New Bike/Rider Trouble
Hello, I am brand new to cycling and I just bought my first bike. I am coming off a motorcycle accident and using cycling to stay fit while I recover. After a lot of research and coming to the realization that I cannot afford a bike from a bike shop, I bought a Walmart bike. I know this was a bad idea but I really needed an entry level bike for under $200. I bought the Kent Nazz 700c. I’d classify it as a gravel/adventure bike it has thin tires but they have some tread too. My issue is that my disc brakes are really squeaky when braking, the brakes don’t really stop the bike too well, and I think the brakes are rubbing. When I roll the bike I can hear the front brake making a quiet rubbing noise. Being a new bike I am a little disappointed. Is there a fix to this issue other than not buying a bike from Walmart? I really am enjoying my first day of ownership and I am going to start commuting 2 miles to work and 2 miles home each day. Any advice is appreciated. Thanks.
Quoted: 18409 Post(s)
Liked 15,530 Times
Subscribed.
Quoted: 18373 Post(s)
Liked 4,507 Times
You might check to see if your rotors are true.
Just put a pencil or something near the rotor and spin the wheels.
Make sure all the bolts are tight, then use an adjustable wrench to gently bend the rotor until it is true.
Likes For CliffordK:
Been a wrench in a shop since 1982, and my advice is to return the bike, get your money back, and buy a bike with regular brakes. Cheap disc brakes are nothing but garbage and will become a pia overnight. Is there anyone you know that can guide you to a good, solid, used bike shop brand bike? Even a vintage bike with friction shifting will be better than what you have now.
LET'S ROLL
Did you bed-in/break-in the pads/rotors?
One day: www.youtube.com/watch?v=20X43026ukY&list=UUHyRS8bRu6zPoymgKaIoDLA&index=1
Likes For NewCyclist1:
Bikes: Casati Laser, Colnago Tecnos, Ciöcc Exige, Black Mountain Cycles Road
Quoted: 129 Post(s)
Liked 177 Times
Where are you? There are a lot of people on these forums who enjoy helping folks look for good used bikes in their area. If we know where you are, the type of riding you're likely to be doing and generally how tall you are, forum members would be able to look at what's available on your local Craigslist and steer you towards some decent alternatives.
Likes For Oldguyonoldbike:
Quoted: 169 Post(s)
Liked 84 Times
As advised, you're best off looking for a used name brand bike. Try to find some local bike clubs. A lot of us have way too many bikes on our hands. I typically give the older ones away to gain bike karma.
Quoted: 12 Post(s)
Liked 6 Times
Return the Walmart bike. I suggest finding a local bike coop. Usually decent bikes can be had for decent prices at a bike coop. E.g. a Trek Single Track, blue hybrid is $175.00 at my local coop. And most coops will make any issues you find with the bike right and/or teach you how to fix the issue.
Liked 4,507 Times
There may also be an element of just habituating to the difference between heavy high speed motorcycles and lightweight low speed bicycles.
Quoted: 1364 Post(s)
Liked 1,677 Times
Diamond Back - Topanga - $50
- It needs a cleaning, new hybrid tires and the saddle adjusted. I don't know how the brakes and gears are. It is a 22-23" frame (not 32"). The 3rd photo is a different bike.
If you are willing to drive a bit:
Trek 7.5FX - $125
- By far the best deal I saw if you can get past it being a women's bike. However, I don't think it is a 22.5in frame as the seller claims, looks like a 17". You need at least a 19" and probably best on a 20"+ frame.
Specialized Hard Rock - $59
Diamond Back Outlook - $20
Bianchi Osprey - $90
Gary Fisher Wahoo - $100
All the above rigid mountain bikes should have hybrid style tires for what you describe, some have them already. Of each I listed, they are all around the same component level. I'd choose based on distance, condition, and price.
These are the better ones
1991 Trek 930 = $220
1986-87 Stumpjumper = $200
Personally I'd negotiate and go with the Trek 930 (if not too far) as it has been modernized and looks ready to go, but the color is not for everyone. You may also want to add more road oriented tires. The most important thing is that the bike fits you. A 21" frame is in the ballpark for someone 6'1".
I stayed under $220 for my suggestions.
Likes For katsup:
Expired Member
Quoted: 3664 Post(s)
Liked 5,412 Times
Those are some great choices katsup found! Return the Wally bike while you can
SE Wis
Quoted: 2746 Post(s)
Liked 3,390 Times
It would help to have a clue how big you are for size.
https://milwaukee.craigslist.org/bik...946403065.html
https://milwaukee.craigslist.org/bik...946315081.html
https://milwaukee.craigslist.org/bik...943077922.html
https://milwaukee.craigslist.org/bik...925729964.html
https://milwaukee.craigslist.org/bik...940581278.html
https://milwaukee.craigslist.org/bik...937616468.html
https://milwaukee.craigslist.org/bik...937913997.html
https://milwaukee.craigslist.org/bik...938770366.html
https://milwaukee.craigslist.org/bik...932155557.html
Quoted: 523 Post(s)
Liked 228 Times
It just happens that I have a 1993 Trek 930 that I got for free recently. I looked at the pictures for the one on CL (https://chicago.craigslist.org/chc/b...945047422.html) and that one seems to have a lot of component changes on it some not for the better. It came with Shimano rapid fire shifters with integrated brake handles and now has twist grip shifters and separate brake handles. The size also does not match any of the sizes listed by Trek. Sizes: 15, 16.5 18, 20, 22" If the owner changed out major components I would wonder how many miles are on the bike. MSRP brand new was $499 so $220 for a 26 year old bike seems a stretch. Bicycle Blue book lists the price for one in good condition at less than $100. You can take BBB prices with a grain of salt but that looks like a big difference.
It helps if you know a little about bikes. There are a few old bikes on the Racine CL that look nice and are surprisingly cheap. Then there are the overpriced dogs like this 70s Motobecane Mirage priced at $180. It was the lowest grade bike Motobecane made in the 1970s https://racine.craigslist.org/bik/d/...932204905.html. I know because I owned their most expensive model made in 1973. I wouldn't pay more than $20 for a 70s Mirage.
Last edited by VegasTriker; 07-31-19 at 05:55 PM. Reason: removed link to Trek 820 - it was overpriced
The frame is 20" and I believe it's a 1993. At 6'1" he is between 20"-22" frame size.
Edit: I can't tell if the hubs/wheels are original. The hubs look like Shimano Exage from that era.
Would anyone recommend me to buy a bike off amazon? I saw a video saying the following bikes are good entry level in the $250 price range:
Schwinn Volare 1300
Schwinn Phocus 1400
Vilano R2
Vilano Tuono 2.0
My concern would be that I don’t ride on the street, only sidewalks, bike paths, and hard packed gravel so I’m not sure if the skinny tires are for me?
Schwinn Volare 1300
Schwinn Phocus 1400
Vilano R2
Vilano Tuono 2.0
I don't think your troubles stem from buying an inexpensive bike from Walmart. And no, Its not a bad idea for many folks. They sell 10's of thousands of them every year with many happy customers. It has more to do with buying an inexpensive DISC brake bike from them. Some folks have spend 2 - 3x as much on brand name bikes and had the same problem with disc brakes, Which is why I avoid them. Bring it back and try one of their standard bikes with wide tires, at least 38mm for the terrain you ride on. No disc brakes, No suspension forks, etc.
Expecting a disc brake or suspension forks to work well on a low end bike, Even brand name ones IMO is asking for trouble.
If you're buying a cheap bike, it's better to go with tried-but-true components rather than poorly-working facsimiles of higher-end stuff.
Most mechanical disc brakes work by moving the outer pad and deflecting the rotor into the rear pad. That means they're deliberately bending the rotor. Nothing good can come from that, and the low-end ones on a department store bike are even worse because they have poor provisions for adjustments.
A used name-brand bike is still your best bet, something simple with rim brakes and no suspension. Amazon is just a big online department store, so no improvement over WalMart or Target.
The simplest, oldest tech bike you can find may be OK. The majority will likely give you similar issues as your Kent (bad shifting, bad braking, broken spokes, loose bolts, etc...).
You will do much better with a bike shop bike, even when they are 30-40 years old.
Like TiHanero, while you can get a new bike cheaply from Walmart in general they aren't worth it. You can also get more than your money's worth from your local Craig's list. Since you probably don't know anything about sizing or recognizing a good from bad bike try to find a local bike club member to help you or find a local bike shop that sells used bikes. If he sees you as a starting cyclist that may be a future customer he can be very helpful.
I road raced motorcycles for a number of years but motorcycles can get very fatiguing. You get no exercise on them and everything about them is designed to drain the money from your wallet. Bicycles are so much more fun I can't tell you. Not to mention the health additions. I'm now 75 and have the heart rate and blood pressure of a 30 year old.
Quoted: 1303 Post(s)
Liked 1,910 Times
New Cyclist,
Take the Wal-Mart bike back. I've been a mechanic on bikes since the mid 70's and work a bit in our local co-op. North side Chicago should have a couple of co-ops available to you, so look into that. I did a full restore on a Giant Hybrid bike this last spring and it sold for $200. The guy that bought it was ecstatic that he found a good bike for a great price. He commutes to work every day about five miles each way (and he looked me up to thank me for recommending that bike to him). His first bike was crunched in and auto accident that left him bruised and battered but he got back in the saddle with the Giant and loves it. The co-ops are generally a great deal for cyclists. Smiles, MH
Quoted: 1743 Post(s)
Liked 1,281 Times
I am also a motorcyclist. Ducati guy since 1998. Many more before that. It would never occur to me to buy a moto or bicycle from Walmart. You cannot buy a $200 bike from a chain and expect it to be reliable or functional.
