Mid 80’s Ritchey Ultra Build ser3009
Mine has the chainstay u brake for the rear so that puts it within a couple years.
Likes For delicious:
Bikes: 91 Ritchey Ultra, 1992 Specialized Stumpjumper, 1990 Klein Rascal, 97 Trek OCLV9700, 90 Minnelli Eclipse, 95 Marin Bear Valley SE, 1991 Breezer Lightning Flash 1991 Diamondback Axis 1992 Stumpjumper Comp 1983 Stumpjumper Sport
Quoted: 101 Post(s)
Liked 639 Times
The paint was pretty basic. Took it down to metal where it needed it and sanded the entire bike to smooth everywhere. I initially hit with Rustoleum grey primer but changed to white and coated the entire frame. I then painted it with a coat of Rustoleum white spray paint. I finally found a store that carried the Rustoleum Pearle Mist. Can looks different than the isual spray cans and i had no idea how it was going to work out but I wanted to try and het it back to original. Needless to say after 3 coats of the pearl I’m really happy with how it turned out. The paint was easy to work with for sure. Let it sit for a week or so and coated it with three coats of Rustoleum 2x clear gloss. I’ve never waxed a frame before so i tried some stuff i had laying around. Not sure if it helped much but looks good. If anyone has advice on how to wax up a great gloss I’d appreciate it.
Quoted: 1088 Post(s)
Liked 1,204 Times
Looking forward to seeing it done. I just finished an MTB with Ritchey everything, and I love how it turned out.
Quoted: 101 Post(s)
Liked 639 Times
Seat and post
A
A couple of parts showed up today👏
Likes For victorm:
Likes For intron:
Wow, looks fantastic. I concur black housing would be great. Sometimes simple is best.
Did you spray the clear over the decals?
Quoted: 101 Post(s)
Liked 639 Times
I don’t recall if I sprayed over the decals so i doubt that i did. Should I?
I am not the local expert, but my understanding is it depends on the material. Thin waterslides can/should be cleared over; the thicker ones (I forget the right term) are fine applied on top of the finish. Maybe someone else can give a more definitive answer. I was just curious about your process. It looks great.
Quoted: 101 Post(s)
Liked 639 Times
I don’t know the technical term for these either but I can tell you they were thicker than any I’ve scraped off a bike frame. I was actually surprised at how thick they were.
Quoted: 101 Post(s)
Liked 639 Times
New bits
rear derailleur is for my 95 Marin Bear Valley SE. toying around with possibly using the red cable housing. Will do some mock ups and see what i like.
Quoted: 101 Post(s)
Liked 639 Times
Mock Ups
Likes For victorm:
Quoted: 101 Post(s)
Liked 639 Times
Any opinion on what colour?
Likes For aceves:
Quoted: 101 Post(s)
Liked 639 Times
Finished!
Will need time for proper photos but hare are a couple teasers
Likes For victorm:
Quoted: 101 Post(s)
Liked 639 Times
Hope y’all like it
Looks excellent. Could have rolled right off the showroom floor in 1989. Enjoy that bike!
Likes For Salamandrine:
Likes For ShannonM:
Likes For kookiemonster:
Quoted: 101 Post(s)
Liked 639 Times
Disassembled and cleaned with warm water with dish soap and some parts cleaning brushes.
Quoted: 101 Post(s)
Liked 639 Times
New bits
So FYI Dia Compe pads turn to stone after 31 years
