In a strong crosswind, is it better to ride faster or slower?
Sophomoric Member
(I vote slower, provided you maintain enough momentum to steer. But I really don't know what the "right" answer is.)
"Think Outside the Cage"
Depends how gusty it is. But in a strong steady wind you're spending a lot of energy counteracting the sideways forces anyway, so there's only so fast you can go.
Plays in traffic
Bikes: 1996 Litespeed Classic, 2006 Trek Portland, 2013 Ribble Winter/Audax, 2016 Giant Talon 4
Quoted: 76 Post(s)
Liked 14 Times
It seemed to go better the other day for me with about 40 pounds of groceries in the panniers. Then again, maybe there was just as much pushing, but less tipping.
Quoted: 7 Post(s)
the lateral force doesn't change based on your forward velocity. There's no reason it should make any difference, the wind is pushing you equally from the side regardless of your speed.
Infamous Member
Bikes: Surly Big Dummy, Fuji World, 80ish Bianchi
In a cross wind I try to apply some sailing logic - I'll angle into it for a bit to position myself to where I can reverse my angle and get a little tailwind action, repeating as necessary. In the end, it probably doesn't make much difference in effort, but the 'game' makes the time go faster. Obviously, don't try this in traffic.
"Let us hope our weapons are never needed --but do not forget what the common people knew when they demanded the Bill of Rights: An armed citizenry is the first defense, the best defense, and the final defense against tyranny. If guns are outlawed, only the government will have guns. Only the police, the secret police, the military, the hired servants of our rulers. Only the government -- and a few outlaws. I intend to be among the outlaws" - Edward Abbey
I'm not a physicist so my reply is not dependable but, while I agree with notfred about the forward velocity not changing the lateral force, I think there might be a formula that would show that the forward momentum of a mass traveling at a greater velocity as opposed to a lesser velocity would somewhat maintain the initial direction of the mass.
In other words, let's say I'm pitching in a softball game and a sudden wind kicks up from my right side. Would throwing the ball underhanded and lobbing it towards the plate cause it to drift more to the left than if I threw the ball harder (more force and velocity)? I think the greater force would keep the ball more on target.
As far as biking: when I've encountered a strong side wind I tuck way down close to the bars and lean slightly into the wind and aim the bike ever so slightly into the wind. Sometimes it's fun dealing with these kinds of winds- gusty ones are particularly challenging- but on busy roads or bridges where I feel a real danger of being blown into traffic I'm not too proud to get off and walk or wait a while.
edit: someone who knows something about long range target shooting, hunting or sniper rifles would probably have the correct formulas that would somewhat correspond to any object moving forward with lateral forces working on it.
I vote faster is better. I know in moutain biking you are less likely to get thrown sideways off of your bike when going faster because your wheels are spinning faster. The extra centrifigul force of the wheel spinning faster makes the wheel harder to tilt sideways (or harder for the bike to fall over). To demonstrate (some of you may have done this as a kid), take a wheel off of your bike and hold it in the air by the axle. Tilt the wheel. It tilts easily. Now have someone spin the wheel. If you try tilting it now it will be much harder to tilt. The faster you spin it the harder it is to tilt.
Bikes: Pugsley, fixie commuter, track bike
Heres my thoughts:
With a side gust, the wind is deflecting off the center line on his wheels. The amount of deflection is probably not speed dependent. However the cyclist then has to correct by moving the wheels under the center of gravity again. At higher speeds this correction can be faster. However how much you move off of your centerline maybe greater.
I donno. I'm thinking you will wobble much more at slower speeds but the biggest difference you move may be smaller. My vote is for a fast as possible to minimize the total distance.
Craig
Craig
I encounter winds of 40 mph (70 kph) and above fairly often in the winter. I'd say that slower is better, as it goves more time to react to off course excursions. However, it's all pretty much academic; unless there is a big tailwind component, these winds will slow you down regardless of how fast you would like to ride. I agree with threephi.
Paul
Paul
ROM 6:23
Bikes: Specialized Tricross Comp, Lemond Tourmalet, Bridgestone MB-5
META
Bikes: Gary Fisher Aquila (retired), Specialized Allez Sport (in parts), Cannondale R500, HP Velotechnic Street Machine, Dented Blue Fixed Gear (retired), Seven Tsunami SSFG, Specialized Stumpjumper Comp Hardtail (alloy version)
Referencing "Bicycling Science" 3rd Edition by David Gordon Wilson on the secion on Bicycle aerodynamics we have the following information:
"There is little remarkable about the behavior of unfaired bicycles in cross-winds, except for the extraordinary stability they normally display."
Essentially what he's getting at is there is no net effect on stability for an unfaired bicycle and rider in a crosswind except for a little wobble if you get a gust. I'd say keep trucking and try and turn your tail a little to the wind. As for tacking like a sailboat (as chipcom mentioned) it's a good idea but it would be better if you had something to present to the wind so you get the sail-effect.
Pedaled too far.
Quoted: 11 Post(s)
Liked 7 Times
In reality, I don't worry and just go the speed my feet want to pedal. If the wind is somewhat from the front, I slow down, if it is somewhat from behind, I speed up. This happens all by itself.
actin' the foo
Bikes: several
Bikes: 2015 Scissortail hardtail MTB, 2013 XL Longbike USS recumbent, 2010 Hans Schneider steel randonneur road bike, 2005 Surly LHT;
centexwoody
They're beautiful handsome machines that translate energy into joy.
centexwoody
Riding faster shifts the vector of the apparent wind around so that it appears to be an angled headwind rather than a pure crosswind. Here's a scientific explanation of how wind works when you're on a moving bicycle (includes diagrams): https://sheldonbrown.com/brandt/wind.html
In sum, riding faster isn't going to make it any better, but it probably won't make it any worse, either. There's simply a limit to how much effort you can sustain fighting drag, and that's what determines your speed in any kind of wind.
As to whether it makes a noticeable difference in stability, I don't know. That's probably a variable that depends more upon the individual than anything else.
Bikes: Devinci Taos, Mielle Alpha
domestique
I think Physics 101 says it doesn't matter wether you ride fast or slow. A cross wind is not a factor in your forward progress. It just means you need to lean left or right.
Sophomoric Member
Physics 102 says something about vectors that I don't remember very well. But it seems like a cross wind does slow you down--I think because you're sorta going against it just to keep going straight.
domestique
Sophomoric Member
Originally Posted by squeakywheel
You're not going "against it" because you are making zero progress in the direction from which the wind is blowing.
Bikes: 06 Bianchi Volpe
Roody's question was whether it is better to ride slow or fast in a crosswind not whether forward momentum is affected by wind although there is some relation. The question for me hits on the issue of saftey. A steady cross wind can be managed well at speed, but if I faced very strong gusts in traffic I would think twice about riding that busy stretch without wind cover. And if I just had to ride in those strong gusts in traffic then I would take the lane to give myself more play in keeping a line. On the edge/shoulder I just would not feel safe with an unpredictable line with cars behind me.
Happy banana slug
Quoted: 1533 Post(s)
Liked 1,527 Times
Zombie thread ahoy!
Lookit me, being all responsible.
So from what I gather from this thread, I should go as fast as I can, but it doesn't make much difference. Yes? I have this terrifying bridge to cross on my ride home. That walkway is about three feet wide and 8-10" high. When the spring winds hit, I get a good strong crosswind that tries to throw me over the bridge railing into the bay 15 feet below. In trying to compensate I can get a bit wobbly, which threatens to toss me off the walkway and into speeding traffic. What could possibly go wrong?
So. Fast or slow over that bridge? Or just get off and walk?
On Holiday
Bikes: A bunch of old steel bikes
Quoted: 394 Post(s)
Liked 14 Times
Anyway, it's not the lateral force that is the issue for me, it's the gusty wind changes that cause the drama.
