Raleigh Super Course
Bikes: Trek 970, Bianchi Volpe,Casati
Quoted: 358 Post(s)
Liked 122 Times
I gave away a Super Course a while back that had been resprayed horribly , decided I liked the way it rode , and happen to find this . Cappella lugs 🤓.
don't know what to do with it. ( any suggestions). There's a clicketty sound out of the rear hub, . I'm sure needs to be all gone through. Surprisingly clean original paint , even under bottom bracket and chrome seems like it will clean up..
Quoted: 3814 Post(s)
Liked 3,345 Times
nice find
appears '73, first year for this transfer set
final model year prior to launch of Mk. II
serial should be found on lateral side of NDS dropout
unusual to locate one with so few changes, only the gear mechs
worst remaining original fitting is the Simplex Prestige Delrin shift lever set
you mention clicking noise in rear
one additional spot to check when you have the machine in the stand is the pedals; have had some of these come through of this time which did not receive the correct number of balls in each race; good idea to repack anyway, assuming you will be using the stock ones...ball size is 5/32"
when you have everything set to your liking do not forget to append the machine to the "show your Super Course" thread
nice find
Likes For juvela:
ambulatory senior
Quoted: 1955 Post(s)
Liked 3,661 Times
Great city bikes!
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Quoted: 1297 Post(s)
Liked 940 Times
First thing? Clean it.
Unless you climb the rungs strategically, you’re not going to build the muscle you need to stay at the top.
Señor Member
Quoted: 1492 Post(s)
Liked 1,095 Times
That's a beautiful example.
Give it a thorough servicing and see what issues remain. If that were to fall into my hands, I'd want to change the rear derailleur and shift levers (I don't much care for downtubes, but I can live with them). Enjoy!
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,802 Times
What can you do with it? Damn near anything, that vintage SC is a chameleon bike. Ride it OEM, or put some wide tires with fenders, or wider tires and use it as a gravel bike. Make it a 1x with upright bars as a city bike.
Quoted: 604 Post(s)
Liked 1,064 Times
If it’s your size, fix it and ride it, clicking sound out of rear hub should be an easy fix. Probably bearings, as stated above, or possibly freewheel, or even rear derailleur, not a big deal. Nice bike, great find, enjoy.
After reading other members posts about how great they ride, I decided to see for myself, so found an old frame and built it up.
As suspected, they were right, awesome ride. I know I’ve posted this before, but everyone likes posts with pics, so here it is again.
Your’s has much more potential, much nicer lug work, and chrome!
Tim
1978 Supercourse
Tim
1978 Supercourse
Liked 5,802 Times
I built an old one up for the 2021 Clunker Challenge, and rode it 62 miles in one shot. I was shocked how nicely it rode.
Foam grips get a bad rap, but they were actually very comfy.
Paramount Fan
Bikes: Paramounts, Raleigh Pros, Colnago, DeRosa, Gios, Masis, Pinarello, R. Sachs, Look, D. Moulton, Witcomb, Motobecane, Bianchis, Fat City, Frejus, Follis, Waterford, Litespeed, d'Autremont, others, mostly '70s-'80s
Quoted: 123 Post(s)
Liked 240 Times
My favorite era, if just for the flamboyant paint and unusual, but not obscene colors. I like the green better than the brown. I was building these up new BITD, and they came with the frame completely wrapped in a sort of brown crepe paper, as I recall. It took almost as long to unwrap as it did to assemble, though the Brits made sure that there was plenty to attend to. The steel crank is so unusual today that it has switched from being a liability to an asset. Someone has changed out the rear wheel, but the brake pad position makes me think it's still a 27". You can still find tires for them, and the Pasela is probably the best choice these days. If it were mine, I would find a working Simplex Prestige derailleur for it, and swap the freewheel for a 14-28 Suntour. That Shimano derailleur works far better but it looks like a tumor on that bike. Most of these ended up with Suntours, but a Simplex just looks right and is a conversation starter. Find a set of metal Simplex downtube shifters and ditch the plastic ones. The Simplex shifters have a smaller barrel than most other brands, so you will get the best feel if you stick with them. A set of barcons wouldn't be out of place, and Suntours will work with Simpex mechs, but downtube shifters will change gears with a crisper snap. The front derailleur combines the attributes of fragility and poor shifting, but keep it if it actually works and the body isn't cracked.
As I recall, the original tape was a patterned, off-white plastic, but I would probably get rid of that not-quite-a-match green stuff and replace it with black or white cloth and a coat of shellac.. Those slippery hoods will outlast you and are right for this bike, so don't screw with them. The saddle has had the radish, so I would find another B-15 or B-17 to replace it.
Every Raleigh of this era that I have worked on recently has had grease that gave up any lubricating qualities long ago, so everything should come apart. Spend some time reading up on how to get the crankarms off if you have never done it before. Without a press, you are going to destroy the cotters in the process, so get some replacements before tackling the job. There is one way to do it right and a whole bunch of ways to do it wrong, some of which will wreck your BB bearings. Sheldon Brown is your friend, even from the grave. The cable casing looks original. If you're thinking of replacing it with lined casing, make sure it fits through the guides before destroying the old housing. The ribbed, off-white housing isn't lined, but is correct for this bike and should work fine. I'd keep the original housing, just for its looks.
Personally, I would put together the correct rear wheel for it (Weinmann rim, Normandy large-flange hub, 36-hole), but that's just me and it's your bike, not mine. This was the first bike in Raleigh's line that I think deserved any respect and it's great to see one that is so close to being original and in such nice shape. There are plenty that are down to little more than the original frame that are available to rat rod.
Likes For sbarner:
Quoted: 702 Post(s)
Liked 672 Times
Original paint in such good condition (and the best color too) argues for staying close to original rather than doing a big hack or resto-mod. Agree with others above that the Delrin pieces may not be ideal if you want to accumulate some mileage on the bike, which I would encourage, they are very pleasant bikes to ride. Personally, on my '73 Super Course, I used steel Huret derailleurs and shifters that all came off of a 1970 Super Course. Functional, but probably doesn't shift as precisely as even the contemporary Japanese kit would have. The Huret Challenger and its accompanying shift levers which first appeared on the '74 Super Course Mk II work well and are robust, but you will be limited to a 28t rear cog. I find 40-28 to be adequate for most climbs but you will find others here on the forum that would insist on having lower gears.
Quoted: 586 Post(s)
Liked 612 Times
It has what might be the original handlebar wrap, so it was likely a garage queen. Amazing how many I see like that. Shame really. But it is what it is.
As far as the Super Course, I own one of the root beer colored ones that's not too far off of that one in age. Mine is currently torn down to the frame and sadly has been sitting for far too long. But I did ride it and it was a blast. Just a nice, supple ride.
That one? Restore it and enjoy!
Quoted: 358 Post(s)
Liked 122 Times
Wheels. I think the wheels are non original and mismatch. So I guess I need a wheel set and tear the bike down for completely new grease and clean. Looking forward to doing this soon.
I loved the way the one I gave away rode. It gave a feeling of sitting in it , rather than on it. Cornered well and comfortable.!
