ***** to get the tires on and off. But that only needs to happen every couple thousand miles. I'm interested in how they or anything else performs while you're riding. So I put up with the difficulty. It seems like hookless is popular with carbon rim makers.
Never had the sealant dry up on me but it's cooler and more humid here.
These sound like a lot of wheel for half the money from a respected manufacturer. Lot of positives. Light Bicycle wheels are pretty well reputed around here (BF) for considerably less and name a strong case unless you're losing races by seconds though.
Occam's Rotor
Liked 2,331 Times
They look like a really good deal, although I don't know if I could bring myself to ride on skinny anorexic 28mm tires. Also I have QR.
Sunshine
Quoted: 10965 Post(s)
Liked 7,491 Times
Glad to see they have introduced a product to bring pricing down so enve is now available to the common man.***
...I'll continue to wonder what I'm missing, but not come close to be tempted to try to understand.
