12-speed Ultegra 81xx Di2 install and (first) use impressions
Obsessed with Eddington
Bikes: '16 Spesh Diverge, '14 Spesh Fatboy, '18 Spesh Epic, '18 Spesh SL6, '21 Spesh SL7, '21 Spesh Diverge...and maybe n+1?
Quoted: 532 Post(s)
Liked 621 Times
After 14000kms and time to replace the second cassette on my SL7, I decided to strip off the 11-speed 80xx series Di2 and go for 12-speed. I contemplated Dura-Ace for about a minute and then decided to buy Ultegra. I’ve had a few DA parts here and there over the years, but Ultegra has always served me well, and the dollars/euros were more important than the grams.
Install: It was easy, considering the frame (aero type road with all hosing hidden…no cables up front certainly helped!).
(1) Plugged the RD into the battery, slapped it on the charger for about an hour.
(2) Prepped the bike by removing the crank, the BB, and all of the 11-speed Di2 bits.
(3) Plugged in the FD, and toggled the Bluetooth connectivity mode so I could use my phone to “talk” to it; created a bike profile in the E-Tube app, and then paired the shifters (R then L, but it probably doesn’t matter) to the system.
(4) Started hanging parts.
Today, went for a ride. Initial impressions…
(1) the system shifts much faster than the prior gen 11-speed. It is not noticeable on normal up/down shifts, it is a stark improvement when the Synchro shifting has to shift the rear and front as I go up/down the range.
(2) the new brake calipers are a massive improvement over the prior gen. The set back Shimano claims they added must work, because I never heard them after releasing the levers, and the engagement is incredibly fast, predictable, and easily modulated.
My only lingering question is to wonder when Shimano will add 12-spd to the GRX line and bring these new brakes over.
The use of TerryDi2C’s great website (bettershifting.com) made hunting for specific directions a much simpler task than reading the Shimano DMs once I was into the install.
- installed the rear brake caliper, which came filled and with a 1700mm hose which I ran through the frame and left the free end hanging out of the headset
- installed the front brake caliper, came with a 1000m hose, to the fork
- installed the fork, and set the brake hoses, per the manual, then installed the handlebar (internally routed aero bar), then hooked up the shifter levers which were also filled.
- tested brakes, no bleeding required, firmed up on the third pull on both ends once the pads were advanced to the rotors.
- replaced BB and crank, then installed derailleurs, chain (had to add 2 links due to larger rear cassette and larger jockey wheels on the RD); adjusted everything, took about 5 minutes using the app.
Likes For Badger6:
Quoted: 532 Post(s)
Liked 621 Times
Short update. I live in Belgium, and it rains frequently here from October to March, and a little less frequently from April to September. So the bike is gonna see rain...and yesterday was the first rainy ride. Noticeably, the brakes were much quieter once the bike was good and wet. The brakes also seemed (this is purely perception I am sure) a bit more confidence inspiring because of the improved threshold modulation over the previous generation hydro brake system from Shimano. And yes, having ridden on SRAM hydro discs, these are amazingly better, IMO (again, probably just perception, but they work really well). The brakes alone are reason enough for me to be happy with my choices here.
Likes For Badger6:
Likes For TerryDi2C:
Quoted: 532 Post(s)
Liked 621 Times
Hey TerryDi2C, did you get the light in your shed? Curious your impressions.
Quoted: 768 Post(s)
Liked 1,744 Times
I have to agree with you on the brakes. Shimano brakes are just better. I recently got a new Domane with the eTap AXS and I find the brakes to be the weak point. I am so used to Shimano brakes and I find these just not a solid. Again, could be that I am just used to the Shimano brakes. I am currently updating my Emonda ALR with eTap AXS, but staying with the Shimano rim brake, so I picked up some new Ultegra 8100 brakes which allow for a better fit on the 28mm tires I run. Never was a fan of the SRAM rim brakes.
Brian | 2023 Trek Domane SLR 7 AXS | 2023 Trek CheckPoint SL 7 AXS | 2016 Trek Emonda ALR | 2022 Trek FX Sport 5
Likes For jaxgtr:
Di2 fanatic
Quoted: 53 Post(s)
Liked 65 Times
There's A LOT of light in the shed now
My 2018 Ultegra Di2 Synapse came with metallic pads and I spent 2 1/2 years hating the battle of the squeal. No matter what I did the squeal always came back. Got a gravel bike with resin pads and was incredulous; no squeal. Put resin pads on the other bike and couldn’t be happier.
Wondering if my experience is typical.
Quoted: 768 Post(s)
Liked 1,744 Times
Metallic or resin pads?
Quoted: 6972 Post(s)
Liked 10,968 Times
Quoted: 532 Post(s)
Liked 621 Times
Quoted: 532 Post(s)
Liked 621 Times
This is interesting to me, since 11sp Di2 does not shift well in Synchro and Semi-Synchro modes, in my opinion. On my bike, in those modes, the bike seems like it first shifts the FD, then after a very brief lag it will shift the RD. It sort of upsets my cadence twice, rather than smoothing it out.
Liked 10,968 Times
Exactly this. I still use full syncro on my 11-speed Di2 bikes, but I pay close attention to the shift points because it always seems to happen right when I don't want it to happen. It's worse when down shifting than up shifting in my experience...but it is barely noticeable on the 12-speed.
I suspect the system doesn't generate enough torque to quickly (and simultaneously) shift both the FD and RD...But it sounds like they've worked that out in 12sp, from your post. Good to know.
