Trek Shift 3 Tektro alloy linear-pull Brake pad Toeing
I am new to the forum so i can't post pictures yet but i have a question about how to align brake pad on cheap components.
I do some bike repair on the side as a kind of hobby. I have a fair amount of regular customers that I do tune ups for. It is mostly casual riders. When I have a new customers they generally bring in barn fresh bikes that they want to start riding again. So in comes the Trek Shift 3 bike with Tektro alloy linear-pull brakes. The brakes are very cheap, but they are about as good as they where when they were new. First I tried adjusting the cable but found the that I had to really open the brakes up to get the brakes not to rub and the lever was close to bottoming out on the grip. The wheel is true to within a 1mm. As i start to check the centering of the brake I noticed the pads are not lined up properly with the rim. As I fix that i notice two things. 1) to align the pad with the rim i have to set the brake pad post to the extreme lowest position. 2) The pad also has severe toeing in the wrong direction . The pad has conical washers but even when loosened and adjusted to the maximum toe in the washers allowed, the pads still are toed in the wrong direction. I couldn't even achieve parallel pads with the rim.
What i did to fix this situation was to just slightly bend the pads to the proper adjustment.
next time this happens should i do the same thing? or is there a better procedure to fixing this issue?
Thanks for your feedback
Quoted: 422 Post(s)
Liked 994 Times
I would check that the right size wheel is installed, and whether the brake arms or fork (assuming front brake) are bent. Also make sure the concave washers are installed in the correct order.
Thanks! @bboy314
Quoted: 555 Post(s)
Liked 494 Times
• Spherical washers are assembled in the correct order and orientation so they can actually work as intended.
• Brake bosses are parallel as seen from above, to give the brake arms a chance of adjusting properly.
But beyond that, with cheap components sometimes the best you can manage is to persuade them into the right sort of shape with whatever implement does the job - often a crescent wrench. Once you've done this the fix should be permanent, so not too worrying that you've bent aluminium parts, but do be careful to only bend as much as necessary.
Likes For grumpus:
Two things to check:
thanks! Grumps
next time I will need to double check the washer order
Quoted: 528 Post(s)
Liked 472 Times
What's a matchbook cover, you might ask. Ask your grandpa.
