Di2 Battery Voltages
Background: Bike unused fro awhile. Charged battery but ended up with only a solid red light on the SM-EW90 B unit but no shifting capability. Decided to replace batteries in battery pack. No response needed about this.
When I disassembled the battery pack the battery output was checked with the two batteries connected together and measured 8V +. Individually each were 4V +. Therefore there didn't seem to be a need to replace the original batteries. When connected to the bike's battery cable there were no lights on the SM-EW90 B unit. Did a recharge for good measure with no change. I then removed the SM-BTR2 battery pack and rechecked the voltages. Again 8V + and 4V +. The voltages measured the same when checked at the soldered joints at the control circuitry. The readings were the same. Then the voltage at the end of the cable at the end of the pack was tested. The voltage seemed to repeatedly cycle from 4V, 0V, and millivolts. It did this either way the probes were connected. Is this normal? Barring a clear explanation I'll just replace the entire battery pack with the newer BT-DN110. However is there any difference between the BTDN110 and the BTDN110-A? (I understand that the newer battery packs will provide adjustment of features via E-tube.)
Many thanks
Many thanks
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,205 Times
Di2 charging
Often the cause of a Di2 battery that won't charge is the USB power supply.
Shimano spec is for input 5V 1A, but a lot of the 1A adaptors that come with phones can't actually manage 1A.
I'd suggest finding a 5V 2A adaptor and charging them again.
Barry
BTW Welcome to Bike Forums
Barry
aged to perfection
Quoted: 839 Post(s)
Liked 1,258 Times
get a 12 v bulb like a tail light bulb at the auto supply store
solder 2 wires onto it, and attach alligator clips
use some wire to connect to the battery poles and drain the battery using the bulb as a resistor
then (re) charge the battery
/markp
/markp
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,205 Times
Why Cycle a battery?
Only reason to discharge and recharge (Cycle) a rechargeable battery was due to the memory effect when using NiCad batteries.
NiMH and Lithium don't suffer from memory, so no reason to cycle.
Barry
Barry
In fact it was my understanding that it isn't a good idea to fully discharge Lithium batteries. You get the best life from them if you recharge when they're down to 40% and only charge up to 80%, although I've never bothered myself.
Likes For jgwilliams:
