When were Shimano ALTUS AX derailleurs made?
Quoted: 1324 Post(s)
Liked 927 Times
I never knew until recently that Shimano made ALTUS AX derailleurs. I have both a front one and a rear one. the front one looks just like the old Shimano FE front derailleurs and the rear one looks a lot like the Adamas AX one but with provision for external cable housing.
Does anyone here know when these were produced?
Cheers
Cheers
Quoted: 4722 Post(s)
Liked 3,038 Times
Definitely 1981-1983 model years, possibly 1984. There should be a double alpha character date code on them.
Edit: Just double checked my literature and Adamas AX was only 1981-983.
Liked 927 Times
I wonder if ALtus AX was strictly OEM stuff on bikes?
Cheers
Liked 3,038 Times
Many of the aero developments of AX went mainstream: elimination of embossing and fluting, aero seat posts, aero stems, aero pedals, aero brake levers,etc. There's not a whole lot to bring back.
Liked 3,038 Times
There was a an AX group below Adamas AX called just Shimano AX but the rear derailleur was Positron and used the direct cable mechanism without housing. You should post pictures, check the model numbers and date codes.
Freewheel Medic
Quoted: 1453 Post(s)
Liked 2,196 Times
Hopefully this does not derail (sic) this specific thread, but since I recently acquired a Lotus Super Pro Aero with Dura Ace AX, a picture of the RD could be helpful. Notice how there is no cable housing? The RD cable runs straight from the shifters to the BB guide to the RD.
Bob
Bob
hi,
I also just fount out that ALTUS AX existed and was surprised that there are literally no photos on google with them. Can you upload some photos with your derailleurs ?
Also, you should check the back plate of the front derailleur and the rear derailleur's cage for 2 letters (ex. GE. ). If you find them you will find when your derailleurs were produced. I doubt you can find someone, other than Shimano itself, that can tell for sure the period when these were made but I would guess, like others , that these were produced somewhere in the early 80's. Maybe they were produced only for a year or two as they are extremly rare.
