Cycling gives me migraines!
Bikes: 2012 Trek Allant, 2016 Bianchi Volpe Disc
I've discovered after two years of logging that an almost guaranteed migraine trigger for me is cycling after not cycling for more than three days. Because of snow and the holiday, I hadn't cycled since last Tuesday. I rode into work, felt great. An hour later, bam migraine.
Does anyone else have this problem? If so, have you found any solutions? The migraines usually aren't that bad, but they do put me out of commission for an hour or two at work (hard to type when you can't see the screen).
Quoted: 52 Post(s)
Liked 17 Times
Quoted: 7351 Post(s)
Liked 2,479 Times
Try more coffee before your ride. I don't know what makes me think of that.
contiuniously variable
Sounds like your vascular system may be slow to warm up.... i'd add 16 oz of water to your daily intake and 2 oz of dark chocolate 80% or more.
- Andy
- Andy
Thanks for the suggestions, all.
I usually don't have my first dose of caffeine until mid-morning (cup of tea), but I'll try having a cup with breakfast on days after breaks. The caffeine in Excedrin definitely helps manage the migraine, so it's conceivable that it would help in prevention as well, whether it's from tea or chocolate.
Dehydration could be related, but I'm usually very good about drinking enough water. I consume 8-16 oz. after my 25-30 minute ride in, depending on how hot it is.
It's tough for me to do a proper warmup since I live at the bottom of a minor hill. I do try to take it easy though.
I have to have tea most days, it helps balance my energy & helps me fall asleep later that night.
- Andy
- Andy
Collector of Useless Info
You sure they're migraines? I tend to have auras (funky smells and colors), and mine last for 8-24 hours. Never triggered by the bike, but seem to be related to chocolate, bananas, dehydration, salt. And there isn't a substance made, other than cyanide, that has any effect on them once they start. And during one, cyanide seems like a good option. Daily Metoprolol 25 mg seems to decrease their frequency.
Is there anything else you do on days that you ride that could be triggering them?
I tend to agree with Cycle_maven that soemthing else may be at play here. I'd check with a doctor if I were you... but what you're describing sounds a lot like my sister's neurovascular headaches, which are triggered by cold.
(I get full-on classic migraines, complete with sparkly visual aura, phantom smells, and a disconcerting tendency to start crying apparently at random... and they last almost exactly 8 hours).
Bikes: Trek 700 (2000ish), 88 Schwinn Voyaguer, late 80's-ish lugged Spalding mountain bike
I get miner migraines. Miner in that I know people's who are a lot worse. Last time I had one I took the sumatriptan that my doctor prescribed me which usually helps. I noticed last time that the medicine didn't seem to work until after I had coffee, which was almost an hour after I took the pill. It may be a coincidence. I was also told to take magnesium supplement. Perhaps that would help?
Bikes: 199? Landshark Roadshark, 198? Mondonico Diamond, 1987 Panasonic DX-5000, 1987 Bianchi Limited, Univega... Chrome..., 1989 Schwinn Woodlands, Motobecane USA Record, Raleigh Tokul 2
Quoted: 1131 Post(s)
What kind of headaches are you having?
Super-spreader
I get migraine auras too, but they were a lot more common back when I wasn't cycling much - in my case I'd say cycling helps to prevent them! Alcohol is often the trigger, and they would most often strike at the end of a long weekend.
OlyCommuter
Bikes: Spot Ajax for commuting, Jamis Dakota Sport for dirt.
Could it be tension headache caused by shoulder/neck stress from your riding position? If you're leaning heavily on your arms, or leaning forward with head up (so you can see where you're going) that can put stress on those areas. Would be great if you had the chance to try a more upright bike, or even a recumbent, to check this.
Bikes: 2 many
Quoted: 1266 Post(s)
Liked 323 Times
I had suicidal migraines for about 12 years. Often started by cycling. They would last about 1.5 days. I would throw up every 20 minutes. Then towards the end my body wanted to lock itself into that cramp that causes you to vomit. You can't breath when that happens. Finally my neurologist retired. He was 75 and using what was state of the art in the 1950's. I had a referall to a new neurologist that is young and using state of the art treatment now. No migraines arter a couiple of visits. Amyitriptaline.
The sugestions here are all things that may work, I've used them all. The problem is there are a lot more too. The best and probably fastest method is a good neuroligist. I have had a couple lately, I know I have pinched nerves in my neck. That's where the pain starts. I raised my bars so I don't have to tip myhead back so far, that is a trgger for me. The recent onset of cold weather has trigered a couple after a ride. To stop one that starts now I take imitrex when they start. It's very safe. Get a neurologist that is very up to date on treatments.
A quote from Louise L. Hay in her book "You can Heal your Life", page 125:
"Migraine headaches are created by people who want to be perfect and who create a lot of pressure on themselves. A lot of suppressed anger is involved. Interestingly, migraine headaches can almost always be alleviated by ************ if you do it as soon as you feel the migraine coming on. The sexual release dissolves the tension and the pain."
Uh . . . might want to clear it with the boss first.
Bikes: 2014 Trek Allant drop bar conversion, modified Schwinn MTN commuter, 2015 Trek 520, Soma ES, Salsa Journeyman, 1980 Trek 414
Quoted: 178 Post(s)
Liked 355 Times
I used to get migraines quite frequently. I found that my trigger was caffeine related. Not too much caffeine, but caffeine withdrawl. I would drink a fair amount of soda while at work each day, and then on my days off, not have the soda. Almost like clockwork, I would get a migraine on my day off, from the caffeine withdrawl. By keeping an eye on and limiting my caffeine intake on a daily basis, I rarely get migraines any more. Not saying that this is your particular problem, but I would look at what differs in your daily routine on days that you bike, and on your off days. Perhaps there is something in your routine or diet that changes on non-cycling days that is triggering your headaches.
They're definitely migraines. Aura followed by head pain and/or nausea. Sometimes worse than others.
I used to get them a lot in high school and college, like once every few weeks. The trigger back then was usually stress (big test coming up, etc.). Then I went years with none. Started biking into work and started getting them occasionally, so I started keeping a log to nail down a trigger.
For treatment, I take Excedrin. It usually cuts down on the pain enough that I can stay at work. I took Imitrex once back in the late 90s and got a horrible rebound headache the next day.
I just took another look at my logs, and it could be stress-related. Some were days that I got a flat tire, others were rushing, one was first ride after a wrist injury. All of them occurred after a break in riding, anywhere from 3 to 10 days.
Bikes: 2 many
Liked 323 Times
I also had them a long time ago. Seems like my history and triggers are very similar to yours. Maybe the start of cycling after time off causes some neck muscles to get sore, then they get better as you ride more, and tone the muscles. Anyway, best of luck with your treatments. Let me know how it goes. If you tried imitrex, does that mean you have or had a good neurologist?
^ Got the Imitrex from my dad. He was also trying it out at the time (seems like migraines are hereditary). I haven't seen any specialist about them since they're not really interfering with my life. According to my log, I've had 9 this year.
Also, I don't think it's neck muscles. My bike is super upright already (Trek Allant).
Bikes: 2 many
Liked 323 Times
Bikes: Jamis Quest Comp
Quoted: 169 Post(s)
With the holidays, I've had two occasions where I had a long break from cycling. No migraines! I have consciously tried to relax my shoulders and neck on the first ride in and it seems to be helping. Thanks for the suggestion @2manybikes and @babaluey!
Let's Ride!
Quoted: 327 Post(s)
Liked 37 Times
i am not sure about migraines but I know that the after a break then riding in the cold weather tends to give me some sinus headaches. Makes me feel like I can feel the cold inside my head.
i also made sure i hydrated really well and it helped. best of luck sorting this out. I would recommend seeing a Dr.
Bikes: Masi, Pinerallo, Cinelli, Raleigh, Peugeot
I'm a little late to the dance on this one but I've been suffering from exercised educed migraines for years. To this day when I play hockey I have to take 2 Advil liquid-gels before I even get on the ice. Sometimes lifting/working out can trigger them too. Especially with movements of fast rushes of blood to my head, or extremely intense cardio. It's all blood and capillary expansion related. I know for me dehydration, stress, a booze bender etc can trigger it. The aura, the pain etc.. but I swear the fix is 2 or 3 Advil Liquid Gels as soon as the first sign hits and crush a can of regular Coke as fast as you can. The liquid gels get in your system WAY faster than regular and the Coke (caffine) opens the capillaries that are constricted causing the pain. I'm far from a doctor but athletically these things have been killing me for years and I swear if you try that 'fix' asap as it hit, lay in a dark room/eyes closed, you can kick the aura in a half hr/45 mins. You get the residual head ache but personally I can live with pain, it's the vision that kills me. Hope this helps you or someone reading.
