Saddle Height - Different Shoes
I used overshoes last year but have just bought some winter MTB cycling boots and the sole on them is huge (read very thick) compared to my trainers I wear in the summer and my walking boots I use in the in between before it gets too cold but is a bit wet.
Do most people adjust saddle height for different shoes ... I'm not using clip in's just "normal" pedals.
Quoted: 4227 Post(s)
Liked 2,488 Times
I don't make any adjustments when wearing different shoes... I use regular MTB platform pedals with normal shoes or boots.
Likes For Kedosto:
Mother Nature's Son
Quoted: 853 Post(s)
Liked 1,434 Times
All of my shoes are SPD with recessed cleats, except for one pair. They have 2 hole and 3 hole compatibility and I also use them with SPD. Since the cleat is not recessed, it makes a big difference in pedal to saddle distance and I have to raise my seatpost enough to make up for the difference. My other SPD shoes do not require a change of saddle height. I only use the dual compatible shoes when I know I will not be getting off the bike during the ride. Hence, they do not get used much. I should get a quick release clamp for the bike I would normally wear them with to simplify the changing.
Quoted: 4559 Post(s)
Liked 2,802 Times
Yup. My commuter and errand hybrids have platform pedals. I adjust the saddle height a bit to suit my shoes or boots.
If you plan to do any riding for more than ~30 min, I'd say you should adjust the seat height. Last winter I did some longer rides on my bike with platform pedals, with winter boots on while seat stayed adjusted for riding in sneakers, and some (fortunately minor) knee pain was experienced. The difference in sole thickness was probably around 10mm.
Quoted: 1743 Post(s)
Liked 1,281 Times
Adjust seat height. Most fitters will tell you it's the angle of your knee at the 6 O' Clock (roughly) position that matters.
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
I will adjust if needed, but it is rare.
Cheers for everyone's replies was just interested as the boots are here but they're b'day pressie so can't actually use them for a couple of weeks but I'm pretty sure they'll be at least 5mm thicker than the soles on my other shoes..
Bikes: Casati Laser, Colnago Tecnos, Ciöcc Exige, Black Mountain Cycles Road
Quoted: 129 Post(s)
Liked 177 Times
Yes. I have adjusted seat height after changing pedals and, more recently, after getting some different shoes. Like the OP I got some MTB shoes with thicker soles and then felt the need to raise the saddle a fraction of an inch.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
I've basically paired some bikes with some shoes so that I wouldn't have to tweak any setups before riding. The fixed-gear gets ridden with the Shimano M089 shoes (which also clip in a little more firmly for some reason), the rando and go-fast bike get ridden with the Shimano 5D5 sandals, and obviously, the 3-speed gets ridden with regular shoes. It works.
vespertine member
Bikes: Yes
Quoted: 687 Post(s)
Liked 220 Times
Yep. Different sole thicknesses = different saddle height. Otherwise, my knees speak up.
This is mainly a factor when I'm using platform pedals and switch between thin summer shoes and boots with thick soles. The platform boots are especially fun - I really get a good saddle to handlebar drop with those.
Quoted: 1856 Post(s)
Liked 664 Times
Quoted: 1324 Post(s)
Liked 927 Times
Cheers
Not that I'd ever wish the summer away but these are the boots I bought
https://www.tredz.co.uk/.Specialized...AAEgLZdfD_BwE#
I'm a size 41 so got them for £105 down from £195 .... should have warm piggies hopefully this winter.
I also have some SPD pedals that came on a 2nd hand bike I bough so may try them to see what I think although I doubt I'd leave them on as I like the convenience of just hoping on the bike with a pair of trainers on if I'm just going to the local shops or pub.
