100+ temperatures
#101
Life Feeds On Life
Bikes: Too many Motobecanes
Quoted: 4407 Post(s)
Liked 4,520 Times
I hate the humidity
Likes For Hondo Gravel:
#103
Life Feeds On Life
Liked 4,520 Times
We are having a cold snap only 99 today. I think I lost 3 gallons of water through sweat mowing and weed eating.
#104
Bikes: Downtube IX NS&FS, Dahon Speed8Pro/Matrix/Curve, Brom S2L,Montague Para, ICE-XL w/Rollie/Schlumpf, Trident Spike, ebikes, BFSatRDay
Quoted: 172 Post(s)
Liked 95 Times
This is the 50+ board ,right? The discussion on hydration here makes about as much sense as trusting the stop light enough to blindly cross the street.
Not paying attention to appropriate hydration especially in this age group with its morbidities conditions and medications is disturbing.
People have GPS, speedometers, power meters, and cadence meters and don't bother to look at the scale.
After your second quart you need to start using your brain.
Sadly one of the signs of disorders of hydration and thermoregulation is impaired thinking.
If you're thinking is impaired before you start, this is not considered a good thing.
Trusting your thirst is better than being entirely stupid, that still does not hit the threshold of actually being halfway intelligent
And the only doctor you're going to need , was the one on the HMS Beagle.
Heatstroke is real and the risk gets worse with age and other impairments.
Ill considered hydration strategies that lack balance are a big risk.
If you were pushing hard enough it's hot enough or it's far enough that you're going beyond 2 quarts and/or a quart an hour, you need a well thought out plan and some real science.
it's rough enough trying to avoid brain injuries from the outside. your kidneys are only so smart.
#105
just another gosling
Quoted: 3882 Post(s)
Liked 1,934 Times
For the gentle reader who has made it this far down the thread, a little science might be good to look at, here: https://www.ncbi.nlm.nih.gov/pmc/articles/PMC1872071/
Athletes need to be reassured that a mild degree of weight loss over an endurance event is acceptable, whereas no weight loss represents over-hydration. Drinking according to the perception of thirst appears safe. Specific advice on hourly volume intake is ill advised, but would typically be between 400 and 800 ml per hour.
Results matter
Results matter
#106
Quoted: 172 Post(s)
Liked 95 Times
, Oh I read it.
with shock
not trolling, but the range of ideas has the above quoted stuff awash in so much dangerously ill considered stuff that it is shocking.
Riders of all ages and especially older riders as well as runners regularly get injured and even die from hyperthermia and over as well as under hydration.with hyponatremia.
Pushing past limits is seen as hubris, a dare. Temp, distance, race speed.
My point is one should dose water with the same seriousness as a medication, when one is beyond the range where homeopathic dosing based on folklore is present.
Balancing your citations is advice promoting a bin of "bag of pretzels" and "When I'm thirsty"
Unless longest seizure or time until body found are event metrics, weight change and intake , even fatigue and behavioral change,
might be things to look at, especially since few of the Army hot weather recs reference the 50yo+ soldiers.
Like the military systems, good process with monitoring is needed as distractions and risks increase.
Few soldiers have heart disease, diabetes, neuropathies or are on medications. yet.
I'm just hoping wisdom can accumulate faster than opinions.
with shock
#107
Non omnino gravis
All quotes taken directly from the US Army report.
In the hopes that the 140-pounders in here will stop assuming we're all featherweights,
I'm ~97kg. I sweat more. I need more water.
In Freedom Units, that's three gallons. A day. On the ride where I spent almost 5 hours north of 110º, I drank roughly 2 gallons during that time-frame. I was at greater risk of dehydration/hyperthermia than hyponatremia, by a significant margin.
For ambulatory activities, rates of sweating are nearly proportional to the two-thirds power of body weight. Therefore, a 91-kg man will sweat approximately 30% more than his 59-kg companion walking at the same speed.
Individuals exposed to hot environments generally drink insufficient fluids during physical activity to offset water lost from sweating. Heat acclimatization shortens the time delay between when sweating begins and when drinking is initiated. In addition, heat-acclimatized individuals drink more frequently and more closely match fluid intake with sweating rate; this results in less voluntary dehydration. During light exercise, heat-acclimatized soldiers can and often will drink sufficient quantities to sustain hydration. However, during moderate-to-heavy intensity exercise, drinking ad libitum generally replaces 50% to 70% of sweat losses,and deficits need to be addressed during rest breaks.
In hot, climatic extremes, daily water requirements for soldiers can range from 5 to 12 L/d. The Water Consumption Planning Factors study report (also known as the Potable Water Planning Guide), published by the US Army Combined Arms Support Command, recommends that each soldier be provided with 11.4 L of water per day (ie, intake for each soldier should be no more than 11.4 L of water per day).
Likes For DrIsotope:
#108
Life Feeds On Life
Liked 4,520 Times
What about us 195-200 pound galoots you get use to the heat you adapt just be wise about or end up in a lake cooling off.
6
6
#109
Here in Bastrop Tx a favorite of mine is Park Road 1. It runs some 15 miles from Bastrop State Park to Buescher State Park, which basically butt up against each other. It's a paved road, and much of it is through shaded pine forest. Not a lot of traffic, usually. It works best in the morning or at dusk, when you have long shadows. The disadvantage is the $5 entrance fee, but I may get the yearly pass (there's a senior discount if I'm not mistaken). Parks are limiting number of people so check at the website to see if passes are available - usually no problem except on weekends.
I typically make use of a camel-back for hydration and a sports drink on my bottle holder for electrolytes. As long as I stay away from riding noon - 5 pm, I feel very little perceived heat stress. Another advantage is I can pull over and walk a few feet into the trees, if I need to shed some excess hydration.
#110
Quoted: 6172 Post(s)
Liked 4,789 Times
bikebikebike I'm sorry, but your post just sounds like listening to the news reports. All hype and stuff to get one emotionally worked up, but no substance or suggestion about what to do.
A little bit more sentence structure, punctuation, capitalization at the beginning of a sentence and breaking long winded parts in to paragraphs of similar thought would help some of us that are in the next decade of age. <grin> <run on sentence..... get it?>
The threads been here a while and each telling what they do to cope with heat. You haven't said one iota your last couple posts here what you do to deal with heat.
Last edited by Iride01; 07-23-20 at 06:14 PM. Reason: spelling.... Is it me or is there some autocorrecting that is more automistaking.
#112
Liked 1,934 Times
Some folks on here don't understand the basics behind the recommendations by scientists, which not incidentally, the Army agrees with. An army doesn't fight well with incapacitated soldiers. Some don't seem to believe it, but the Army recs are about right for soldiers being reliably able to do what they do, that's all soldiers. They're not all endurance athletes, though not bad either. The Army (and I) are saying that there are limits on human performance. There is no protocol for doing continuous hard aerobic exercise at over 100°F for many hours. Don't do that. I don't have one, the US Army doesn't have one. You'd have noticed if you'd read the link. It's real simple. You can die. You have no idea whether your risk from hydration was worse than your risk of hyponatremia unless you gave someone a blood sample to analyse. You should have read that ncbi link more closely.
My advice is pretty clear and based on 20 years of experience riding in hot weather. Not as hot at 110, only some hot multi-hour pass climbs, long rides in Eastern Washington in July and that sort of thing, but plenty enough so that I figured out what to do and what not to do. Actually, I didn't "figure it out". I read the Hammer, Ultracycycling, and other scientific advice and learned how to implement it.
I'll make it simple for everyone.
Do not: drink more than 1 liter per hour, 1.2 liters is the limit, that's 40 fluid ounces.
Do not: ride more than 3 hours without peeing. If you have to, stop somewhere with water and shade and drink until you pee. I realize that some find this ridiculous, but this is how you stay safe. Disregard at your own peril. There is no other reliable, in-the-field method of determining hydration state. The skinfold test only shows dehydration. Color of said pee doesn't matter.
Do not: stop drinking because your water got warm.
Do: take enough electrolytes of your choice that you are thirsty enough to want to drink that much water. Never force water. If you aren't thirsty but you should be, more electrolytes, stat. You'd know if you were drinking too much, because you'd have to pee more often than every 3 hours. If you like pretzels, fine. I like Endurolytes because I know what's in them.
Do: watch your heart rate. If it climbs more than ~20 beats over what it should be for that effort, you need shade and rest. Plan for that in advance. Know where your shade and water will be. Always have a ride plan in hot weather. Look at your distance and therefore time between water stops and have enough water on board, plus a little.
Do: wear skin-tight technical clothing and only one layer.
Do: watch your forearms. If they go dry, you need to find shade and water stat, realistically within 1/2 hour. If that's too far to ride, you need to hitch. If you wear sunsleeves like I do now, watch your sweating from other areas. You must be sweating the entire time. If you've followed the above advice, that won't be a problem.
There's a good discussion of heat adaptation strategies here: https://www.tandfonline.com/doi/full...0.2019.1666624
Short form: For adaptation, one needs to ride some in the heat almost every day.
My wife and I did the one-day 200+ mile STP, on our tandem at a team age of 139 and we never were a strong team. The weather was the hottest ever recorded for this ride. We took 15.5 hours to do it. In the first 100 miles, riders were passing us. In the second 100, we were the ones doing the passing, simply because we followed the above advice. At the finish, we were the first to board the first bus to Seattle. It took ~1.5 hours for the bus to fill, not at all my experience on cooler days. Our time was really slow, but not as slow as most folks because we kept our average speed about the same all the way. And, well, I admit that we only stopped 4 times, so we did go a little over 3 hours between pee stops. Over the long run, you're faster if you take care of yourself, have enough food and water, and are able to stay on the bike.
Results matter
Results matter
#113
Non omnino gravis
Where I'm located, the average daytime temperature from July through October is over 90ºF. We get a few dozen days a year over 100º, and a handful of days guaranteed to be over 110º. Not unusual to have a few days in the 90's in November. We acclimate.
While I wholly appreciate erring toward the side of caution, drinking a sufficient amount to urinate every three hours, but keeping intake under 1.2L/hr, that's not a thing-- for me, where I live and ride. In +100º temperatures and single digit humidity, I'd be sweating as much as I'm drinking. Not unusual for me to take in 30oz/hr on a typical ride. I've probably emptied 2x 25oz bottles in 100 minutes ten times this month.
I'll finish this month with somewhere just over 1,000 miles. Sometimes it's plenty hot. I must be managing it alright, because I keep riding day after day.
#114
Liked 4,789 Times
I pretty much agree, generally with Carbonfiberboy . As for the
if this is pure water with no added electrolytes either in the water or from tablets or food, then yes that is a point to start worrying. As for water consumption when augmented with electrolytes ...... I think that much less dangerous, but still maybe some risk.
I've ridden in 100°F plus temps and I don't think I came close to that much water in one hour. On my ride yesterday, I did consume 56 oz. in 1:53 hr:min on a 30 mile ride. It was only a tad over 95°F and being late afternoon the dew point and humidity tolerable.
Still not sure on the contention of urinating every three hours. I'd swear I've done five hour or more and never felt the need. But maybe I'm mistaken. It's been a while since I've ridden three of more hours so maybe I used the restroom or road side somewhere and don't remember. But as far as ever being dehydrated and having dark urine? I haven't had dark urine in years. Even when I wake up after six to eight hours of sleep I don't have dark urine. And I don't think I sleepwalk and pee in my sleep. <grin>
#115
Liked 1,934 Times
I pretty much agree, generally with Carbonfiberboy . As for the if this is pure water with no added electrolytes either in the water or from tablets or food, then yes that is a point to start worrying. As for water consumption when augmented with electrolytes ...... I think that much less dangerous, but still maybe some risk.
Results matter
Results matter
#116
Liked 4,789 Times
Normal weather here is hot from mid May to early October. I actually tend to like that many stay home and I have the trail to more or less to myself. Surprisingly though we haven't had many days over 95°F this year.... so far. Heat index has been way up there, but to me that doesn't mean much when cycling at a decent speed. Heat index is felt more when doing things at a slow pace or no pace at all.
Heat exhaustion will sneak up on you and you have to know the signs. I went dry once in the heat while cycling solo and had chills going up me. I knew I was in trouble and found some shade quick. I haven't come near that experience since that time over ten years ago. And I make certain I won't get caught riding with insufficient supply of what I use for hydration.
#117
Here in Dubai, it was 110 degrees F with about 80 percent humidity yesterday afternoon when I biked home from work. Plus, we have to wear a face mask (or risk a $225 fine). Thankfully, it was only a 30-minute ride because I was completely soaked (as was the face mask) when I got home..
#118
Liked 4,789 Times
I've found the pleated cloth masks work reasonably well. Some are better than others when getting sweaty or huffing and puffing huge volumes of air while riding. Generally the more pleats the better as that seems to keep them from sealing up around your nostrils and mouth only giving a small section of cloth to pull air through.
I'll use them if I'm in a crowded section. They don't slow me down, but they do make taking a drink from my bottles more of a chore. I've tried many but the home made simple two layer pleated masks seem to work the best for me. I tried some of the ones like sports fisherman use that go all around your neck and you pull them up, but they hold in too much heat. They got pulled off in the first two miles.
But if you try one and are done with them, then I'd say you aren't trying. No matter how hot it is.
#119
100+ temperatures
So Cal is usually dry even if at 100 so more liquid is all I need; however my son just moved back to Texas (3rd time-he is a Texan) so I will start spending 6 -8 week periods there; he tells me it takes him 2 weeks to get used to 95 deg/ 95% humidity so I will have to ride in it. I have ridden in the Austin area many times and have established groups I ride with. They ride in the summer and many are late 60's early 70's so it is doable.
#122
Liked 4,789 Times
locolobo13 We've got quite a few of these along some of the lower parts of the trail I ride frequently.
They make a lot of noise when they hit my helmet, and I sometimes feel them struggling to get out of the helmet vents. Also, they don't taste so good and they are quite a mouthful to chew up. <grin>
#125
Life Feeds On Life
Liked 4,520 Times
Drank about 6 quarts of water on my 10.4 mile hike in hot humid weather. Around 4:15 moving time. Ate a couple of salty cracker packages. All I know if you are in the heat drink and drink a lot. Not to the point of hyponatremia. Drink enough but not like you are flushing a toilet you will be OK if you stay within the fitness level you are at.
