Need advice from wheel builders and wheel pros.
Bikes: Gary Fisher Marlin, Gary Fisher AR Super, Scott CR1 Pro, Jamis Nova Sport
So I recently built a bicycle rack for my motorcycle. The final part that needs to be figured out is where to mount the front wheel. The rest of the rack is a copy of a solid design so no need to worry yourselves about that.
Anyway, I was looking at my setup and I had the idea of clamping the skewer of the wheel in a "dropout-like" notch, only the notch is horizontal and the wheel is hanging like a flying saucer. I'd use nylon washers to protect the hub. This would be the easiest and simplest way to finish without more fabricating and welding.
My question might be silly, but will the wheel handle that kind of stress? Would it be weakened prematurely? I'd like to think that all the forces a wheel experiences while riding normally with the bumps and turns under weight are more than what it would see just hanging there.
Let me know what you think.
Thanks.
Thanks.
Quoted: 4212 Post(s)
Liked 3,883 Times
I think the wheel will be fine assuming it doesn't hit anything else and the QR spring isn't crushed due to poor clamp design. I suggest no plastic interface between the wheel and the clamp. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Insane Bicycle Mechanic
Quoted: 809 Post(s)
Liked 712 Times
The wheel will handle that stress fine. The stresses on it during normal riding are magnitudes greater than what it would encounter when it is being carried.
However, I'm not sure how you will attach a QR wheel so it's clamped by only one side of a quick-release skewer. Perhaps you could put the hub in a "dish" and strap it in place with a nylon toe strap.
Cycling journalist Maynard Hershon has many miles carrying bike wheels on a motorcycle:
Maynard Hershon: Part two: Dude, you're a neutral support motor driver.
Jeff Wills
Jeff Wills
Thanks for your input. Much appreciated.
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
I've seen threads about this at advrider.com, including a product review. Good luck!
https://advrider.com/f/threads/motor...estion.966724/
https://advrider.com/f/threads/motor...e-rack.914806/
https://advrider.com/f/threads/revie...e-rack.829069/
Quoted: 1529 Post(s)
Liked 718 Times
IMO a wheel clamped on one side (you'd need a spacer in the other side too) would likely subject the axle to fatigue; any bouncing around would put a bending force on the axle between the locknut and the cone.
