135mm quick-release axles, deal breaker?
Have bike, will travel
Quoted: 910 Post(s)
Liked 288 Times
I found a low cost 2021 Fuji gravel bike at an on-line dealer. The bike has 100 front and 135 back quick-release axles. I have 2 disc brake bikes with through-axles and I like the precision of the through-axle standard.
I want a low cost bike I can keep at a vacation home and this Fuji is perfect for what I have planned. Am I going to be sorry I got a disk brake bike with quick-release axles?
Expired Member
Quoted: 3674 Post(s)
Liked 5,441 Times
My negative experience with QR and discs involved removing/replacing the front wheel. Very fiddly to get the brake alignment right. If you don't have to remove the wheel to transport the bike, that might not be an issue.
Likes For shelbyfv:
Quoted: 910 Post(s)
Liked 288 Times
Perfect evaluation, thanks. I'd buy this bike to keep for local rides and to avoid having to transport a bike from my domicile. I'm patient enough to reset the alignment. Will I need to reset the caliper position after I reinstall the front wheel?
Expired Member
Liked 5,441 Times
It was my experience that I had to realign the caliper after most wheel removals. This was with an inexpensive suspension fork, maybe flexy, so that may have compounded the issue.
Quoted: 166 Post(s)
Liked 252 Times
I like thru axles, but QR works fine. more fiddly yeah maybe most of the time not always seems to depend on the drop out design.
Either way once they are on and set its fine a gravel bike I wouldn't even hesitate to go QR.
Quoted: 581 Post(s)
Liked 921 Times
All my bikes are older and have QRs. It is not an issue but there are a couple things to keep in mind:
- QRs were not originally designed for the forces disc brakes produce, and the front QR can loosen off over time. Make sure it is tight enough initially and check the tightness occasionally
- Ensure the wheel is fully installed in the dropouts and is straight in the fork before you do final adjustments on the brake. This should prevent the problem shelbyfv described, unless there is some other problem
Likes For ClydeClydeson:
Sunshine
Quoted: 10969 Post(s)
Liked 7,495 Times
There are 2 QR disc bikes hanging in our garage right now. One hasnt had a wheel adjusted since the last time I added sealant over a year ago(if it cuts, that sealant will be useless) and the other hasnt had a wheel adjusted in 3 years as it uses tubes. My kids ride both and while they secondary bikes that dont get high use, they probably get more use than a backup bike at a vacation house. Just use internal cam QRs and have fun.
Randomhead
Liked 3,699 Times
I don't think you'll be sorry. My gravel bike is QR and I don't see any problem with it at all. QR is gone on higher-end bikes, but it's apparently never going away on cheaper bikes. Which surprises me a little, because I would think the lawyers would make them use TA on all bikes.
I have QR discs on my Soma Fog Cutter and have no issues removing and installing wheels. I actually prefer it since it's faster than thru axles and I do it often with the front to transport the bike. Just make sure the wheel is seated properly, I give it a quick spin to be sure no rotor rub. I am using internal cam XT skewers.
Quoted: 6972 Post(s)
Liked 10,971 Times
That might've been your issue. I have a Space Horse with QRs and disc brakes and have no such problems. Insert wheel, squeeze front brake lever, then clamp down QR. Works like a charm. It works even better if you throw away the OEM QR levers, which are probably external cam, and replace the with some Shimano XT internal cam levers - which will cost about thirty bucks.
Likes For Koyote:
Quoted: 446 Post(s)
Liked 1,045 Times
Overall I prefer TA mainly due to easier rotor alignment, but I'm always paranoid that I'll accidentally mess up the the threads when screwing in the axles. QR is a bit more tedious to align properly, but you don't have to worry about messing up your bike.
I have QR on my gravel bike, but I also have the option to go thru-axle in the future with a rear derailleur hanger swap. I like having this option since forks are easy to swap out, but having the option to change your frame from QR to TA makes it a bit more future-proof.
Likes For tdilf:
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
I wouldn't let the QRs stop you if the bike is otherwise perfect. Keep the skewers tight and accept the fact that you might occasionally have to re-align a caliper, which takes all of five minutes. But honestly, I've only had to do so a couple of times in many hundreds of miles of use on mine.
Likes For Rolla:
Quoted: 910 Post(s)
Liked 288 Times
Likes For Barrettscv:
Expired Member
Liked 5,441 Times
^^^Cool! Surely you need a Pegoretti gravel bike (if such a thing exists.)
Likes For Racing Dan:
Obsessed with Eddington
Bikes: '16 Spesh Diverge, '14 Spesh Fatboy, '18 Spesh Epic, '18 Spesh SL6, '21 Spesh SL7, '21 Spesh Diverge...and maybe n+1?
Quoted: 532 Post(s)
Liked 621 Times
Which on my first disc brake equipped CX bike (with QR axles) was as simple as opening the cam lever old the wheel on the ground, and drop the fork/frame over the top of the axle, ensuring it was all the way into the dropout, and boom…perfectly aligned, every time. No different than with rim brakes.
This is by no means an endorsement for QR with disc brakes. Just saying that ensuring the hub is aligned in the dropouts is not magic.
Likes For Badger6:
Quoted: 427 Post(s)
Liked 339 Times
Through Axle is definitely better, but QR was generally adequate..
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
I have MTBs with both and a gravel bike with QR.
TA is an improvement, but if I was otherwise happy with a gravel bike, I would not really care that it was QR.
As far as brake alignment, there are tricks to that on QR, but it has generally not been a problem for me if I am conscientious about how a place the wheel during brake setup and subsequent wheel installations.
Quoted: 576 Post(s)
Liked 1,003 Times
+1 on not a big deal; have four such bikes.
For putting the wheel back, count the full revolutions to clear the lips and remember the lever orientation. This will help keep the torque constant.
Quoted: 1461 Post(s)
Liked 1,486 Times
Just piling on - I had a Fuji MTB with QR/hydro discs and it was fine. The calipers were a little fiddly and required frequent alignment to prevent rubbing, but I have the same situation with my TA disc brake bikes.
My only concern would be wheel/hub compatibility - 135mm QR disc hubs are becoming more rare these days, so your aftermarket wheel options might be a bit more limited.
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
I got a custom bike in 2014, which was the last year for QR (at least from that maker). It hasn't been problematic, once I learned that I needed either Dura Ace internal cam QR or (arguably better) DT-Swiss QR-compatible skewers that you can crank down hard. This is especially important if you have disk brakes. Ideally, the fork drop-out should be forward-facing (like Enve's 1st gen forks).
If you get the bike and can't live with it, you can always replace the fork.
My main gripe at this point is it is hard to find high-end wheels that are still QR-compatible. Chris King, for example, no longer offers it. Some hubs are backward-compatible (or future-compatible) like White Industries or DT Swiss.
