Stopping CC (carbon fibre cable) rattle
Old 11-09-19, 09:28 PM
UsedToBeFaster
Quoted: 125 Post(s)
Liked 18 Times in 14 Posts
I have a cyclocross bike so cables on top of TT.
I installed everything but there the cables rattle.
Of course I could pull everything apart and install donuts. But is there a faster solution?
UsedToBeFaster is offline
Old 11-09-19, 09:35 PM
SalsaShark
SalsaShark's Avatar
Bikes: 2014 Trek Allant drop bar conversion, modified Schwinn MTN commuter, 2015 Trek 520, Soma ES, Salsa Journeyman, 1980 Trek 414
Quoted: 178 Post(s)
Liked 355 Times in 166 Posts
Cut a donut, install on the cable, and super glue it onto the cable in the position you want it. I usually glue those things in place anyway just to keep them put even when i remember to install them correctly with the new cables. Glue on the exposed cable won't impede operation, and adhesive traces can be removed with acetone if needed.
SalsaShark is offline
Old 11-09-19, 10:26 PM
DrIsotope
Non omnino gravis
DrIsotope's Avatar
Quoted: 4905 Post(s)
Liked 1,731 Times in 958 Posts
You could put a strip of sticky-back hobby foam under the cables as sound deadening. I've used sticky-back hobby foam to stop housings from rubbing on the headtube/frame. It holds up pretty well, removes relatively easily. Comes in a ton of colors, also really cheap.
DrIsotope is offline
