Road Morph pump broblem
a77impala
Road morph bike pump.
I have this pump and yesterday when attempting to pump up a tube to find the puncture it didn’t work!
it had no pressure at all. I walked a mile and half to my car.
it appears the O ring won’t create any pressure. I went to local hardware store for new O ring.
the one like the original didn’t creat any pressure and the next larger wouldn’t go into the pump.
Does this pump require a special O ring and if so where do I get it?
a77impala
No, what type oil should I use?
aged to perfection
Quoted: 839 Post(s)
Liked 1,258 Times
it's a topeak pump. I am not sure if parts are available but the O ring is certainly a failure point.
on ebay I see a "road morph repair kit" which has the replacement part but its $6.00 and "you don't want to pay that much"
personally I would buy a new pump. That one probably is not worth fixing
but what do I know ?
/markp
/markp
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,995 Times
The Topeak Road Morph is a rebuildable pump generally they have rebuild kits for it and your local Topeak dealer may have the kit and can get you the part you need. I wouldn't ditch the pump and if you are doing that send it to me and I will take care of it.
a77impala
I like the pump, when it works. I put some oil on the O ring end, worked for a few minutes.
I’ll check with a bike shop next time I’m near one, see if they have parts.
I’m 180 miles from nearest good bike shop!
Bikes: Specialized Tarmac Expert, 2002 TREK 520, Schwinn Mesa WINTER BIKE, Huffy Rock Creek 29er, 1970s-era Ross ten speed. All my bikes are highly modified(except the Tarmac) yet functional, and generally look beat to ****. .
Quoted: 68 Post(s)
Liked 88 Times
Unfortunately, you might have a tough time finding the o-ring, most shops will sell you a new pump but don't stock the o-ring. You can buy one on-line but between the price and the shipping you'll probably just opt for a new pump. I have two of those pumps sitting in my garage with worn out o-rings.
Quoted: 2026 Post(s)
Liked 1,096 Times
Contact Topeak's customer service. They are very likely to send you a replacement o-ring (or perhaps a brand new pump) at no cost.
Likes For HillRider:
Insane Bicycle Mechanic
Quoted: 809 Post(s)
Liked 712 Times
Thanks for the reminder to oil the o-ring in my pumps. It’s been a while since I had a flat on the road and I know I’m tempting the Flat Gods by saying so.
Jeff Wills
Jeff Wills
Quoted: 2604 Post(s)
Liked 1,933 Times
Phil's Tenacious is my favorite because it's sitting at the front of my bench.
If you run into this problem again, you might be able to get home by trickling some water from your bottle into the pump. It probably won't get you up to full pressure, but it may seal the O-ring enough to get enough pressure a couple miles' ride home. But when that happened to me, I replaced the pump. It was 10-12 years old, so I got my money's worth out of it.
Likes For pdlamb:
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 840 Post(s)
Liked 336 Times
Quoted: 455 Post(s)
Liked 112 Times
Had the same problem when we were touring on our tandem in Denmark. I took the pump apart and spit on the "o" ring! Worked until we got to a home center.
Now I do abit of maintenance on the pump before every tour.
Likes For Tandem Tom:
Bikes: 2012 Specialized Elite Disc, 1983 Trek 520
Quoted: 676 Post(s)
Liked 741 Times
I neglected mine once for a couple of years. (After I started using Gatorskin tires, flat frequency went way down.) So it didn't work when needed. It was full of grit from riding in rain, etc. I happened to be at the end of a desert ride and was out of water, didn't even have enough spit to clean it and make it work. I had to walk a couple of miles into Albuquerque. Now I clean it and check it after every ride in the rain, and do a complete tear-down service on it yearly. And I keep it inverted on the frame. (Someone on this forum puts some kind of condom over the handle.) It's a great pump, worth the extra attention.
Mostly harmless ™
Bikes: Heavy, with friction shifters
Quoted: 1107 Post(s)
Liked 216 Times
I've had good results with using silicone grease on rubber seals.
I'm silly enough to disassemble a brand new pump and apply some right from the start.
Likes For Bike Gremlin:
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,220 Times
Use something other than oil. You want something semi-solid that stays in place. Silicone grease, bearing grease, Vaseline, etc. would work better. As to the o-ring, you need to make sure you match the cross-section of the o-ring as well as the proper diameter.
Stuart Black
Stuart Black
Likes For cyccommute:
What's everyones favorite version of the morph pump? I'm liking the Road Morph G more than the Turbo Morph G even on high volume tires due to the extendable hose on the Road Morph G.
Clark W. Griswold
Liked 3,995 Times
https://www.topeak.com/global/en/pro...6-ROAD-MORPH-G
https://www.topeak.com/global/en/pro...-TURBO-MORPH-G
https://www.topeak.com/global/en/pro...-MORPH-DIGITAL
https://www.topeak.com/global/en/pro...MOUNTAIN-MORPH
The Road Morph G and the Turbo Morph Digital have nearly the same hose length (minus a mm or two). The difference is the Gauge is part of the pump head which does change the overall length but the hose is nearly the same.
For me I like the Road Morph for high pressure stuff and my Turbo Morph actually lives in my travel tool case but have brought it out mountain biking and used it on rare occasion for other high volume stuff. I do like the Turbo Morph for it's easier to read gauge but that is not super important either way for a portable pump.
Quoted: 980 Post(s)
Liked 582 Times
I also like the Road Morph... mine is so old I can't tell if it's a "G". IIRC, when I bought these (I have 2) the choice was between a "Road Morph" and "Mountain Morph", and I went with the former. It's almost like having a floor pump on the bike.
The Road Morph is attached to the seat tube.
Clark W. Griswold
Liked 3,995 Times
Quoted: 980 Post(s)
Liked 582 Times
Hahaha... that makes sense! They're *both* "G". The gauge is what makes it such a good product; you can watch it while operating the pump and not having to contort to see the pressure or maintain the seal on the valve stem.
Likes For sweeks:
a77impala
selection of metric O rings, bought the one closest to what I have.
It didn’t work, even with 30 weight oil applied to it. I have two other working pumps so it’s not that I have to use
this one.
Just Pedaling
Bikes: YEP!
Quoted: 334 Post(s)
Liked 522 Times
I went to local Runnings, they sell everything from fishing tackle to farm needs. They had a large
this one.
this one.
