How do you know when its time to replace your chain??
Quoted: 18459 Post(s)
Liked 15,710 Times
I replace my chain every time I wash my sheets.
Quoted: 4717 Post(s)
Liked 1,882 Times
https://www.parktool.com/blog/repair...icle-section-2
I use a ruler to measure the chain. Usually the chain needs replacement every 3k miles. YMMV
Quoted: 8 Post(s)
Ok, what about performance? If lets say you have 5k miles on chain. Will it skip, have difficulty changing gears? etc.
I use a ruler to measure the chain. Usually the chain needs replacement every 3k miles. YMMV[/QUOTE]
Bikes: Cervelo S3
Quoted: 38 Post(s)
When my park chain tool tells me to, once the .75 end fits in between the chain links, I switch it asap, till then it’s good. (Im on 10 speed though, 11speed you change at .50 wear)
Hassle and worry free way of checking, tool is like 10bux
Quoted: 3382 Post(s)
Liked 5,554 Times
You get skipping when you put a new chain on a worn-out cassette.
Quoted: 2953 Post(s)
Liked 3,106 Times
Every couple thousand miles or so, whenever shifting gets compromised.
When it breaks and its too worn to press it back together.
Farmer tan
Don't be like me.
I waited too long and it kept working fine.
Then, when I checked it was 1/8 inch over 12 inches.
Put a new chain on and it skipped.
Put a new cassette on and it shifted like new, but it still skipped.
Put new chainrings on tonight, so we'll see what happens tomorrow...
