ENVE releases their own tire
Asleep at the bars
Quoted: 234 Post(s)
Liked 203 Times
Is that ever a limitation? I can't recall ever thinking to myself, "wow if only these tires had better grip!"
"This 7:48 cycling session burned 5933 calories. Speed up recovery by replacing them with a healthy snack." - Whoop
Quoted: 18883 Post(s)
Liked 10,646 Times
My 4.5 ARs were designed for 28 mm tires. I'm trying to figure out which size in these tires is best for my wheels. Obviously it's not a tan sidewall one, but that only narrows it down so much.
Quoted: 850 Post(s)
Liked 344 Times
“If only these tires had better grip” is all I think about when I’m trying to hold someone’s wheel going 50 down a mountain. How could you not?
I’m not saying everyone needs all the grip in the world. But if you’re riding with the kind of crowd where half a watt of aero or 3 watts of RR matters, chances are that grip matters too.
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times
Quoted: 20810 Post(s)
Liked 9,456 Times
Newbie racer
Bikes: Propel, red is faster
Quoted: 1575 Post(s)
Liked 1,569 Times
I might be wrong, but sometimes the tire/wheel pairing is meant to optimize the aero interface. That was the idea with Mavic and the tire/rim strip deal on the CXR. If that's the case, it would tend to cater more to TT/triathlon for pure aero and CRR versus grip needed for other racing. Again, I may be wrong. Grip does matter, but not sure how any company could quantify that.
Also, not to say they wouldn't work on other wheels............but LOTS of other aero wheel companies pick one or two really popular tires to design the wheel around. Like a GP4000 or GP5000. Going with these, unless someone tries it first with your exact wheels....you wouldn't know before buying how they'd match up.
Liked 9,456 Times
This is why the WAM/RAM specs should be pushed. Pirelli is doing it on their new tires and ENVE at least has the WAM; I hope that others follow suit. For now, Schwalbe has at least said that their new tires should measure out to their nominal with a 19mm int width rim, so it gives you a decent idea of a starting point, while Conti has been more vague, simply saying that they're sized with "modern width" rims in mind.
Likes For WhyFi:
Newbie racer
Liked 1,569 Times
I think at slower speeds the gains in CRR of a larger tire on some aero wheels might work out fine. But the aero losses of the bigger tire bulging out at higher speeds far outweigh the CRR gain. That's why Enve and others are designing wider aero wheels now. Play both games at the same time.
One thing I'm surprised hasn't come back from Conti or others is the concept of the "attack/force" aero tires. Their CRR wasn't great, but they tested out pretty good in some tire/wheel aero tests I've come across. I would love for them to release an "aero" version of the GP5000 TL. Even if not branded as such.
Bikes: 1984 Fuji Club, Suntour ARX; 2013 Lynskey Peloton, mostly 105 with Ultegra rear derailleur, Enve 2.0 fork; 2020 Masi Giramondo 700c, full Deore with TRP dual piston mech disk brakes
Quoted: 324 Post(s)
Liked 81 Times
I look at this the same way I look at automotive tires. If you drive a Porsche 911 GT3RS, you have about 10 options for a rear tire, and the cheap one is ~$300. If you drive a Toyota Corolla, you have about 130 options, and they start at $39. In this analogy, the ENVE 3-point-whatevers are the Porsche.
Folks running the Mavic system seem to be pleased overall, despite being "limited" to a certain selection of tires.
Likes For greatscott:
Non omnino gravis
Absolutely unfair to blame the roadie tax on ENVE-- we don't even know how much their tires will cost yet (though I assume on par with a GP5000.) The "bike tire vs. car tire disparity" is a long running one, and every single manufacturer is guilty of it. In this case, I give ENVE a soft pass because they don't make automobile tires. I still have the screenshots from before the release of the Conti GP5000. Relative to the GP5000, the Extreme Contact is 8 times as wide, lasts 20 times as long, and costs about the same.
Likes For DrIsotope:
Quoted: 850 Post(s)
Liked 344 Times
Non omnino gravis
Normal person's opinion, if you're fine with $2,500 for wheels, you probably don't flinch too hard at $90 tires. I spent like $700 for the wheels... on my car, which means there's four of 'em. And they were forged in Japan.
Further normal person's opinion, ENVE wheels are too expensive, their tires will be too expensive, pretty much everything in this life is too expensive. Except TVs. Those things are dirt cheap now.
Asleep at the bars
Quoted: 234 Post(s)
Liked 203 Times
And I just found GP5000TL 700x28 in stock (just received them today). $60 from Amain Cycling: https://www.amaincycling.com/contine...72580?v=871693
Interesting idea, but how many Enve tires would it take to equal the width of one Porsche 911 GT3RS tire? Plus the Enve tires will last maybe 3,000 miles while the Porsche tires will last 30,000 miles, so now you have to apply the math of that and you'll be shocked to see that the bike tires will cost a great deal more than Porsche tires will over time.
Asleep at the bars
Quoted: 234 Post(s)
Liked 203 Times
How many Porsches out there ever get to see a track... 5%? 1%? 0.01%?
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
I have a (dentist, yes) friend who (before feeling the burning need to upgrade his 808s to 858s) said he would spend two grand on an Enve rear disc to match his 6 front for tri. Just so it would match, aesthetically. He'd totally pay $90 a pop for tires to be matchy-matchy. Or would have last year.
probably akin to the percentage of Hummers seeing dirt vs driveway pavement
Joking aside, I vaguely recall a collegue once told me his GT3RS rear tires only last about 10k, and he isn't tracking his car. I believe he had Michelin Pilot sport cup 2's.
Likes For aclinjury:
