Best Puncture Resistant Tires?
In a previous thread I asked what was the best self sealing 700 X 25 tube there is and was shot down on all fronts. The factory self sealing tubes don't work. Injecting tubeless mountain bike sealant into your tube doesn't work with narrow high pressure tires and the puncture resistant strips not only don't work and but can actually cause flats.
So I am going to try a different tack since I want to avoid flats at all costs. Without any regard to weight, what is the best puncture resistant tire on the market? I have heard of Continental's Gator Skins...Thanks,mjac
Quoted: 626 Post(s)
Liked 701 Times
For my money? Schwalbe Marathon Plus.
No tire is perfect (and Gatorskins are good). Sharp metal object will puncture even the most 'bulletproof' tire, but for glass, goatheads, etc., then the Marathon+ is great.
FWIW, I think tire liners causing flats is a grossly exaggerated problem, and at most, you might have to sand smooth the edges of a liner to a nice taper (I have been running tire liners in my streetbikes, mtn bikes, and now recumbent and velomobile for over 20 years, and never had a flat caused by the liner.
Since most of my riding is commuting (although I do ride a lot for fun, I don't have separate machines for that), I go with what is the most flat proof. I'd rather be a little slower, but be able to get to work without worrying about flats.
Currently: Velomobile - Marathon+ (2 x 20" front) 26" rear with Mr. Tuffy liners. The fronts also have Flat Attack sealant in them (the rear doesn't currently). My recumbent is running Schwalbe Kojaks, which are a little faster, but I also have liners in them.
I check my tires ~weekly. Last sunday, after a 30 mile ride, I checked my tires, and pulled a total of 3 mostly intact goatheads, and 8-9 broken thorns from goatheads out of my tires. No flats.
Bikes: 2021 Canyon Endurace SL8, 2019 Cannondale Topstone Sora, 2002 Giant Yukon
Quoted: 34 Post(s)
Liked 148 Times
From my reading Conti GatorSkins and Schwalbe Marathon seem to get a lot of mention. I own neither of those, I ride Conti GP 4 Seasons and so far so good,
If I wanted maximum flat protection you would recommend Schwalbe Marathon Plus Tires, Mr. Tuffy Liners and Flat Attack sealant in the tubes?(see your line about going about your business without worrying about flats)
Likes For Flip Flop Rider:
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
If that's truly what you want, then solid tires are it. Any pneumatic tire has some risk of going flat.
What at are solid tires and what are these inserts people talk about or were the solid tires facetious?
Quoted: 626 Post(s)
Liked 701 Times
I did note that nothing is fool proof. I have had a few flats, even using tire liners. Everyone of them was something very sharp and metallic (those large, industrial copper box staples are the worst!). In other words, items that would even likely flat a car tire. Never had a flat caused by glass or thorns (even mtn bike riding in the AZ desert) with the tire liners.
The Flat Attack sealant is new for me. I had the shop add it last time I had my velo in for a cassette change. The shop guys swear by it, even while admitting that slime, and the orange stuff are almost useless as a sealant.
Bikes: 2017 Colnago C-RS, 2012 Colnago Ace, 2010 Giant Cypress hybrid
Quoted: 408 Post(s)
Liked 122 Times
FWIW: I can't attest to any other tire manufacturer but I can say that I have been using Conti Gatorskins since Jan, 2011. Over 70,000 road miles total with only three flats caused by punctures. I've had more flats from valves going bad than punctures. I know that there are other tires on the market that can/will give the same performance, but since I've only used Gatorskins on my road bikes, I can't tell you which one(s) they are.
HCFR Cycling Team
Ride Safe ... Ride Hard ... Ride Daily
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
HCFR Cycling Team
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
Likes For John_V:
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
For my daily commuter, I wanted to minimize flats to keep my commute time predictable. For convenience rather than for safety. Changing a flat in 40 degree drizzle in the dark isn't really much fun. At all.
I chose Schwalbe Marathon Plus in 35mm width. Great tire. It's not supple and it's not light weight. It has eliminated puncture flats from this bike over 3 years now. My only flat tire was from a failed valve.
But flats happen on my other bikes.
Likes For Phil_gretz:
Señor Member
Quoted: 649 Post(s)
Liked 292 Times
My chum had Marathon Plus when we were touring a couple years ago. Every time I got a flat (too many times to remember them all) he laughed and pointed to his tires... until the last day when he laughed and pointed one last time, then noticed his rim was flat against the ground. I would still recommend those tires, though. Only one flat over many thousands of kms.
Quoted: 822 Post(s)
Liked 1,961 Times
Good vision, Rx glasses if you need them, good sunglasses with great contrast qualities, and focused concentration on the road are also known to prevent flats/tire damage. I am going back to Gatorskins folding after a couple of flats with Specialized Armadillos and the tread not lasting like the Gatorskins.
Quoted: 1819 Post(s)
Liked 1,695 Times
Everyone has their favourite puncture resistant tire. The problem is that a particular tire model can change over time. I have used Continental Gatorskins(not impressed) but that was years ago. Same with Specialized Armadillos. Both these tires are infamous for harsh ride. I have a set of Panaracer Pacela TG(since replaced by PT) tires on my touring bike which I use here in the spring when roads are covered by sharp bits of crushed rock used to provide traction for cars on snow covered roads. I have never had a puncture although I did once suffer a pinch flat which has nothing to do with the tires. The nice thing about the Paselas is the ride quality and their good grip on slippery pavement. Safety is about more than puncture protection. It is about a tire that can hold onto the road in bad conditions
Quoted: 4560 Post(s)
Liked 2,802 Times
Michelin Protek Cross Max. The toughest tire I've ever ridden. Never a puncture flat. I've picked out broken glass, small nails and tacks, bits of steel wire from radial tires, but nothing ever penetrated the puncture shield. The thick tread has been slashed down to where the yellow Aramid fiber puncture shield is visible, but nothing penetrated through to nick the tube. Possibly the perfect tire for bombed out roads and folks who are forced to ride the debris-strewn shoulders and gutters.
It's heavy but I use it only on one hybrid that I use for errands and casual rides. The tires don't feel sluggish on that bike, probably because I don't expect it to feel fast.
My other lighter, sportier hybrid wears Continental SpeedRides, a great all purpose tire with a minimal 1 mm thick puncture shield. It's had a few puncture flats, but not enough to worry about.
On my road bikes, I'd rather deal with an occasional flat than ride the lead filled garden hose known as Gatorskins. My only concession to practicality is I use Conti Ultra Sport II tires for everyday use. They're remarkably grippy, tough, durable, smooth rolling and resistant to punctures and cuts despite lacking any puncture shield. And at around $15 each, I don't even care if one gets cut to pieces. So far I'll wear them out from ordinary riding before they get enough nicks to do any damage. The last puncture flat I got was nearly two years ago.
I have a few somewhat better clincher tires: Schwalbe One V-Guards, Conti Grand Prix Classic, Vredestein Fortezza Tricomp. Occasionally I'll mount those when I feel like chasing a KOM or PR. But they're a bit more fragile. One of the first Schwalbe Ones I got was cut to pieces long before the tread was close to being worn out.
If I wanted a puncture resistant tire for a road bike, I'd probably try a Michelin Protek Urban, or one of their tougher road bike tires like the Pro 4 Grip Service Course. Based on my experience with the Protek Cross Max, the Aramid fiber shield seems to ride better than just slapping on extra thick rubber for puncture resistance -- which is pretty much what Schwalbe and Continental do for some tires.
Quoted: 822 Post(s)
Liked 1,961 Times
The Gatorskin folding tire rides better than the hardshell IMO. I ride 28 mm so I really do not notice a harsh ride. I do not understand why there are so many complaints re: Gatorskins. I cannot see spending $50+ for a tire when I can get Gatorskins for around $35 and they will last 5K miles. I am a recreational-touristy type cyclist so watts and speed really do not apply to me.
Well, I have several tube tires right now that I wanted to try and get some use out of and was wandering if I could put a top grade sealent in the tubes for the time being if it would do some good. But if I am forced to upgrade I was considering a top of the line puncture resistant tire in as big a size I can fit, Gator Skins, Schwalbe Marathon Plus, in tubeless and inject the best sealent I can find into it and worry about the mess later. That eliminates pinch flats and most of all my nemesis, valves splitting from the tube or valve failure.
This is true.
The other thing, despite what some people say, do you believe the Mr. Taffy tire liners prevent flats. I assume you think this is the best brand. For now I would like to put Flat Attack in my tubes and run Mr. Tuffet Liners and see how that works. See what they say...Thanks,mjac
