bottom bracket & crank
Old 04-13-15, 02:26 PM
oj.
oj.'s Avatar
Bikes: 2013 trek 4700d, 60's BSA, United Dinero BMX, 1980 BSA Prima
Quoted: 23 Post(s)
Liked 3 Times in 3 Posts
bottom bracket & crank sizing
I have found this frame that I am interested in (Fixie/Fixed gear/Single Speed Bike Frame with Fork Matt Black 52cm | eBay), but I have been confused by bottom bracket sizes. The frame says that it needs a 68mm-107mm bottom bracket (which i have found - Shimano BB-UN55 MTB / Road Bike Bottom Bracket 107mm | eBay). The question that i am asking is can i just put any square taper cranks on or do i have to get a set of cranks specific to the bottom bracket dimensions? P.S I know this is probably a really easy to answer question but this is my first foray into anything other than bmx.
oj. is offline
Old 04-13-15, 03:23 PM
DMF
Elitist Troglodyte
DMF's Avatar
Bikes: 03 Raleigh Professional (steel)
Depends on your REAR components. You want the front chain ring in the same plane as the rear cog. In general you can mount any square taper crank on any square taper axle (there are nuances), but the crank will have its own geometry.
So what's on the back?
Stupidity got us into this mess - why can't it get us out?
- Will Rogers
DMF is offline
Old 04-13-15, 03:24 PM
DMF
Elitist Troglodyte
DMF's Avatar
BTW, is 52cm the right size for you?
- Will Rogers
DMF is offline
Old 04-13-15, 04:24 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds. 2019 Giant Explore E+3
Quoted: 1795 Post(s)
Liked 1,271 Times in 877 Posts
You buy the BB to fit the crank used. Not the other way around.
Bill Kapaun is offline
Old 04-13-15, 05:18 PM
hueyhoolihan
Quoted: 86 Post(s)
Liked 4 Times in 4 Posts
yes, the vast majority of modern square tapered double or single-speed road crank will fit.
i'm equivocating, but still... don't quote me.
hueyhoolihan is offline
Old 04-13-15, 05:33 PM
D1andonlyDman
Bikes: mid 1980s De Rosa SL, 1985 Tommasini Super Prestige all Campy SR, 1992 Paramount PDG Series 7, 1997 Lemond Zurich, 1998 Trek Y-foil, 2006 Schwinn Super Sport GS, 2006 Specialized Hardrock Sport
Quoted: 59 Post(s)
Not necessarily. Certainly the 68mm dimension is nearly universal on current road bikes, but the 107mm, which is for the spindle (axle) length, is not. In fact, a 107mm spindle seems rather short for most cranksets, other than single chainring cranks. Typically, most double square taper cranks would use a spindle ranging from 108 to 115mm, and most road triples would use a spindle ranging from 115 to 127mm.
Here's Sheldon Brown's database on bottom bracket compatibility with cranksets. It's not complete, but it's as good a source as I've found on this subject:
Sheldon Brown's Bottom Bracket Size Database
D1andonlyDman is offline
Old 04-13-15, 06:21 PM
Camilo
Quoted: 1110 Post(s)
Liked 1,204 Times in 761 Posts
Just want to repeat this - the crank determines the type of crank (including spindle length), not the frame.
Camilo is offline
Diamond
Bicycle Mechanics
12
11-12-17 06:12 PM
adlai
Bicycle Mechanics
5
06-28-14 06:04 AM
Kommisar89
Classic & Vintage
30
09-11-12 08:24 PM
[FAT]Roy
BMX
3
05-08-10 11:03 PM
fullyfixed
Singlespeed & Fixed Gear
11
03-16-10 11:15 AM
