Everything rear rack carrier: Looking for inspiration
Bikes: HP Velotechnik Streetmachine GTE, 2015 Devinci Silverstone SL4, 2012 Cannondale Road Tandem 2, Circe Morpheus, 2021 Rose Backroad, 2017 Devinci Hatchet
Quoted: 181 Post(s)
Liked 14 Times
Hi guys,
I am looking for some inspiration. I have been searching around on this forum and on google and did not really find anything that would be better than my current solution. The problem is, that my current solution is not strong enough.
Here is what I currently use:
See the milk crate pictures in my winter/commuter bike thread: https://www.bikeforums.net/winter-cy...-ish-post.html
My milk crate is mounted to an Axiom rack with a 50kg weight rating. Since this thread, I also added a 10mm round aluminum bar to the right top edge of the milk crate, so that I can attach a pannier flat across the milk crate for further volume and weight capacity.
Here are my requirements:
This is what I have considered as an alternative so far, and what I think of it:
...anyone else feeling creative?
Let me know!
Thanks,
alias5000
- I need a good place for my U-Lock to be on the bike without rattling around and being convenient to access
- I have to be able to carry 35kg on the bike with about 25kg of that being in liquid form (milk, water, juice...). This is where my current solution is weak: the milk crate is disintegrating after about one year of use.
- I need a volume of about 50L to carry my grocery runs. As I said, about 25L are liquids, the rest is more on the high-volume side and not as heavy.
- The ability to use bungees and attach lights is a high bonus
- The ability to make the carrying solution detachable (reasonably easy) is also important to me - this bike is my pannier-style bike touring backup, and my current commuting and winter bike.
- it's not strong enough to survive regular mistreatment with ~35kg worth of groceries and other stuff. A little bit more capacity wouldn't be bad.
- The load sits pretty high, so that I do get a lot of side-to-side swaying which makes steering 'interesting'. Though I do have solution for this in mind.
- Using a cargo trailer. -> Trailers are quite expensive! Also, storing the trailer will be tricky, because our basement entrance is not the widest.
- Using front racks + panniers: I think this is a possible future solution. However I don't think the fork I current have will survive a lot of extra load, so I think I will have to wait until there is a good reason to replace it with a proper touring fork (Surly et.al.)
- Adding panniers to the back. This is something I have always been trying to do, but haven't found a good way with this rack. Even if I found a good place for pannier mounts to be added, the panniers would be hanging very low (disc brake! Rear derailleur!), because the milk crate limits how high they can sit. If there's a better way to coordinate the two, I might be there. How much weight can wald folding baskets carry?
- N+1: Absolutely out of the budget. There's a dream-bike N+1 lineup and it's too long already. Also, for me, N=Nmax.
Let me know!
Thanks,
alias5000
Bikes: Raleigh Port Townsend, Raleigh Tourist
Quoted: 36 Post(s)
Liked 11 Times
I've seen wire baskets that go on top of the rear rack. The one I'm thinking of is by Sunlite. Looks to be about the size of a milk crate.
https://www.amazon.com/Sunlite-Rack-...-20&ascsubtag=[artid|2143.a.20086637[src|[ch|
Bikes: Voodoo Hoodoo, Linus Libertine
Quoted: 106 Post(s)
Liked 15 Times
Let me share my set up.
Stainless steel touring front rack plus 2x 22L waste sorting boxes from IKEA.
Effective volume more than 50L.
Quoted: 90 Post(s)
Liked 18 Times
just throwing out ideas without looking at the bike.
i wonder if you could stack milk crates as you need them for more storage. i think the plastic ones stack don't they? maybe hinge a couple so one would be the cover for the other. or use two like panniers and mount them at a level where you could stack a second pair over them, and maybe even wide enough apart that a third could added to the second level, like storage legos.
Quoted: 181 Post(s)
Liked 14 Times
I could just get 3 milk crates. The center one is mounted the way it is right now (on top of the rack). And then I'll build a mounting system so that the other two milk crates can be on the sides of the rack underneath the center milk crate. I'm thinking of using some aluminum L-bars across the rack with two hooks pointing downwards on each side. These hooks can then hook into counterparts near the side-milk crate center. This way, I can unhook the side milk crates when not needed (most of the time) and also keep my removable mounting system for the center milk crate.
I just need to figure out tonight, if this will induce heel-strikes.
N+1/2
add an extra cycle kit, increase rear load capacity.
I own a Burly Flatbed trailer , it folds flat easily, when you take the wheels off.
Quoted: 90 Post(s)
Liked 18 Times
Buy or make : Bike Buckets and things stay dry inside them..
Quoted: 181 Post(s)
Liked 14 Times
I will still replace my broken milk crate (rack top) which should now last longer, since it's now not as over-strained as before anymore.
But I really like the ideas that have come up here, so thanks everyone! I will keep playing with the thoughts of mounting things on the rack sides. This could be additional milk crates; but more prominently, I have been thinking of ways to (optionally) mount panniers underneath the center milk crate without removing it. I already had some ideas for that in my mind, but this discussion has most definitely refined them
In a way the trailer probably counts as N+1/2
Xtracycles are (theoretically) quite interesting, especially because I could also carry people this way (even though I really don't need this feature right now). How do they handle in (Canadian) winter (leaving the salt/rust/dirt issue aside)? It's a long wheelbase, but the rider sits far forward, which gives me the impression it would handle quite badly in deeper snow where sliding/skiing starts. OTOH, let's see how it's going to be with a trailer in these conditions. I'll have to touch up a few dings before winter starts and then keep it nice and shiny.
Hi, we've used rectangular cat litter buckets [free] hung on the rear rack with bent over shelf bracket hooks, and old plastic soda can flats ziptied to the front porteur on at least 5/6 different bikes over the years. Can hook another pair of buckets same way to the front porteur below the flat, but only for paper products and other light stuff. As noted, buckets are light, strong, waterproof, hook on, lift off, portable, etc. Since I use a 'step over' mixte I can load it good and put a 24 roll TP bale on the rear just for grins.
