Tubeless or not?
#52
Quoted: 8277 Post(s)
Liked 9,033 Times
So the only tubeless tires I have installed or helped to install have all had tubes in them. Since the tire bead is the thing you are trying to stretch over the rim and the tube is (hopefully) not between the tire bead and the rim bed, how does the tube make the tire harder to stretch? Especially during a roadside repair when one bead is still stuck to the rim.
#53
Liked 9,033 Times
I have tubless-ready rims and tires on my mtb and the hardest part is breaking the bead away from the rim. It's just ridiculous! Putting it back on is tight but not nearly as bad as road wheels. I could probably put it on with two tubes in there.
#54
Tortoise Wins by a Hare!
Quoted: 1549 Post(s)
Liked 941 Times
I tried it 2011 and was thoroughly unimpressed. The ride was nice, but back then I was using 23mm tires @110psi on Stans Alpha 340 hoops(and Stans sealant). Wire/thorn punctures sealed nicely, but anything larger would send sealant spraying all over the place.
There is plenty of information available in real life and online regarding tubeless bike tires. Personal experience is not necessary to make an informed decision regarding if one considers it too much hassle, or simply not worth the additional cost and maintenance for them. Most cyclists have zero experience with airless tires yet somehow have no problem deciding that they are not for them. Might as well take issue with them too.
#55
Quoted: 4717 Post(s)
Liked 1,882 Times
Since trying tubeless a second time with wider/lower pressure tires(and a better sealant) this hasn't been an issue.
#56
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4384 Post(s)
Liked 3,016 Times
Surely you are aware that fitting a tight tire requires putting the bead into the center channel of the rim? If there is a tube present and the center channel is shallow, it prevents putting the bead as deeply into the center channel. Particularly near the valve.
#57
Liked 9,033 Times
Let's be clear about something. Not all tubeless rims are the same. The Mavic UST design is a special thing. Your experience with one type of tire or rim does not have much to say about any other specific case.
Most of the tubeless rims I recall don't have a low valley in the center, it's flat between the sides after the dropoff from the bead. Since you have experience mounting tires on the same rim with and without tubes I thought you could explain why the tube makes a difference.
#58
Liked 3,016 Times
Yes, this can be hard, too. Always possible, but sometimes a struggle.
#59
Liked 3,016 Times
#60
Liked 9,033 Times
When I'm home I use a big screwdriver and it's still hard. They're 2.8 Maxxis Rekons on 35mm wide rims. I broke the rear wheel and replaced it with a different rim and it is a little easier but that could be because the tire has been on and off so many times.
#61
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,532 Times
Over the last several years I have helped people put tires on many different tubeless rims. I only mentioned the mtb because it's amusing. It seems to me that mounting on tubeless ready rims is always a struggle but since I always use tubes I don't have information on mounting them tubeless.
If I understand what's being said... After removing one bead from the rim, the opposite bead has to be brought into the deepest part of the center channel. With a tube, that tube somehow then has to fit between the bead that's sitting in the channel, but be out of the way, so you can fit the other bead back into the rim? Is this how it goes?
#62
Liked 9,033 Times
#63
Liked 9,033 Times
Maybe to help visualize, a profile diagram of a typical tubeless rim helps?
#64
Liked 3,016 Times
#65
Advocatus Diaboli
Liked 1,532 Times
That little curved part in the middle? That part we used to call the spoke bed? Some of these rims don't have that, they're flat across. The question I was asking is during a tube installation on the road where it wouldn't be necessary to break both beads why is it harder to get the tire back on if there's a tube in it? How does the tube interfere with stretching the tire bead? If it's just the tube makes things more crowded and takes room from manipulating the stupid tire, I guess I can accept that.
Yes, that's the idea. Ideally, if the tube is up in the tire, far away from the bead, then it causes fewer problems. You don't want it interfering with placing the "other" bead close to the center channel, and of course you don't want it near the part of the bead that you are working to slide over the rim. But it's hard to get it to stay out of the way, particularly near the valve, and this makes it harder to pull the bead into the rim channel to produce enough slack..
#66
Quoted: 20810 Post(s)
Liked 9,456 Times
So, back to your above statement - personal experience is obviously not required to make a decision on whether or not an individual would like to embark upon a specific endeavor for themselves; you do you - I don't care. Where I do care is when advice or statements of fact come from those with zero personal experience - this kind of thing directly impairs individuals looking to make an informed decision. Most of the anti-tubeless ire comes from an echo chamber with little-to-no practical knowledge. Do you not see how this -
"Tubeless is more trouble and mess than it's worth."
....differs from this?
"I don't get enough flats to be interested in trying out tubeless; it seems to be more trouble and mess than it's worth."
One is a statement of opinion that implies direct knowledge and some kind of authority. The other acknowledges no direct experience while relating reasons for reluctance. The former, coming from someone with no experience, is worthless at best but has a lot of potential for harm. The latter has some redeeming value.
Likes For WhyFi:
#67
Liked 3,016 Times
Seems to me I've heard that question already? If you don't believe the answers you are getting and it doesn't affect what you are doing with the wheels and tires you handle, then good on ya, mate.
#68
Liked 9,033 Times
Whether to break both beads? I don't know but I think when I've done this stuff with people we've tried it both ways but I'm not sure. Next time I'm in that situation, if we ever have group rides again, I will be certain both beads are free before trying to put the outside one over the rim. Thanks for your insight.
#69
Quoted: 1819 Post(s)
Liked 1,693 Times
I guess that I must have had a very painless introduction to road tubeless 10 years ago. I bought a pair of Campagnolo Shamal 2way fit wheels and a pair of Hutchinson Fusion2 road tubeless tires. No need for rim tape. Had a bit of trouble mounting the tires not knowing about the centre area of the rim, but knowing that I couldn't pinch an inner tube, no big deal. A bit of trouble getting the tires to seat, but my Silca super pista pump was able to shoot a big enough volume of air that I was able to pump up the tires with a bit of effort. Once mounted, I didn't bother to inject sealant right away, the tires held pressure very well, almost as well a butyl inner tubes. Meanwhile, one of my friends who was using sealant had a very bad puncture that sealant couldn't have helped, so he convinced me that having a spare inner tube (and boot) was a smart move. Not all that later, I suffered a sidewall puncture that sealant wouldn't have helped, but my tire boot and spare inner tube got me home. Since then, even riding without sealant, I have only had to deal with 2 on the road punctures, one which allowed me to pump my tire back up and ride home 30 km away and another caused by an industrial staple which allowed me to ride back to my car 5 km away, only stopping once to pump my tire back up. In both cases, I was not using sealant. To be clear, I have used sealant from time to time, but not all road tubeless tires require it. My current Hutchinson Fusion5 all season tires hols air without sealant almost as well as a butyl inner tube, so I mostly ride them without sealant. If I have a rare puncture, I carry a spare inner tube, no more fuss than changing one. Since I haven't had to install an inner tube on my tubeless wheels for almost 8 years, I feel confident that the various benefits of road tubeless are a big plus for me. They ride smoother, they have less rolling resistance, and they, very much like a tubular will stay in place on your rim if should flat on a fast downhill
Likes For alcjphil:
#70
Quoted: 1743 Post(s)
Liked 1,281 Times
Reading all this I am really glad I listened to GNC and went with Mavic.
#71
Liked 1,882 Times
I’ve never needed to use a tube with my Light Bicycle wheelset, but I used a tube during the initial setup(just to compress the tape). It wasn’t difficult to get it in there like a couple Mavic users have mentioned.
I trust your experience. You aren’t new to cycling. If you couldn’t do it, it’s probably really hard to do.
#72
Liked 1,281 Times
Obviously you love your Mavic wheelset, but have you tried them with a tube?
#73
Today they are making tubeless tires and rims so that they do not fit together well. Maybe if you pay 1,400 for a pair of wheels they may fit better but I wouldn't bet on it. The fit is now so F-ing tight that you need a tire jack (https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1) so it would be really difficult to fix out on the road.
And there are some aluminum wheels out there (https://www.probikekit.com/bicycle-w.../12056926.html) that I stumbled across and bought a set. I really like them and they weigh the same as a carbon wheel and unlike carbon they have equal spoke tension. I intend to run these as clinchers so that I don't have to fuss with them. out on the road.
#74
Quoted: 3949 Post(s)
Liked 7,295 Times
#75
Quoted: 800 Post(s)
Liked 512 Times
alcjphil Your experience with tubeless is pretty much exactly the same as mine. I started 10+ years ago with the Shamal wheel set and a pair of Hutchinson tyres. Man they were difficult to mount. But once on, I found the ride to be a dream. People in my local club mocked me mercilessly because tubeless was all new and crazy back then. The sentiment was pretty much the same that I hear/read on here. Too much hassle.
I am having the last laugh though. Of those who made fun of me? All but one have converted over to tubeless.
