New chain, oil or not needed
Hello,
I put a new chain on my friends bike as he had neglected the bike in storage for many years. Frozen links and rust which I could not free up.
My question is do you need to lube the new chain or is the way it shipped good to go.
New chain is a KMC 8 speed chain and my friend is just getting back to riding.
Thanks
Thanks
Quoted: 668 Post(s)
Liked 529 Times
Believe it or not that is a philosophical question. People like Sheldon Brown think the lube chain manufactures put on new chains is the best you can get, others chemically clean the chain and replace it with their own proprietary mix of lubricants, others like me just go ahead and lube the new chain when putting it on.
Likes For Pop N Wood:
Quoted: 3450 Post(s)
Liked 420 Times
Brand new chains are good to go for several hundred kilometres/miles before you need to worry about them. Lubricating a new chain will just make it more likely to pick up extra dirt and grit which isn't what you want.
Likes For AnthonyG:
Quoted: 576 Post(s)
Liked 1,001 Times
Wipe the outside of excess grease and ride the original lube.
Likes For DorkDisk:
Half way there
Quoted: 986 Post(s)
Liked 880 Times
I just install the chain and let the factory lube work it's magic. As DorkDisk recommends, wipe the excess off the exterior.
I usually just put it on and ride until it starts making a noise, then lube.
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,532 Times
Quoted: 1459 Post(s)
Liked 1,480 Times
The stock lube on the SRAM chain I recently purchased seemed really heavy and sticky. After a few rides I ran it through my normal chain cleaner and it was still really gross. I took it off and soaked in degreaser, scrubbed it clean and put new lube on it.
It didn't make any difference in how it rode, but it has been much easier to keep clean since doing this.
Quoted: 1943 Post(s)
Liked 2,164 Times
I’ve pretty much moved away from using wet lubes, so I strip off the factory lube.
John
John
Bikes: 2021 Salsa Fargo 1x12, 2019 Jamis Renegade Exploit 1x11. Motobacne NX Fat Tire
Quoted: 198 Post(s)
Liked 332 Times
The SRAM 11_SPD chain I just put on had a very tacky lube, like pancake syrup. I whiped it down externally as best as possible with WD-40 to get it off than re-lubed.
Many new chains have a heavy preservative lube to prevent rust but it's not great for riding with as dirt and grime stick to it like glue.
I've been using KMC chains for several years now and, I've noticed the thick wax coating causes sluggish shifting & attracts dirt. So, I add lubricant to loosen things up. My favorite go to chain lube is red Type F automatic transmission fluid. I put it into a small 2 oz. plastic Nalgene drop dispenser bottle and place a small amount on each link. Exercise the shifters & drivetrain. Wipe off the excess. Quietest drivetrain & smoothest shifting ever. That's it. That's all. Done deal. Be good. Have fun.
Bikes: 89 Paramount OS 84 Fuji Touring Series III New! 2013 Focus Izalco Ergoride
Quoted: 285 Post(s)
Liked 74 Times
Agree SRAM chains can be kind of gummy. KMC maybe not quite as bad. But as a waxer, I strip them before use. I wouldn't bother lubing a new chain.
scott s.
scott s.
Quoted: 2604 Post(s)
Liked 1,928 Times
The last few chains I've installed have had various amounts of lube. Some didn't need to be wiped, some needed to be run through a rag dampened with mineral spirits to remove the excess.
Quoted: 35 Post(s)
Liked 47 Times
Sounds like the stuff they coat new brake rotors with (for your car) to prevent them from rusting in the box. Sticky and oily. Cleans right up though with brake parts cleaner....
Quoted: 4559 Post(s)
Liked 2,802 Times
KMC recommends running their chains as-is, rather than stripping and replacing the original lube. I do that for the first few months on my hybrid/errand bike chains, but when the chain needs lube I use Park CL-1.
Park CL-1 is a medium weight oil with PTFE. It's really tenacious stuff, doesn't wash out in rain and even resists heavy cleaning with soap and hot water, and "green" spray degreasers. PTFE leaves a distinctive slippery but non-greasy film.
With this technique I may clean and lube the chain once or twice a year at most. It runs quietly and shifts well. I may change chains every couple of years.
When I relube with CL-1 I don't drizzle it all over the entire chain. I apply a single drop every few inches along the chain, maybe half a dozen droplets. Then ride. It gradually distributes itself while riding. Then wipe off the excess after around 20-50 miles.
Park CL-1 isn't one of the sexy lubes often recommended on various chain lube friction tests. In those tests it usually ranks close to dead last for some reason. But I've found it satisfactory and low maintenance for 5 years on my hybrids.
My road bikes are a whole nuther story. I've fussed and fretted with melted wax, "wet" wax, stuff like Rock 'n' Roll Gold and Absolute Dry with PTFE, etc. It's a constant battle chasing a tiny advantage. Not sure it's worth the effort.
Heft On Wheels
Quoted: 887 Post(s)
Liked 560 Times
Jon Cannings on GCN says its the best lube on the market for a wet lube. However it will attract more dirt than standard lubes.
I typically ride for a few hundred miles with the new chain as-is.
But I tend to prefer a lighter dry lube in general so after that I do a thorough de-grease and re-lube.
The stuff that comes on it from factory is pretty thick and durable (and a pain to get completely cleaned off). Can probably get away with riding it for quite some time.
