tubeless conversion - tape question
Old 03-13-21, 05:32 AM
CrowSeph
CrowSeph's Avatar
Bikes: BMC SLR01; Cannondale Trail; Lot's of project and vintage bikes..
Quoted: 333 Post(s)
Liked 168 Times in 101 Posts
I'm planning a tubeless conversion , actually i'am still running classical tyre with inner tubes.
Any of you guys have used one of those tapes instead of the normal rim tape?
and which are the pros and cons of every tape listed below?
  • gorilla tape
  • electrical tape
  • other cloth tape
CrowSeph is offline
Old 03-13-21, 08:42 AM
trailangel
trailangel's Avatar
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times in 422 Posts
Do yourself a favor and buy the right product. Are the rims tubeless compatible, or are you trying to see if you can get non-tubeless rims to work?
Calvin Jones looks like he is using Gorilla tape:
trailangel is offline
Likes For trailangel:
Old 03-13-21, 09:49 AM
dabac
Quoted: 1074 Post(s)
Liked 295 Times in 222 Posts
I’m not too fond of using electrical tape. It’s soft enough to need double layers and the adhesive seems to smear fairly soon.
On some TL-ready rims I’ve used bundling tape with good results.
If rims aren’t TL-ready, you usually need to build up the trough some - or a lot - to get it to work. A thick pipe insulation tape tend to work better/faster than multiple layers of regular tape.
dabac is offline
Likes For dabac:
Old 03-13-21, 04:45 PM
Kapusta
Advanced Slacker
Kapusta's Avatar
Quoted: 2762 Post(s)
Liked 2,537 Times in 1,433 Posts
Gorilla Tape works great. At least as well as the real thing in my experience. I recall reading instructions from some high end wheel manufacturer that specifically recommends it (I forget which one).
But there is a caveat: If you need to remove it, it is a real b!t#h to get all the glue off.
Kapusta is offline
Likes For Kapusta:
Old 03-21-21, 12:57 PM
DETarch
Quoted: 14 Post(s)
Liked 5 Times in 5 Posts
I'll echo Kapusta- Gorilla tape is NOT fun to remove. Leaves tons of residue that needs to be completely cleaned for new tape to stick. I also think it's more porous that dedicated tubeless tape and tends to soak up sealant.
I've had good luck with Orange Seal tape- it seems to stretch and stick a bit better than Stan's in my experience. I'd recommend using a dedicated tubeless tape.
DETarch is offline
Old 03-21-21, 01:08 PM
tyrion
tyrion's Avatar
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times in 972 Posts
Yes, Clear Gorilla Tape. Works great, but as others have mention, a real PITA to remove and clean up residue.
tyrion is offline
Old 03-21-21, 02:19 PM
downtube42
downtube42's Avatar
Quoted: 896 Post(s)
Liked 2,063 Times in 1,081 Posts
Gorilla Pros:
Rips to proper width easily
Goes on ez pz
Sticks and Seals
Cheap
Gorilla Cons:
Tire mounting can be harder, since the thicker tape fills up the center bed.
Residue after removal
Electrical Pros:
Cheaper
Electrical Cons:
Too Stretchy
Will probably require multiple layers to go from bead to bead
I don't think cloth tape is in the ballpark. Porous and thick.
downtube42 is offline
Old 03-27-21, 10:51 AM
CrowSeph
CrowSeph's Avatar
Quoted: 333 Post(s)
News: i decided due to the cons of the gorilla tape to use a specific tape but i had to admit i fall for the cheapest one on internet (brand ztto or zitto). Let's see how it works.
CrowSeph is offline
Old 03-27-21, 07:04 PM
Clem von Jones
Quoted: 151 Post(s)
Liked 23 Times in 16 Posts
It's a false economy to use make-do tape for tubeless. I would try the Scotch 8896. 3M-Scotch makes good adhesives and tape. Tubeless setup can be a pain in the ass. You have to get the details right. When it works as it should it's far far better than tubes, but when it fails it's a colossal mess.
Clem von Jones is offline
Likes For Clem von Jones:
