"25% less torque (compared to dry) on fasteners lubricated with anything"
After my experiment, I looked at bolt manufacturer data and found they generally recommend roughly 25% less torque (compared to dry) on fasteners lubricated with anything (oil, grease, etc.) and roughly 40% less torque on fasteners coated in anti-seize compound.
I've read in multiple reviews of torque wrenches where the person goes to recommended torque and strips the bolt. They assume the wrench is faulty, but it could be thread lubrication skewed the torque reading.
Anti-seize is apparently even more lubricating than basic grease.
Quoted: 1438 Post(s)
Liked 1,092 Times
Data? There are many kinds of anti-seize, some contain copper, some nickel, some a combination, others MoS2 and others have PTFE or similar. I do not think they all act the same, best not to generalize.
Instead, upliftingly, I took Ajax’s advice, which is to reduce the recommended assembly torque by 30 per cent for fasteners in that more heavily lubricated state. I’d expect one of the world’s leading bolt manufacturers to know their **** and get it right in their Fastener Handbook for Bolt products, which you can download independently and confirm.
Here's the link: https://autoexpert.com.au/posts/ulti...ickle-graphite
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
Does the opposite apply when tightening a bolt with thread-lock?
Likes For dsbrantjr:
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,532 Times
Full article: https://forum.ih8mud.com/threads/ant...-bolts.604971/
Expired Member
Quoted: 3670 Post(s)
Liked 5,422 Times
I guess this is about those pesky thru axles again. JMO, but you are obsessing way too much about this.
Likes For shelbyfv:
We used to have a joke about bolt torque back in the day when I was building radio, microwave, and, radar towers out in the middle of nowhere. It went something like this: What's the difference between spot torque and star torque? One is when you tighten something so hard you see stars! Ha ha. No, really. You have to understand the yield strength of materials before you know how to torque fasteners. I rarely if ever get out a torque wrench. Most experienced mechanics understand how much force it takes to snap a fastener in two. And, they tighten things up and stop before they reach that point. It's actually easier the bigger the fastener.
Quoted: 2338 Post(s)
Liked 2,822 Times
apples oranges Big difference between torque in cars, jeeps etc and on bicycles....... where most torque is measured in 4 to 8 newton meters 35 or so for casseette lock ring I don't thing dropping 5 nm to 3.75 (even if you could do .25) is a good idea for keeping things like brake cables and handle bars from slipping
This is "common" knowledge. Be careful.
While many things have torque ratings well below yield or some other failure limit, some don't and that extra 30% becomes very important.
Torque ratings usually assume some regular steel fastener into some regular steel threaded thing.
Side note, galling stainless steel stinks. Use anti-seize on stainless when you can (and reduce torque by 25% unless otherwise specified).
NOTE the link you provide talks about anti seize, not Any lubricant. Anti seize is vastly different than lubing a fastener with oil.
Imo, a torque tool stops you torquing more than the set spec, but it doesnt entirely replace common sense and "hand feel".
I use a torque wrench on threaded bottom brackets and cassette lock rings - the big stuff - and every thing else is done by feel. It would be stupid to post a torque value, assuming no lubrication. Zipp stem bolts, for example, are lubed at the factory. I put antisieze on all threads. I don't reduce the torque value for it. Another example is SRAM XDR cassettes. There's antisieze on the threads from the factory and a factory torque spec that does not get reduced.
I've been wrenching on carbon fiber parts for 25 years now and never had a torque related problem.
Likes For DaveSSS:
This page lists torque coefficients for their anti-seize products: https://www.farnell.com/datasheets/1995733.pdf
"PLEASE NOTE: There are two “coefficients” used to express the relationship between torque and tension: torque coefficient (also called “nut factor”) is the most commonly used. A different concept is the “friction coefficient,” which has a value of 2/3 (or 67%) of the torque coefficient."
0.13 torque coefficient for nickel-graphite anti-seize and 0.18 torque coefficient for aluminum-graphite anti-seize.
