Tires- Tube or tubeless?
Quoted: 6974 Post(s)
Liked 10,975 Times
Dried sealant is significantly lighter than fresh sealant.
You really shouldn't have any more than 60 grams of liquid sealant in a 28mm road tire. If you ride 5000 miles a year you'll likely only top off sealant twice before you get a new rear tire. Let's say 50 grams dried sealant and 60 grams liquid sealant in the tire after one year. Add the valve stem 7 grams. 117 grams tubeless, I run 80 gram tubes in my road tires, so 37 gram weight penalty at the end of one year in order to not have to change a tube for 90% of punctures. Pretty good trade off there.
I carry a spare tube whether riding tubeless or tubed. It's a wash on that account. On long solo centuries on a tubed bike, I'd carry a patch kit, two spare tubes and a spare tire.
An air compressor is handy for other things besides installing tubeless, might as well get one.
As you note, the dried sealant that I find inside my old tires is practically weightless -- as would be obvious to anyone with a moment's thought, since the main ingredients in sealant are liquid, and they evaporate.
rekmeyata , you should not post nonsense about things that you have not experienced and which you do not understand.
Likes For Koyote:
Habitual User
Quoted: 4957 Post(s)
Liked 8,100 Times
This is the only part of your post I disagree with. From my experiences with road, gravel, and MTB tubeless, the tires have definitely been harder to mount than I ever experienced with my bikes from 20-ish years ago. That said, I’ve accepted it as part of a system that I think is superior to tubed tires. Maybe our experiences have been different.
Liked 10,975 Times
Of the three or four different tubeless rim types I’ve used, and many different tires, I’ve only had one single tire that I could not mount by hand — even though I had mounted the other identical tire that I’d purchased at the same time.
Likes For Koyote:
Habitual User
Liked 8,100 Times
This doesn’t surprise me… After all, the difficulty of mounting any tire is in the way it interacts with any particular rim. Given the almost infinite possible combinations, we’ll all have different experiences!
Of the three or four different tubeless rim types I’ve used, and many different tires, I’ve only had one single tire that I could not mount by hand — even though I had mounted the other identical tire that I’d been purchased at the same time.
Liked 10,975 Times
Yep. Can’t remember if it was this thread or a different one where we got into this, but I don’t use levers to mount tires.
Maybe not weightless, but most of the sealant is water and does evaporate. I at some point in the past did weight a tire before and after scraping off the build up of what was pretty much the life of the tire. I don't recall the exact weight, but as you suggest it was surprisngly little.
Likes For staehpj1:
I now carry only a plug kit and a couple of CO2 cartridges. I also have had a puncture on a solo ride this year and I didn't know it had happened until I went to top up the tires the next morning and they were down 20 psi. That and the sealant on the frame were the only clues.
Likes For Bald Paul:
Expired Member
Quoted: 3683 Post(s)
Liked 5,448 Times
Likes For shelbyfv:
Liked 10,975 Times
It's great if people don't feel a need to run tubeless...It's not great when they feel compelled to post a bunch of misinformation about it. It almost seems like they're too insecure to simply let others make their own choices.
Habitual User
Liked 8,100 Times
Liked 10,975 Times
I don't think my hands are that strong, but I was fortunate to have a talented mechanic as an early riding buddy, and he taught me some tips and tricks for mounting tight tires. I won't repeat them here, unless asked, because that comes across as condescending to experienced riders who've mounted lots of tires. (Though I will say that, fairly regularly, I find out that I've been mistaken about something, or doing something incorrectly, for my many years on the planet.)
I also think that people have different tolerances for such things. I'm willing to spend a few minutes trying to wrestle a tire onto a rim, but not much more than that -- and then I return the tire. So that might help explain why I don't need tire levers to mount them. I know that most tires will stretch out after being on a rim for a while...But if it's THAT hard to mount initially, it's probably still going to take a little time out on the trail when I have to stick in a tube -- and I don't need that kind of time-waster in the middle of a gravel race, for instance.
Quoted: 680 Post(s)
Liked 949 Times
we went tubeless on our tandem. any tire that what puncture resistant enough in a 1.5" size was so harsh and pretty slow. going tubeless give us a much smoother ride and no punctures that stopped us. but the tires and my 2" tire on my trek I can put them on by hand and they are easy off too. I lucked out there.
Quoted: 1248 Post(s)
Liked 1,323 Times
Likes For Atlas Shrugged:
Habitual User
Liked 8,100 Times
Likes For Eric F:
Quoted: 2497 Post(s)
Liked 741 Times
You know, at the core of this statement re: tire levers vs magic, lies the foundation ethos of my thinking about the entire tubeless vs tubed paradigm. Tubeless culture has developed a following of devotees that make the technology work through all manner of art, craft, and when all that fails, force of will, and seize on every triumph as more justification to put the hair shirt on another day and ride. Tell the truth, have you ever seen the sheer amount of ... drama that surrounds the adoption of a tubeless lifestyle duplicated in the tubed tire world?
Liked 10,975 Times
I mean, what's more dramatic than claiming that using a particular type of bike tire is a "lifestyle"? Swinging is a lifestyle...RV'ing is lifestyle...Using tubeless tires is not a lifestyle.
Likes For Koyote:
Liked 1,323 Times
Tubeless tires are going to be heavier and when there is a blowout the only fix out on the road is to have a tube handy and to pull the tire off the wheel and put on the tube and inflate the tire. Primary advantages are on mountain bikes and being able to use lower tire pressures for better traction and handling.
I put sealant in the tires of my e-bike that had 4" tires and required two different wrenches to remove the tire for fixing a flat. I sold the bike and now have an e-bike that has the usual skewers to remove the wheels and 28mm tires with tubes.
Liked 10,975 Times
Not necessarily true.
Definitely not true.
Likes For Koyote:
Habitual User
Liked 8,100 Times
Isn't the fix for a tubed tire blowout exactly the same as what you described? One of the major advantages of tubeless tires is the automatic sealing of small punctures that would mean a tube change for a tubed tire. A hole large enough for a tubeless tire to require a tube (and probably a boot), will be equally damaging to a tubed tire.
Likes For Eric F:
Habitual User
Liked 8,100 Times
I've been riding bikes for more than a few years, under lots of different conditions. I understand the options available to me, and the pros and cons of each tire type. Tubeless is my informed choice.
Likes For Eric F:
Liked 10,975 Times
Likes For Koyote:
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12790 Post(s)
Liked 7,698 Times
I'm not old enough to have witnessed it first hand, but I'm sure there were similar discussions back in the early days of clinchers.
Habitual User
Liked 8,100 Times
And with the tubeless tire, you may be able to just shove in a plug, add a little air, and be on your way. I can put in a Dynaplug in about ten seconds. That sure beats changing out a tube -- which, as you note, you might still have to do anyway, JUST LIKE if you were running tubes in the first place.
