Steel Fork straightneing
Just picked up this Fuso FRX #550 ... But... And it's a big one! The front fork is bent from a collision. The fork crown is fine. I just need to find a mechanic in the Tampa Bay Area willing to straighten it. I talked to Dave Moulton, the builder, and he says it can definitely be straightened. The shops I've talked to keep saying they can't due to liability issues. Help!
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
I have never found a shop willing to straighten a fork. Too much potential liability for too little money. My LBS doesn't even install tubular tires anymore. I talked to him about it, the increase in his insurance to cover doing tubulars was about 10X the income it would generate. So it was a pretty simple decision. So I adopted a D-I-Y solution.
Lots of DIY options have been discussed on this forum. I've straightened a lot of forks, but ONLY on my personal keeper bikes. My method is not as good as the one below. No interest in taking on this risk for others.
And in no way am I recommend you straighten the fork. Its really one of those decisions only you can make.
And be sure to inspect the main frame carefully. Typically I will find either slight rippling, or cracks in the paint on the DT and TT near the HT.
https://www.bikeforums.net/bicycle-m...bent-fork.html
Quoted: 836 Post(s)
Liked 1,061 Times
Try posting in the Framebuilders section as well. https://www.bikeforums.net/framebuilders/
Quoted: 882 Post(s)
Liked 821 Times
Considering the ramifications of a front fork failure, you might consider locating someone who definitely knows how to repair the fork (Dave's apprentice) than someone willing to do it.
Get a long pipe, about a foot longer than the fork mask the fork so it doesn't get scratched, and go to town on it. You may have to take it to a bike shop to get the final alignment using a jig. But you can also just try riding it and if it ride straight with no hands, it's aligned.
Il faut de l'audace, encore de l'audace, toujours de l'audace
1980 3Rensho-- 1975 Raleigh Sprite 3spd
1990s Raleigh M20 MTB--2007 Windsor Hour (track)
1988 Ducati 750 F1
1988 Ducati 750 F1
So this is what I did with the help of a local frame builder. All straight & Aligned. Thanks to everyone, especially Dave Moulton, for the assistance.
When we bent our forks jumping bikes, a junk wheel was installed, the fork turned around and wham! into the wall it went. This bent the fork blades back to straight (by sight, not measurement).
Another method is to install a dummy axle and use a lever against the crown to bend the blades in unison. Will need to measure for alignment either way.
As someone else suggested, take a hard look at the downtube to make sure its not kinked. If the head on hit bent the forks that far back, it could have very easily crinkled the DT.
1988 Ducati 750 F1
1988 Ducati 750 F1
Ask me how I know.
1988 Ducati 750 F1
1988 Ducati 750 F1
Hello
Dave is semi-retired
I was in a 3/4 race on my 2 month old 3Rensho and had gone off the front but got caught. I was towards the back of the pack and as we go around a corner, the riders in front of me go left and right and theres a guy that had just crashed who is slowly getting on his hands and knees. No whrere to go I nail him on the hip, belly flop and skid on my chin a bit. The downtube was kinked, but I kept on riding it until it finally split, luckily the DT didn't separate, but the frame got really loosey goosey. I was like 20 miles from home and stopped and called a freind to pickme up. I dodged a bullet on that one.
1988 Ducati 750 F1
1988 Ducati 750 F1
When metal gets bent, it's molecules of the material getting torn apart. Those ripped apart molecules are typically too small to see. When you try to straighten a fork, you aren't putting those torn molecules back together, you tearing more apart in the vicinity. You aren't unbending, you are bending again in hopes of countering the deformed geometry. Get it looking straight and you have approximately doubled the damage you had after the initial bend. Steel is perhaps the most forgiving material. Aluminum typically just snaps off when you try to unbend it. Heating to red hot can allow you to alter the shape but it need proper annealing to regain some of the strength. On a bike like this one, the heat required would melt the brass in the crown.
Some times the steerer gets bent too. You never know what the weakest point of a bike is until it gets crashed. Sometimes the wheel fails, sometimes the frame gets bent, sometimes it's the steerer or blades. Rarely all are of equal strength. I've seen frames ripped apart in collisions where the fork and wheel were okay.
Look for cracks or ripples in the paint just behind the head tube. That's a sign the frame got damaged too.
Randomhead
Liked 3,696 Times
Quoted: 4201 Post(s)
Liked 3,857 Times
So now I have to sleep with the guilt of tearing molecules apart? Andy
AndrewRStewart
AndrewRStewart
