USB Cable Question
Quoted: 455 Post(s)
Liked 112 Times
USB Cable Question
I think I know the answer but just want to make sure.
We have a new Garmin Edge Explore 2 that used type"C" usb plug. Will a double ended "C" encounter and problem when I attach it to my android phone? The reason I ask is I was using a little adaptor junction box with a USB C cord and it only worked in one direction.
Thanks
Thanks
Quoted: 4260 Post(s)
Liked 1,363 Times
Not sure what the “little adaptor junction box” is.
USB C cables are bidirectional. (They have to be because they don’t plug in one direction.)
https://www.viewsonic.com/library/te...he-difference/
(With older USB cables, you needed an OTG cable to plug your Garmin into a phone.)
Likes For njkayaker:
Quoted: 6196 Post(s)
Liked 4,810 Times
I usually just try it and see what happens. I've not had a bad thing result from willy nilly connecting cables to devices other than it doesn't do what I wanted it to do.
Is the little box on the cable a ferrite core? Those are usually cylindrical though.
If it blows up please let us know. <grin>
Bikes: 68 SS, 72 Fuji Finest, 72 PX-10, 77 Pana Pro 7000, 84 Pinnarello Treviso NR, 84 Trek 520, 88 Project KOM, 90 Trek 750, 91 Trek 930
Quoted: 184 Post(s)
Liked 204 Times
Adapters do not always work; I had a problem with adapting an endoscope usb-a to micro. I bought a different adapter and all OK.
Last new bike 1991
Last new bike 1991
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,205 Times
Thanks
Thanks
Barry
Did some research and learnt something new, I’m an iPhone user so this was news to me.
Some Android phones support USB on-the-go (OTG).
This allows a compatible Android phone to be used as a power bank & charge other usb devices.
Two issues… it charges those devices slowly…… you are required to use an OTG adaptor.
Yes, the OTG adaptor has an input and output side, so one way.
Quoted: 455 Post(s)
Liked 112 Times
It allows me to download routes/courses to the Garmin.
Quoted: 3242 Post(s)
Liked 2,086 Times
Backwards method to do that. If you have a smartphone (Android or iPhone) download and install the Garmin Connect Mobile app. BT pair the Explore to the phone and the GCM app. Create an account with Connect, on the app and on the Connect website. You can then create routes on the Connect website or on the app, save and then send to the Explore. It does not require a cable connection. You can as well create a link from RideWithGPS, Kamoots or Strava, create routes on those apps, and pick them up on the Explore when there's a WiFi connection. You can check, but there might be a Trailforks app resident on the Explore that allows you to download directly any routes created on that app, which is the best for mt. bike trails.
Liked 1,363 Times
Why are you attempting to connect your Garmin Edge to your Android phone ?
Barry
Barry
The phone has to support OTG.
If its a newer model Samsung then do as Steve said, & most current samsungs are OTH compa. I've currently have the galaxy s20 & the garmin explorer 2.
You do need the app he said, I can also do it via my laptop using ridewithgps website, its how I've loaded last years events rides to both my 20 & explor2.
Oh, also its how I created some local rides using ridewithgps site then loading them to both devices. Makes it so easier to create on the bigger screen laptop (true laptop not a chromebook or tablet) for these old eyes.
I have an Edge Explore 2 and it works fine with generic double ended USB-C cables. In fact I threw away the factory Garmin cable. Nobody wants USB-A anymore.
Zoom zoom zoom zoom bonk
Bikes: Giant Defy, Trek 1.7c, BMC GF02, Fuji Tahoe, Scott Sub 35, Kona Rove, Trek Verve+2
Quoted: 551 Post(s)
Liked 722 Times
A lot of my smart USB-C chargers won't charge my dumb devices. USB-A chargers aren't smart enough to know that that cheap flashlight or battery pack isn't properly USB-C compliant.
Also the USB-C specs are a nightmare of different speed and power transfer rates.
Quoted: 3461 Post(s)
Liked 1,467 Times
I do, my dynohub powered USB charger, the pass through cache battery, my USB powered NiMH AA/AAA charger, camera battery charger, and phone, they are all USB A, Mini USB or Micro USB.
My laptop is the only USB C device I have, it stays home when I bike tour. That said, I bought a USB-C charger to use for non-bike travel with my new laptop that uses a USB C cable and C charger for power supply. And my new travel charger had the wrong voltage rating for the USB C power supply jack, won't power the laptop, but it will charge it at an exceptionally slow rate.
